Losi 8ight building and setup
#4201
Ok, so at that angle it really works without tension? I just never seen anybody do that yet. Maybe thats how its suppose to be done, I havent done it like that, anyone else?
Oh, and I noticed that you have 2 trays, 1CF and 1aluminum, Do you think it feels too stiff? Or is it feel the same?
The trays....maybe overkill...... But in my opinion, like my wife says, the stiffer the better. I like the Kings Headz extended motor mount, Xtreme Racing CF Radio Tray, Qoncepts.com Aluminum Center Diff mount, Aluminum front and rear center braces, I also put longer screws in the bottom of the radio tray. Just my opinion but I don't buy the whole (torsional flex thing in offroad), unless you race smooth high bite tracks. Here in Tennessee we have alot of goat pastures I have ran a lot of electric and nitro onroad where chasis flex is a good thing, but to me in offroad thats the job of the shocks......
#4202
Dan did the same setup on my buggy using a longer servo horn. If you think about, since the carb has to be angle because of the center diff mount, you put less stress on the servo. You extend the servo horn to avoid putting stress on servo. With the stock horn, it is short and the servo has to travel and fight the angle of the carb which in the long run will wear out your servo. It makes sense to me and works great.
Thanks Dan for the help!!
#4203
do you have to trim the plastic on the servo tray for the ace servo to fit it ??this is for the throttle brake BTW
#4205
hmm..this could be the answer I am looking for! I cannot believe that all three of my engines (and 4 carbs) are wacked...the longer servo horn does make some sense...it looks odd, but if it works, that is what counts! I will give it a try and see what happens..thanks bro!
#4207
i just picked up some upgrade rc wraps for my m11 and 8ight. wanted to post some pics. watch out for me in joliet at the rc pro series. also check out the new neon yellow wing by losi.
#4208
Novarossi Rex R21BF with a black head. If this was all the info you had, how many ports would this engine have? Also, is it possible to find more info about the engines using the batch numbers on the side of the engine box?
Thanx for the help.
Hey Joecool,
Several friends of mine and me, will be headed to Joliet at the end of July. Is the layout gonna get changed up? This wil be my biggest RC road trip yet? I keep getting farther and farther from home. But it's awesome at the same time. Can't wait to meet the people up there.
Thanx for the help.
Hey Joecool,
#4209
If the cooling head does not have a 2000 on it then you have a 3 port sport motor that is very popular. They retail for 165-189 usd. The newer ones have a larger cooling head than the old ones. They are great engines for the price. They have good lowend due to the 3 port design. An 086 pipe would be a good all around pipe option, with good mileage.
#4211
Thanx for the help.
Hey Joecool,
Thanx for the help.
Hey Joecool,
#4212
ya, I'm building my tire supply still. It takes a while. And going on long trips, I'd imagine a guy could never have enough. And especially if there is two different types of tracks we could run on. But at our track, we race indoors and outdoors. So I have tires for both conditions.
What makes you want to use 25w. in the rear shocks. Does the track get really bumpy and blown-out?
#4213
Hey guys, just a couple things I tried yesterday that worked well, so it's worth repeating.
- 37.5 and 54's in the front, 25 and 56's in the rear. Down from 40 and 27.5, seemed to get through rough stuff better without sacrificing corner speed.
- Four carbon shoes with four gold springs in the clutch. Lots of power, great feel, excellent wear!
#4214
#4215
What track were you testing at yesturday?
