New xxl2e owner
#46
Tonight I did my first diff service on the rear one.
Yesterday I noticed it was loud or screaming some. So I took a look. Found my heatshrink cut off the rear diff input. Also some play in the pinion bearings. I thought ohh no. Hear we go again.
Took it apart tonight with the good thoughts of it only being the bearings.
To my surprise it was only the bearings.
Everything else looked good. Even the side gear drive pins weren't broken.
So I had new bearings the correct size. Got them from avidrc. Put them in the diff after cleaning it. They fit really good.
Put it back together and checked it. All shims back where they came out. Turns very nicely. Not extra play but not to tight.
Finished it up and ran a pack thru it. Nice and quiet.
Compared to the diaster- this losi is a pleasure to service.
Loving losi!
Loving losi!
#47
Yes, it's so nice to work on. Did you fill with diff fluid? That helps too if you haven't done that, also upgrade the pins in the diff. To HPI diff pins, much stronger, the part number is #Z260. 2.5x12mm. Other than one shock shaft I haven't broke anything....and my part wall is proof, look at all the Dollar Hobbyz bags that haven't been used yet! Lol
#48
You should sqeeze a CD in that truck I had zero diff, slipper pad or pin problems. The magic of a CD
#49
I did fill with fluid. Got the hpi pins coming to. Found that number to on here. Today when I get home I'm replace wheel bearings. Got a lot of play in them. Been running it too much. Lol. The water, mud and dirt hasn't helped.
#50
Nice job doing all that.
#51
I skimmed thru your build yesterday. Your truck is really nice. I would to get that truck body and paint it. The cd you installed I found really interesting. Going to read it closer at somepiont. I really liked having motor and cd lower in chassis.
- rounding of hexes
- burning slippers
- diff problems
- calms the wheelies down a bit. (not on 6s really)
I also have CD in my two electric savage trucks. fitting a CD is another hassle
#52
Yeah kinda panicked yesterday. Cause of the previous rc bad diffs. I got parts coming for the xxl2e now. But I will be easier. I can set 2 diffs up and ready to swap in.
#53
The stock ones are in it yet. But after a month of running it thru everything it's expected.
I have rubber sealed bearings from avidrc. Going to put them in this afternoon.
#54
Replaced all the wheel bearings today. I used rubber sealed bearings from avid. I removed the seal on 1 side. Put some grease in the hub between bearings. Noticed I need some 8mm I'd shims to remove the end play.
Charged a set of batts and ran it.
Nice and quiet. Like new.
Really enjoying this xxl2e.
Every change I make the truck responds. Weather it's bearings or shock oil or spring tension. It responds. Losi made a pretty darn good truck here.
#55
Glad your loving it.
Trout
#56
Hey Trout, can you fit 2 4s in that battery tray? been trying to find the inside dimension on those
thanks
thanks
#57
Won't work this way, but you can see what batteries I have, great battery, I run them in all my rc's. I must have a dozen or more, only had one with a bad cell in years.
#58
But will work this way, but the back battery will not be flush with the front battery, but you can strap it all in.
#59
Hey trout those work pretty good then.
I would like to a different tire. I have dirt track near me. Would like to find a tire with better bite.
Are you using the 24th motor gear?
How much smaller are the badlands?
#60
Yes 24t pinion, but I think a 26t would be better. That conversion opens up your tire selection big time.
