New xxl2e owner
#31
What servo(s) are you running? I don't think you will see much improvement if don't have stronger power hungry servos. I tried running a single hitec 7980 and without the bec it would make the esc flip and the motor would kick in randomly. Now I then tried two savöx servos and it almost jammed the esc at full throttle for several seconds. Actually hurt myself pretty bad grabbing the car. I was doing this indoor and was being a bit careless. With a bec that's all gone.
So that should be a healthy increase maybe.
Just trying it out. If it doesn't work I'll get another servo. I already have 1 hs7954sh which does 403 inoz at 7.4. I'll just get another or try switching the servo savers to the mgt springs. Supposed to be stiffer.
See what happens.
#32
#33
Just plugged it in and checked. No smoke tonight.
Then it on and tried steering. Pretty snappy now. I the servo savers being upgraded will help more also. Gotta go. Lipos to run out. Yippee!!
#34
It's not scientific but my nephews LST had LED's on it plugged into the receiver and they dimmed a lot when you steered. With a Castle 10amp bec set to the same 5.1v the MMM esc puts out the LED's dimmed less because the external bec is capable of more amps so voltage under load doesn't drop as much. With the external bec set to around 5.7v the LED's didn't dim at all and servo performance was improved. I eventually settled on 6.3v for that truck to keep from burning out the LED's and the servos liked it too. More voltage equals less amps drawn. A bec may be rated to 5amps or 10amps but that's the max, doesn't mean voltage won't drop when you try to draw that many amps. That's the part nobody tells you.
Edit: Glad everything worked out for you in the end.
#35
Stock servos. Read in an earlier post that the stock servos can run on 7.4. Rx only supplies 6 volts. The servos have more power. I figure the 1.4 volts is almost 25%.
See what happens.
See what happens.
#36
Servos don't have to be power hungry to see the benefits of an external bec, as long as it's more capable than an esc's internal bec. Any Bec is just a power source and like any other power source there will be voltage drop under load. I once hooked up a multimeter to measure the amp draw of a servo while sawing the transmitter wheel back and forth. I saw an average draw closing in on 1amp with spikes up to around 1.5amps. Even on a 5amp rated bec your going to see the normal 5.5v it puts out drop lower under load. Strap on a 10amp bec and the voltage will drop less because it can put out more amps. Raise the voltage and your going to draw less amps, Ohm's law, wattage = volts multiplied by amps. Any load, servo, motor, etc is going to draw a certain wattage. Divide watts by amps and you get voltage or vice versa.
1) 7.4V = I x 2 => I = 7.4/2 = 3.7 Ampere
2) 5.5V = I x 2 => I = 5.5/2 = 2.75 Amps
I see it this way -> With a higher voltage the wheels will turn in say 0.5 secs
With a lower voltage the wheels turn slower in, lets say 0.8 secs the wattage used to turn the wheels may be the same as watt is defined as energy over a period of time. But in order to turn the wheels faster more juice (amps) is needed and it's possible to draw more amps with a higher potential. (Volts).
What I'm trying to say is
High voltage = more amps drawn a shorter period of time
Lesser voltage = less amps drawn over a longer period of time.
The same amount energy (VxI) is used measured over time.
#37
#38
Very easy but I only done it once 3 years ago. If I remember correctly you buy the mgt servosaver and use the stock servo arm(s). Not sure if the mgt came as a kit for all splines or if you needed to buy the correct version for your servo?
#39
Some more info here
http://www.rctech.net/forum/monster-...ng-servos.html
EDIT: Even more info: http://forums.thetoyz.com/index.php?showtopic=7755
#40
So couldn't find 2 of the parts.
Then read your idea. I like it. It said to use servos from the mgt.
Thanks.
#41
Some more info here
#42
#43
The xxl2e has spektrum 601 servos in it now. I'm trying to find spline count. Then I can order the mgt saver.
#44
#45
