T/E Maxx Thread >
T/E Maxx Thread
T/E Maxx Thread
Old 02-25-2002 | 12:19 PM
  #76
TPhalen's Avatar
Well, even if they were 100x better, I couldn't run them....
But do let me know what you think if you do decide to try them!!! I'll live through you on this one...heh heh
TPhalen is offline
Old 03-12-2002 | 03:41 PM
  #77
Buda's Avatar
Default TP
Nice to see you here too, from what you talk about in the TC3 forum you really dig that Maxx.
Now the question is do I go for E-Maxx or T-Maxx.
Bearing in mind it probably wont be raced just bashed about unless the Snetterton off road track gets my attention. But I dont really have the cash (spend a bit for martial arts training) to race two cars/trucks and I got a bit of cash tied up in the TC3.
Ok I have some batteries for the emax but use those for racing and desire the longer run times that nitro can deliver.
Stock how long is the emaxx run times? I have 4 2400 and 2 2000 mah batteries. The 2400 are my race cells and the 2000 are for practice/tuning
Can you give me pros and cons of each?
Cheers M8
Buda is offline
Old 03-13-2002 | 07:33 AM
  #78
TPhalen's Avatar
Well, I wouldn't suggest running your good packs on the E. If you decide to get an E, I would just hold off and get some ok packs for it. Wouldn't want to overuse your good race packs now, would ya???
Pros and cons. Well, have you ever had a nitro vehicle before??? If you have, then you have some knowledge of tuning. That is the biggest thing for people to learn. And the hardest.
Nitro gives you longer run times with less down time in between runs; electric has longer down times, but, in most cases, can be upgraded with a little less cost and have more power. Plus it's easy. Plus it's a little cleaner. But, you can upgrade the Nitro to a .21 or XTM's new 24.7 motor and get some amazing power (if tuned correctly) out of it. AND long run times.
I couldn't decide so I have one of each . The stock T motor is really boring for me (since my E is ridiculously fast), so I'm in the process of converting to .21 power.
Check out MaxxTraxx dot com for some other good info on these trucks.
TPhalen is offline
Old 03-15-2002 | 09:52 AM
  #79
myclod's Avatar
I gotta agree with TPhalen on this one, i would say if you already have electric to stay with it in this case, i have a T, E and a Clodzilla 4, and out of the 3 i play with the 2 Electrics most, for 2 reasons, #1 electric is instant torque, and alot more fun for me since i run in a rocky wooded area where i really can't go fast, and #2 cleaning....i can clean my electrics up quickly with a brush whereas with the TMAXX i spend upwards of an hour or so cleaning the thing so therefore i run it less., Either way you go you are getting one of the best R/C products on the planet right now and will have a blast with either,
myclod is offline
Old 03-17-2002 | 09:11 AM
  #80
Anyone here tried the associated shock kit? The shocks on this emaxx are pretty weak...can't handle the big jumps. Also what weight oil and springs does everyone suggest? I jump it about 25 feet long and land from 8 feet in the air.
I've wanted to get that shock kit by progressive suspension...but its too much money for me . I can get the assocaited kit for like $50 with my swank employee discount .
Modena AL is offline
Old 03-17-2002 | 09:18 AM
  #81
Default Shocks
I'd look into something like the dynamite shocks made by losi, or maybe Integy. All are under $100. They are pretty nice with the fully threaded bodies.
t-d-motorsports is offline
Old 03-18-2002 | 06:55 AM
  #82
myclod's Avatar
The associated shocks are great, i have them on my T-MAXX but not too impressed with the springs provided, BUT you can go with firmer Assoc. Springs and should be just fine
myclod is offline
Old 03-19-2002 | 01:16 AM
  #83
AO's Avatar
AO
What engine is best for my shock t-maxx..
My Old engine has died..
AO is offline
Old 03-19-2002 | 03:44 AM
  #84
myclod's Avatar
LOTS of Engines to choose from...probably the best deal going right now is the Megatech .16 rated at 1HP for around $100 and a Guy came into the Shop i work PT in the other day and had a plain 'ol OS.15 CV (~.56hp) in his jerking the front tires off the ground for reliability go with the OS .15CV or .15CV-R (1.1hp) if the OS isn't in your budget go with the Megatech by all means, in either case you will see a huge improvement if the motor is properly tuned
myclod is offline
Old 03-20-2002 | 06:57 PM
  #85
pitbull racing's Avatar
Hi all
I just got my t-max and broke the motor in what temp should the stock motor run at for a back up bullet I bought a trinity picco 15
pitbull racing is offline
Old 03-21-2002 | 04:51 AM
  #86
myclod's Avatar
most Traxxas engines like to run in the 180-190 range now this is what i've seen recommended to many people, BUT here is the kicker....those temps are with Blue Thunder Fuel, if you are using Trinity (Which is a good fuel) the motor is going to run much cooler (i've seen as low as 145) and i have found that the Traxxas motors run better with the Traxxas or Blue Thunder fuel with a little heat in them.
myclod is offline
Old 04-12-2002 | 02:01 PM
  #87
Just got my proline suspension kit in! Can't wait to put it on. I'm going to wait until I can get some new shocks for it. I was thinking either the AE ones or the ones by Progressive Suspension. It will be running by the time school is out.
Old 04-24-2002 | 05:12 PM
  #88
If I were to get one of those trinity Monster motors would you recomend the wild or pro. I really wanna go fast but also have runtime to play with. Ill be running it with 3000 packs. So which ones do you think are better (does the pro go a lot faster or wild have a lot more run time)? Also do the reedy bad maxx run just as good as the trinity?
cantbestopped44 is offline
Old 04-27-2002 | 02:30 PM
  #89
pics of my race maxx
http://www.t-d-motorsports.com/Photo.../schwingel.htm
schwingel3 is offline
Old 04-27-2002 | 06:25 PM
  #90
Hello, I'm new to this site. Looks like a cool one.
I think some of the best shocks are these. If you wait, the pics will scroll. http://www.unlimitedengineering.com/shocks.shtml
They have awesome quality. They're heavy duty! Usually 1/8 scale shocks cost twice this much. They have tons of travel.
I put them on my truck. They are awesome! I tried AE shocks, then went to Progressive shocks. These OFNA shocks blow 'em both out of the water.
Here's some pics of my latest pride and joy. Don't let the cleanliness fool you. I love driving it in the dirt and eating up other maxxes on the race track.
http://www.printroom.com/_vti_bin/Vi...=50&courtesy=1
http://www.printroom.com/_vti_bin/Vi...=51&courtesy=1
http://www.printroom.com/_vti_bin/Vi...=52&courtesy=1
http://www.printroom.com/_vti_bin/Vi...=53&courtesy=1
Here's my list of mods.
OS RG 21 (ported by Jesse's Porting)
XTM extended chassis, braces
RB Novarossi 063 one piece pipe
Ultimate hobbies alum tranny case
XTM center steel CVDs
SuperMaxx ext steel CVDs
SuperMaxx ext stage III suspension
Boca bearings throughout
Dynamite alum. bulks
Dynamite alum bulk braces
Ballistic Stupidity front, rear, and center skid
Kahounas RC front and rear alum. bumpers.
SM/OFNA 1/8 scale shocks
Shock socks (not installed yet)
Airtronics 200oz steering servo
OFNA servo saver (until UE Gen 2 is in stock)
Dynamite alum. steering bellcranks
Futaba 3PDF tx and rx
Futaba S3003 throttle servo
SM 10mm FOC
RRP brake kit
RRP 72T slipper kit
Mugen 1/8 scale 3 shoe flywheel (in the mail)
Alum. Mugen shoes
Traxxas high stall spring
Steel Nitro Hawk clutch bell
Dynamite alum./foam air filter
Dynamite alum. rx and battery box
Dynamite alum. steering and throttle servo mounts
Blue/white LED head lights wired to 3rd channel on rx
SM Monster Wheels (BIO 3 style)
Giant Trac tires
RC Raven body posts and SS screw kit
Trinity aluminum body post braces
Color changing airbrushed Proline Silverado body
Thunder Tiger 175cc fuel tank
Stainless steel braided hoses
Dubro fuel filter
RC Trix aluminum diff cases
Megatech aluminum diff collars
Kippster cup and spiders in front
3mm modified RRP diff gears
3mm modified spool in the rear
Ballistic Batteries 6V 1600mA custom battery pack to fit in alum batt box
2theMaxx21 is offline
