Kyosho Mini-Z Series
#6541
12c is the body I’m currently using on the 5600. That would be the one I’d mostly likely change
#6544
Welcome to the world of Mini-Z!
- The body will impact the handling, but both those bodies handle pretty well. To make sure the difference is from the body, and not a chassis issue, why don't you swap bodies between chassis. If the handling moves with the body, its the body difference. If is stays with the chassis, it a chassis issue. Process of elimination.
- Stock knuckles break if you breath on them. I run the PN low downs on all my cars. Part MR3032
- The Kyosho lock nuts are some of the best in my opinion.
You’ll get a range of opinions.
I haven’t run the P1. Buy do run the Audi on multiple cars. I’ve mostly found bodies to be similar. So do better a not getting stuck to the side rails on contact.
No problems with the stock steering knuckles. Only broke a couple in two years between 6 RWD. I have moved to the aluminum steering blocs. More out of curiosity then need.
after trying both cars again. They are fairly similar. I think I was too excited to tried a new car that it felt better.
#6545
New guy here to ask more questions :'(
What's the recommended glue used for white bodies? Thanks
#6547
Thank you Raman
#6548
Are these LaFerraris European only release? I though Kyosho's agreement with Ferrari has been terminated a long time ago.
#6549
I guess that is the case. Kyosho european used to carry rwd models with lotus exige, Fwd with fiat 500 Abrath and an Old alfa model. I do wish they offer this beyond european market though.
#6551
Cheers,
Jim
#6552
I also need a new set of knuckles. I run a track of EVA mats, with fabric hockey tape on the seams. It stays fairly flat, but being on carpet, its not perfect. Does the PN low down knuckle change the front clearance much? Its like .5mm lower right? I was going to order a set, but worried I might start snagging the bumps or bottoming out.
#6553
