Kyosho Mini-Z Series
#6526
So long as the other necessary chassis holes to mount this piece are also not stripped this will be the quickest fix since your running 94mm only on that chassis.
the helicoil tool can fix any stripped hole on the chassis or top plate . In my experience if using MR-03 style front suspension it is essential to helicoil the two front clip holding holes on the chassis and use machined screws for a positively tightened screw...even a partially stripped hole which happens with less than 10 front clip swaps for different bodies ( coarse screws + soft plastic) in that area causes uneven front spring tension from right to left making the car never handle at its best.
I just have to say thanks for the tip on using Helicoils. The postman dropped off the kit on Saturday and I installed a couple this morning in the one chassis that was getting to the point of being close to unusable and they worked perfectly.
Thanks again.
Cheers,
Jim
#6528
PN makes upper arms but in 1 degree camber increments and caster can be adjusted via shimming on the aluminum tower bar however shims below and above knuckle also effect camber. Before switching to only AA arms the fastest set up in the club (PN home track) was 0 degree upper arms with 1mm shimm on top and .5mm shim on bottom of knuckle with tires trued anywhere from 22.8 good all the way down to 22.2ish ...most racers preferred shimming for the middle caster setting. With that in mind using new plastic caster arms .5 lower / 1mm upper shim should still be a very good starting point.
#6530
No matter which knuckle is used going for parallel to ground upper arms with least amount of droop is the sweet spot for best overall front suspension geometry.
I believe the stock plastic arms have 0 degrees of caster.
#6534
Ok, I'm fairly new to RC cars after not having one for >15 years. I have a few questions, that I hope some of you can help me out understand.
1. I bought 2 RWD cars, a Audi R8 LMS NBR 2010 and a McLaren P1 GTR. It seems like the Audi handles way better. At first I thought I was going insane, but after looking around on the net, it seems like it does in fact handle slightly better. Or is my mind playing tricks on me? If it is not playing tricks on me... do the other Audi R8 (2015/2016) models handles as well?
2. The front knuckles keep breaking on me?!?! doe these parts break that easy? on one, I was removing the knuckle and notice that the metal pin was also rotating when I was trying to remove the nut.. 2nd had the same problem when I tired to screw in the locknut... am I just bad at this? unlucky, or do they just break like crazy?
3. are the locknuts sold by Kyosho just plain m2 locknuts like the ones damn tried to link to McMaster but it won't let me...
thanks!
thanks!
#6535
thanks!
thanks!
- The body will impact the handling, but both those bodies handle pretty well. To make sure the difference is from the body, and not a chassis issue, why don't you swap bodies between chassis. If the handling moves with the body, its the body difference. If is stays with the chassis, it a chassis issue. Process of elimination.
- Stock knuckles break if you breath on them. I run the PN low downs on all my cars. Part MR3032
- The Kyosho lock nuts are some of the best in my opinion.
#6537
thanks!
thanks!
I haven’t run the P1. Buy do run the Audi on multiple cars. I’ve mostly found bodies to be similar. So do better a not getting stuck to the side rails on contact.
No problems with the stock steering knuckles. Only broke a couple in two years between 6 RWD. I have moved to the aluminum steering blocs. More out of curiosity then need.
#6538
Starting to wonder what the PN chassis would be like for one of my Evos.
