Kyosho Mini-Z Series
#6256
Just so everyone knows i recently like yesterday as of writing this that i purchased a dxr 3500kv sensored motor to use with my gl esc and quality control was horrible. There was a plastic shim inside the motor endbell that had to be removed because it was blocking the sensor from picking up the motor, also there was some of the glue residue on 1 of the sensors that had to be cleaned, on top of that it is clearly not certify as they say to working with the gl sensor or team powers board. If u have a gl esc stay with gl DO NOT BUY THIS MOTOR the sensor wires need to be flipper it to work properly from what i am being told by 2 different people 1 person being in Indonesia and another in the states. Do yourself a favor learn from me as i am now out 49 dollars for a paper weight. Might as well just kept my sensorless gl motor in the car
#6257
Well that sucks. Hope it was a fluke and you got a “Monday” motor.... Mine runs fine in sensorless mode in my glr. It’s not as smooth as my PN 3.1 though.
#6258
the whole point of a sensored motor and esc is to use the sensor part for better throttle feel not to cog and have boost and turbo mode. Thays the whole point of the purchase and from the main dxr people themselves they say its only certified to run with swave ensotech in sensored mode
#6259
#6260
Sorry to hear your motor doesn't work... why can't they just follow a standard pattern for making motors and speedos? There is no such aproblem for the 540 sensored motors. Only half a dozen manufacturers are making sensored motor for micro cars, I can't see why they have difficulty to agree on a single pattern for laying down the sen
#6261
#6263
#6264
i wish it was that easy when plugged in the motor ran backwards then when trying to go reverse it acted like it had a short. Idk if it is the wire backwards but i know for sure it was put together wrong because the llastic part was covering 1 of the phases so it would not pick up the rotor location. A new motor shouldn't have to be taken apart to diag whats wrong with it. Dont know if i just got a lemon but defently gave me a salty taste.
I totally agree that there should be a standard pinout standard for the sensor cable and power terminals on all motors of this scale. Motors should be interchangeable without needing to check any certification list of compatibility. I have a couple motors which I cannot use from XRX because no sensor cables from any of my ESC work with their plugs... Customers should never need to adjust sensor cable wiring to change their motors.
#6265
When you reversed direction, was this done by swapping wires or adjusting the rotation direction in the ESC settings?
#6267
Super stock
final
final
#6268
Stock class
evo4100
evo4100
#6269
Hello everyone... New to mini-z and RC in general. Super, super casual into this, just mostly having fun in the office with other car guys when we can't race our real cars.
I have a question about the radios.
I bought a Mr-03 Ve that came with an EX6 that was flashed to EX6R firmware. Cool.
I also bought a new RTR 32616BL (AWD GTR R33).
What do I need to do to either of the cars (I assume the R33) to make both cars work with the EX6/R?
I see that there is the red antenna, but unsure if that's what I need, or if I can even make it work with the R33 RTR kit.
Looking forward to having some fun!
