View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
OTHER NEW ARRIVALS!!!!!!!!!!!!
DYNAMITE TUNED PIPE SETS FOR 1/8- LOW END/MID/HI SPEED
DYNAMITE EXHAUST REBUILD KITS
DYNAMITE CHARGERS FOR NITRO AND LIPO
DYNAMITE IGNITERS
DYNAMITE FUEL BOTTLES - IN 3 SIZES!
DYNAMITE 5mm PINIONS
LOSI PARTS AND TIRES FOR ALL LOSI KITS - INCLUDING THE 8 and 8T 2.0
LOSI MICRO PARTS AND KITS
LOSI PARTS FOR MINI CRAWLERS
SPEKTRUM RADIOS and RECEIVERS
SPEKTRUM TX CASES
AND AT LONG LAST!!! BACK IN STOCK TRAXXAS PARTS!!!!!!!!!!!!
AND NEW XRAY PARTS TO BOOT!!!
DYNAMITE IGNITERS
SPEKTRUM TX CASES
Brand New in box Fun Cruiser Gasser Boat 30cc (made in USA)
Prather Products, Inc.
Prather Engine
Walbro carburetor
Fiber glass hull
Stainless rudder and fittings
47 inches length
14 inches width
Just add Tx-Rx, batt and its ready to run...
Php 43k REPRICED 30k
For faster transaction pls. text or call (09053286727)
Prather Engine
Walbro carburetor
Fiber glass hull
47 inches length
14 inches width
New ROCK CRAWLER ORDER basis
http://www.horizonhobby.com/Products...rodID=INTAFA01
Arriving soon!!!!
Imax B5 charger
Imax B6 charger
Imax B8 charger
S4315M 15.5kg torque servo
http://www.cyclonetoy.com/list_1.asp?id=1489
SM servo install in edge540 43cc
5A power supply
7.4V 3500mah 25C
7.4V/900mAH/15C
7.4V/ 850mAH/12C
www.cyclonetoy.com
www.cheapricequalityrc.zoomshare.com
Text or call 09158884491
http://media.hyperion.hk/dn/a123/123-brief.pdf
A123 Battery 2300mah 750.00 each now 20 pcs 14 pcs - 10pcs 6pcs in stock 2300mAh
video of Trex 500 A123 7S1P http://www.youtube.com/watch?v=rSFgh...eature=related
Shape : Bare Cell
Voltage : 3.3V
Max C-rate cont. : 30C
Max C-rate pulse : 60C
Dimension(mm) : L:70 * H:28
Weight : 70g
Limited items only all brand new
Heavy duty servo cable 300mm 130.00 ea.
http://www.cyclonetoy.com/list_1.asp?id=1216
Dynam 25amp Esc php 750.00
Heavy duty servo cable 600mm 180.00 ea.
http://www.cyclonetoy.com/list_1.asp?id=1218
Energy EC Power lipo Brand
11.1v 1,500mah 15c lipo 1,350.00 free shipping
http://www.cyclonetoy.com/list_1.asp?id=944
11.1V 1600mah 8C Gun-Type Transmitter for 3pk 1,450.00
http://www.cyclonetoy.com/list_1.asp?id=943
11.1v 2200mah 20c lipo 1,450.00 free shipping
http://i248.photobucket.com/albums/g...34016480-1.jpg
11.1V/2200mAH/ 12C 1'350 free shipping
http://www.cyclonetoy.com/list_1.asp?id=939
Regulator/Lipo Cutoff
(Lipo cutoff)LiPo Battery Protector for Car 950.00
stock 4 pcs in stock free shipping
Manual
http://www.hobbywing.com/english/Art...?ArticleID=402
Charger and Connectors
T plug connector 3 pcs set male and female 200.00
http://www.cyclonetoy.com/list_1.asp?id=131
Imax B6 Charger 3,150.00 4 2 pcs avail.
http://s248.photobucket.com/albums/g...current=b6.jpg
Imax b8 Charger with connectors and aluminum case SOLD OUR ARRIVING SOON
http://www.cyclonetoy.com/list_1.asp?id=1174
5A adaptor for Imax charger and other brand charger 750.00
http://www.cyclonetoy.com/list_1.asp?id=1213
Program card 650.00
http://www.cyclonetoy.com/list_1.asp?id=122
Servo
Tower pro 9G micro servo 350.00
http://www.cyclonetoy.com/list_1.asp?id=160
Hitec hs65MG 1,250 each in stock
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60° at no load
Operating Speed (6.0V): 0.11sec/60° at no load
Stall Torque (4.8V): 25 oz/in. (1.8kg.cm)
Stall Torque (6.0V): 31 oz/in. (2.2kg.cm)
SPE 43CC Gas Engine 10,500 in stock
http://www.cyclonetoy.com/list_1.asp?id=162
Hawk propeller brand (Wood)
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=21
23 x 8 c 880.00
22 x 8 850.00
20 x 8 c 850.00
20 x 10 c 840.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
10 x 4.7 electric prop. 150.00
8 x 4 E. propeller 150.00
http://www.cyclonetoy.com/list_1.asp?id=568
http://www.cyclonetoy.com/bookpic/20...1382918411.jpg
6v nimh 1500mah hump pack sold out
Igniter with battery and meter 750.00 1 unit avail.
http://www.cyclonetoy.com/list_1.asp?id=1157
Tower pro voltage monitor 450.00
http://www.cyclonetoy.com/list_1.asp?id=886
futaba 3pk module 75mhz php 1,000
Futaba 40mhz R149 DP Dual conversion 9 channels PCM receiver no crystal, 3,500.00 reprice 2.6k rush shipping included
Selling for a friend
Brandnew Super chipmunk 30 made in japan for 7,500reserve
spec.
for sale wood mainblade 325mm 2 set 1,100 for 2 set
Brandnew dynam rx 6 channel no crystal 72mhz 750.00
Telemetry Combo Pack 3,800
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
Overview
It’s a tool that no serious racer will want to do without – a tool that gives you the kind of information that helps you tweak your car for maximum performance. And it's all packaged in one convenient box.
If you’re a serious racer, you’re probably way ahead of us in figuring out Spektrum telemetry’s benefits. But we’ll list them nonetheless.
There are benefits like engine-saving feedback to help maximize performance while preventing costly failures and rebuilds. And the elimination of dumped Rx packs means no more crashes or DNFs due to battery failure in nitro-powered vehicles.
Besides that, Spektrum Telemetry’s lap timing helps you analyze the effectiveness of tire and gear selections, suspension tweaks, etc. Plus it backs up race organizers’ lap counting systems.
Add its rpm sensing to give you a handle on your car’s actual speed, plus the Quality of Signal feature to monitor RF link strength, and you’ve got the whole package.
engine head for savage .25 4,500
Tamiya Tnx clutch shoe 950.00
4 pcs 98% brandnew Proline 40 series Crime Fighter Tires
with 23mm hex and tools 3,950
98% brandnew Tamiya Super Modified Motor 11T 1,950 each 2pcs avail
for 1/10 car 950.00
GP nimh Battery 2pcs 950.00 all
Brandnew for tamiya TNX 1,450
Hpi Savage tire 2,700
Hot Bodies UFO Wheels
for the HPI Savage Truck. 2,550.00
BrandnewTeam losi AfterShock with integy upgrade parts 32,500 neg.
box and manual and spare stock parts
no electroni include
Arriving soon!!!!
Imax B5 charger
Imax B6 charger
Imax B8 charger
5A power supply
7.4V 3500mah 25C
7.4V/900mAH/15C
7.4V/ 850mAH/12C
www.cyclonetoy.com
Shape : Bare Cell
Voltage : 3.3V
Weight : 70g
Manual
Program card 650.00
Servo
23 x 8 c 880.00
22 x 8 850.00
20 x 8 c 850.00
20 x 10 c 840.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
spec.
Key Features
Overview
for 1/10 car 950.00
ot of bullet connectors brand nu consist of 13pcs female,9pcs male for...P500 sold sold
hvmaxx pro 6.5 use only for bashing esc has a defect but never thermalled, motor is in very good condition sintered rotor 5mm shaft w/ novak heatsink and 14t/32p 5mm bore pinion...P5k
futaba 3pk synthesized (no need of crystals) comes with box/manual, battery tray for lose batts, 1300mah battery pack, speedmind bag for...P7.5k fixed
or get the hvmaxx and 3pk for 11,5k...
if interested txt or call 09158774050....
emaxx2 with full hop ups sold
eagle charger sold
tower pro servo sold
novak 4cell lipo cut off sold
pinion 16t and 12t 32pitch sold
eagle charger sold
Dischargers Kayo Dyan!!!!
1) Novak Smart Tray 800 (Fixed)
- No hidden defects whatsoever
- In Good working condition
2) Much More CTX-D2 discharger 4.5K (Neg)
- like New
- mint condition
- With Bubble wrap
>>>> Eto Pa!!!! All for 4.5K only!!!!! Parang libre na yung Smart Tray
Items in Laguna with box, willing to meet in Manila on per schedule basis.
PM or Text 0917 534 6385, Pls state real name and rctech handle.
Thanks![/QUOTE]
- like New
- mint condition
- With Bubble wrap
Thanks![/QUOTE]
For Sale
1/10 scale wheels
26mm Proline Chrome wheels set(2 pairs) 500php
28mm BBS Chrome wheels for sponge tires set (2pairs) 500php
28mm BBS white wheels for sponge tires set (2pairs) 400php
32mm Chrome wheels for sponge tires set (2pairs) 500php
24mm BBS white wheels set (2pairs) 400phpadd 200get another any pair on tag item
24mm 6 spokes wheels set (2pairs) 400php
buyers handle the shipping
pm or txt 09239986059/09218031010
1/10 scale wheels
For Sale
Brand new Eagle Racing Ni-cd
GP 1600mah 900php
sanyo 1500mah 900php
buyers handle shipping
GP 1600mah 900php
Suspended
For Sale: Brand New Unlocked Blackberry 9000 Bold @ $310usd
a
Details
Item : HTC MAX 4G Smartphone Black / BlackBerry Bold 9000/Blackberry Storm Unlocked
Price :$300
Currency :USD
Condition : 10/10
Includes :Box and everything included in box.
web: (www.yvonneyeungstore.com)
SKYPE::jamesbrown55
MSN CHAT:Yvonneyeung06
Yahoo Chat:Yvonneyeung24
Selling Details
Contact: ( [email protected]/ [email protected])
Notes:Also in stock 3G phones
Samsung i900 omina/Apple iphone 3G 16gb/Nokia N96 16gb /HTC Touch HD / sony ericsson c905 cybershot /Blackberry storm and more.
Details
Price :$300
Currency :USD
Condition : 10/10
SKYPE::jamesbrown55
Selling Details
FS...
• Protoform DNA2 Body B/N
Exactly cut, no holes, unpainted, complete decals, wing hardware
Php 800
• Tamiya RZ with CO27 Armature used but in good condition
Comes with Trinity ball bearings
Php 500
• Tamiya Tyres used pero makapal pa, walang butas o punit
4pcs slicks, 4pcs high grip radials (SOLD)
Php 150 (slicks na lang)
• Tamiya 5 spoke rims good condition, minimal scratches
black color, 2pcs
Php 100
• TA05R Spool Pulley (unused/brandnew)
Php 150
Airflow
09162852677
Sta Mesa area
Php 800
Php 500
black color, 2pcs
Php 100
Php 150
Airflow
09162852677
Sta Mesa area
FOR SALE:
Tt01 convert to Tt01e- 2,3k
-rolling kit
-full ball bearings
-alum. shaft
-silvercan
-extra parts
Ta05 rolling kit- reserved to syrle_2k3
Novax GTX- 3k fixed
-no motor limit
-no reversed
Tamiya 23turns BZ- 700
Axion 23turns- 500
-with bearing
tt01 spur 55t & 58t 48pitch- 200 each
cyclone spur 96t 64pitch- 200
pinions- 150
18t 48pitch
22t 48pitch
23t 48pitch
24t 48 pitch
25t 48pitch
Cyclone S front 1way- 1k
HPI rc bag- 1k
HPI Mustang- 1k
-painted police car
RFS: quit
if interested call or txt
globe: 09062221764
sun: 09228959494
-rolling kit
-full ball bearings
-alum. shaft
-silvercan
-extra parts
Novax GTX- 3k fixed
-no motor limit
-no reversed
Axion 23turns- 500
-with bearing
pinions- 150
18t 48pitch
22t 48pitch
23t 48pitch
24t 48 pitch
25t 48pitch
HPI rc bag- 1k
HPI Mustang- 1k
-painted police car
RFS: quit
globe: 09062221764
sun: 09228959494
F.S
FOR SALE B.NEW PRO LINE CRIME FIGHTER FOR 1/8 BUGGY 1,8OO PESOS. FOR SALE LEVIN TRUENO BODY SHELL 800PESOS. 09283426421
FOR SALE! BRAND NEW!
ACME Racing 3Ch FM Transmitter w/ LCD display- B/new,40Mhz., 3 Channels, w/ Box. I'll look for the Manual. Unused talaga. RADIO ONLY no X-tals, receiver and servo. 1K lang. ( Open for swap with M03 parts. Alum dampers etc.)
CR01- B/new 3Racing Alum. Knuckle Arm 1.2K set,
B/new 3Racing Alum. threaded shocks set 1.5K.
AXIAL AX10- B/new 3Racing Alum. Y-Shape linkage connector 680 pesos
B/new 3Racing Alum. Steering link set 400 Pesos
B/new 3Racing Alum. angled linkage set w/ 8pcs. rod ends 1K.
Genuine B/new AXIAL PARTS!
Axial AX10 stock Chassis set- 800 pesos- a pair of B/new Anodized black aluminum chassis.
Axial AX10 stock Slipper clutch set- 1.2K W/ Spur gear! B/new taken from a B/new kit.
TOWER-PRO MG996R SERVO- (OUT OF STOCK) Upgraded version of the famous MG995. The MG996R has smoother operation due to a whole new PCB circuit, IC control so it CENTERS perfectly! Metal gears are further improved so it's more quiet. Perfect for 1/8 & 1/10 scale Cars,Buggy,Truggy, MT's. Safe for large scale plane application!
TOWER-PRO 9g Micro Servo – 350 pesos each - Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
HOBBY WING PROGRAM CARD - 850 pesos each
Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack (Now Available)
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
Mtroniks Viper ECO20- 2,000 each, (9 Pcs. Available)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g http://www.mtroniks.net/details1.asp/ProductID/170/lockit/true/Viper-Eco20.htm
IP6 Competition ESC- 7,300 (last piece)
B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies! http://www.mtroniks.net/details1.asp/ProductID/177/sid//IP6.htm
Mtroniks Genesis Pro (brushless esc)- 5,300 each,
B/N, Brushless 100A peak, 4-8cell NiMH, 2-4 Li-Po, Li-Po Safe w/ built-in 2,3,4S programmable voltage cut-off, intelligent start up, Adj. Punch, Timing, Rev. set-up and battery selection,(LAST UNIT)
http://www.mtroniks.net/details1.asp/ProductID/179/sid/4/Genesis-PRO.htm
Mtroniks Genesis Pro/ KEDA 5900Kv COMBO- 8,600 B/N 100A Peak ESC plus 36-50-06T brushless motor (540 Size) 5mm shaft.
Mtroniks Micro Failsafe- 1,400 each(OUT OF STOCK),
B/N, this new micro sized WATERPROOF failsafe is small enough to fit easily into those tight radio boxes or even just hang outside the box! It's waterproof after all!!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=Failsafe.jpg
Mtroniks ZGM (Zero Glitch Module)- 1,400 each,
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=zgm.jpg
Mtroniks Signal Booster-1,400 each,
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=signalboost-WP.jpg
Click here for product pictures:
Posting for my Brother: Used items for sale!
Tamiya TLT Chrome wheels and tires- 1.3K neg. set of 4 ( Rare )
Tamiya CR01 Vise Crawler tires- 1.2K neg. Seldom used. set of 4
I accept payments thru Bank Transfers or Credit cards via
Text or Call Stephen 0919-8888865 Pls. include your real name and RCTech username. Sorry No Trade unless specified! Meet up during Saturdays 7am-111am at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
tt01 - 4k
like brandnew. tinesting lang sa bahay
comes with:
full ball bearings
teu 101 esc
s3003 servo
stock motor
wheels and tires
aluminum heat sink
no body shell included
tamiya nismo body - 1.1k
uncut unpainted
no side mirrors
no wing
no decals and window mask
TLU01 led light set - 800php
brandnew
more than 2 sets available
tamiya aluminum heatsink - 250php
brandnew
tamiya plastic oil filled shocks - 400php
brandnew
1 set na lang available
TT01 metal outdrive dogbone set - 850php
brandnew
tamiya chrome wheel set - 400php
brandnew
tamiya super driftech tire set - 700php
brandnew
more than 5 sets available
tamiya receiver tamiya TRU-02 - 500php each
almost brandnew.
kinabit then inalis din after ma testing
yung pure black na lang
sport tuned motor - 700php
brandnew
pwede kabitan na wires kung gusto ng buyer
more than 5 pcs available
tamiya porsche carrera gt - 1.1k
brandnew
pre painted with decals
with sidemirrors
eto po yung link sa mga pictures..
http://s549.photobucket.com/albums/ii380/doki71/
text lang po mga interested at 09295688808
thanks
comes with:
full ball bearings
teu 101 esc
s3003 servo
stock motor
wheels and tires
aluminum heat sink
uncut unpainted
no side mirrors
no wing
brandnew
brandnew
brandnew
brandnew
brandnew
brandnew
almost brandnew.
brandnew
brandnew
with sidemirrors
thanks
