View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
HYPER 8
Hyper 8 w/ upgraded parts.
>carbon fiber servo tray
>rear shocks tower
no electronics and engine
5,500 pesos.SOLD!
sms or call, 0917 9606 101
http://s470.photobucket.com/albums/r...t=DSC00056.jpg
http://s470.photobucket.com/albums/r...t=PC210226.jpg
>rear shocks tower
5,500 pesos.SOLD!
B/NEW PANTHER PYTON TIRES ON REVO RIMS (4 pcs)- php4.5k
B/NEW GE POWER LIPO BATT (2 units) - php 3.5k ea
- 5000mah 25c 7.4v
B/new OS max21 VZB VSPEC engine - php12.5k
- w/ 21J carb, turbo plug, shim, restrictors
- ideal for 1/8 buggy kits
Used Bump start - php1.5k
-Model Top brand
- slightly used 12vdc
M8 radio 27MHZ FM MODULE only - php500
B/NEW TOWER PRO MG995 servo - php850 ea
- hi torque servo
- 2 units avail
Ride height gauge / camber gauge - php500 for both sold
Hongnor 0.12 nitro engine pullstart (2 units avail)- php2.8k ea
-removed from a b/new CRT 0.5 rtr kit
-can be used for 1/10 scale kit
-1 unit break-in condition / 1 unit racing condition
TRAXXAS EZ START - php1k
-used but in good working condition
TAMIYA TEU 101BK esc -php1k
USED EFRA 053 PIPE N MANIFOLD - php300
**(Items above can be swapped to any other item that might interest me,like big bore shocks for 1/8 buggy, power supply at least 12amps)
txt / call 0920-9093580. pls indicate username / name
POST FOR A FRIEND :
Contact jeffrey 09178409442
B/NEW Hyperion Charger (EOS0606i AC/DC) - php10k
- Multi-chemistry charger / Discharger system with integrated hyperion LBA balancer
- AC Input 100-240v / DC Input 11-15v
- Charge rates 0.1 - 6.0A
- Supported Cell types
* Lipo : 1-6s (3.7-22.2v)
* LifePO4 : 1-6s (3.3-19.8v)
* Nicd/Nimh : 1-14cells
* Lead acid : 1-6cells
- multiadapter (2-6s) included
- AC power cord included
B/NEW GT Power A6 Charger - php5k
- Intelligent digital mutifunctional balance charger / discharger
- Input voltage : 10-18v
- charge current range 0.1-5.0A
- Discharge current range 0.1-1.0A
- Nicd/Nimh 1-15cells
- LiIon/Lipo/Life 1-6 series
- Pb battery voltage 2-20v
- USB cable w/ CD software
- Charging lead connectors
Contact kim 09178927243
B/NEW ARROW SHARK FLYING DRAGON GAS BOAT - php36k
-Semi rtr (still sealed in box)
-JZ 260M unleaded gas engine pullstart
-steel tuned pipe
-complete hardwares like trim tabs,turn pins, rudder, strut
-3/16 x 478 propeller
-no electronics (need to install servos,receiver, batts, radio)
-w/ manual, boat stand
- pictures below is the same as the one for sale except the cover is blue.
- 5000mah 25c 7.4v
-Model Top brand
- hi torque servo
- 2 units avail
POST FOR A FRIEND :
-steel tuned pipe
for sale
xray t1r. rolling chassis w/ mazda6 and AE86 trueno body shell (both painted), HPI T1 Drift tires mounted on a HPI work meister rims (3mm and 6mm offset), Take off 32r tires mounted on a speedmind dish rims, HPI body posts.
No electronics. with spur gear but no pinion gear.
asking is Php7500(neg)
09228271641 - Jeff
QC area.
09228271641 - Jeff
QC area.
CHECK THESE PRICES !
Anyone interested to order starting Dec. 11 to Dec 23 pls visit our website
www.cyclonetoy.com
www.cheapricequalityrc.zoomshare.com
New airplane
Gasoline Airplane ARF >> Pitts Python 50cc ARF
http://www.cyclonetoy.com/list_1.asp?id=1529
Wing span: 1780mm
Fuselage length: 1600mm
Weight: 3800 G (not include engine and radio)
Wing area: 105 D㎡
Engine:45-60cc gas
Radio:4CH/6S
PU wheels\Anodized Alu Landing gear\C.F tube\ Alu long arms
Item must be in pull payment when you order
free shipping to visayas and mindanao
All parts are avail.
Item No.: 00450-E Super 3D 450 Flasher same as trex 450 v2 8,900.00
http://www.cyclonetoy.com/list_1.asp?id=1415
Item No.: 00500-A 500 Gfcpe Helicopter-same as trex 500 16,250.00
http://www.cyclonetoy.com/list_1.asp?id=1417
Item No.: 00500-B 500 Super Pro 3D Helicopter 19,800.00
http://www.cyclonetoy.com/list_1.asp?id=1418
Item No.: 00450-D 450 Flasher PE 3D-same as trex 450 v2 kit only 6,800 php
Item No.: 00450-D 450 Flasher PE 3D-same as trex 450 v2 10,900 php
free 1 set metal head and 1 set metal tail parts
include: brushless motor and 30amp hobbywing esc
http://www.cyclonetoy.com/list_1.asp?id=1414
Item No.: 00450-RTF 450 RTF Helicopter(Update version) 16,950
http://www.cyclonetoy.com/list_1.asp?id=1416
Christmas Sale up to Jan 5
Item in stock pls check the links
For inquire text or call 09158884491
landline o45 8660458 look for alvin[/SIZE][/COLOR]
www.cheapricequalityrc.zoomshare.com check our website we have a sale item for inquire send me the item number thanks
Instock item
SPE 43CC Gas Engine in stock 10,500 instock
DL50,DA50 tune pipe IN Stock 3,550.00
Imax B6 charger with aluminum case 3,550.00 free shippinginstock on sale
ARF Model 28% EDGE540 40CC in stock 16,500 airplane only
Wing Span : 76in(1930mm)
Length : 71in(1800mm)
Wing Area : 1147sq in(74sq dm)
Flying Weight : 11.4-12.8lbs(5200-5800g)
Engine : 32-48cc gas
In stock wood proppeler
prop 20x8 850.00 in stock
prop 18x8 650.00 in stock
17x6 propeller 580.00 in stock
prop 16x8 580.00 in stock
16x6 propeller 550.00 in stock
Hitec HS-5245 MG Digital
Dimensions (mm): 17.0 x 32.0 x 31.0
Weight (grams): 32.0
Speed (sec): 0.15
Torque (Kg.cm): 4.40
Ball Raced: Yes
Hitec 645MG 1,300 each 2 pcs in stock
SPECS: Speed: 0.24 sec/60° at 4.8V
0.20 sec/60° at 6.0V
Torque: 106.93 oz-in at 4.8V (7.7 kg-cm)
133.31 oz-in at 6.0V (9.6 kg-cm)
Length: 1.59" (40.6mm)
Width: 0.77" (19.8mm)
Height: 1.48" (37.8mm)
Weight: 2.11oz (60g)
Hitec hs65MG instock 1,300 each 2 pcs in stock
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60° at no load
Operating Speed (6.0V): 0.11sec/60° at no load
Stall Torque (4.8V): 25 oz/in. (1.8kg.cm)
Stall Torque (6.0V): 31 oz/in. (2.2kg.cm)
MG995 metal gear 13KG large torque 750.00 php
Connector wire length:320mm
Specifications:
Weight:55.2g
Operating speed:0.24sec/60degree(6.0V)
Stall torque:13.0kg/cm or 180oz/in(6.0V)
Temperature Range:-20 degree to 60 degree
Dead band width:4ms
Operating Voltage:4.8V~7.2V
HITEC 7955TG 3,500 in stock
Specs:
# Torque: 333 Oz/In @ 6V
# Speed: 0.15/Sec @ 6V
# Dimensions: 1.57 x 0.78 x 1.45 in
# Weight: 2.29 Oz
LIPO
Energy e.c power Brand
Igniter with battery and meter 800.00 php 2 pcs avail.
Tower pro voltage monitor 450.00
UBEC-5A-HV (High Voltage) 1,350.00 Sale Sale
http://www.cyclonetoy.com/list_1.asp?id=1209
INDICATOR 1,450.00 1 unit in stock
1. 4.8-6.0V power regulator is suitable for many different model engines
2. Ignition will remain 20 seconds automatically
3. Pulse transfer system, low current, low dissipation
4. Glow connector design is easy to fixed ignition
5. Compact and Portable (30g)
(Lipo cutoff)LiPo Battery Protector for Car 1,100.00
stock 7 pcs in stock free shipping
Manual
http://www.hobbywing.com/english/Art...?ArticleID=402
Basetech thermometer made in france 1,450.00
http://s248.photobucket.com/albums/g...basetech-1.jpg
For sale brandnew Storm Pro CL-1, Red RTR 21,000 neg or trade to .50 size nitro helicopter rtf
http://www.horizonhobby.com/Products...dID=GSC3002APT
Key Features
* Fully assembled
* GS B03 pull-start engine and tuned pipe
* Prepainted and decaled body
* Oil-filled racing shocks and carbon fiber radio tray
* T6 7075 hard-coated 3mm chassis[/SIZE][/COLOR]
www.cyclonetoy.com
New airplane
Wing span: 1780mm
Wing area: 105 D㎡
Engine:45-60cc gas
Radio:4CH/6S
Instock item
Speed (sec): 0.15
Ball Raced: Yes
Specifications:
Weight:55.2g
Dead band width:4ms
Specs:
# Weight: 2.29 Oz
LIPO
Manual
Key Features
* Fully assembled
3pk Black
HRS rx
75mhz
Top bag
P7,500.00
09209623803
HRS rx
75mhz
Top bag
P7,500.00
09209623803
charger needed
looking for imax b5 charger , ung good conditon pa, budget is 1.8k to 2.5k
txt me . 09052198844
For Sale
TRF 416 kit only with box & manual = 16k ; free shipping
http://i296.photobucket.com/albums/m...6/DSC06841.jpg
http://i296.photobucket.com/albums/m...6/DSC06842.jpg
http://i296.photobucket.com/albums/m...6/DSC06843.jpg
http://i296.photobucket.com/albums/m...6/DSC06844.jpg
http://i296.photobucket.com/albums/m...6/DSC06845.jpg
http://i296.photobucket.com/albums/m...6/DSC06846.jpg
http://i296.photobucket.com/albums/m...6/DSC06847.jpg
Call or text 09294775910.
FOR SALE
Team Associated TC4 Team Kit
* Newly Rebuilt
* With Dish Rims/Slick Tires (ING brand)
* With Motor
* no electronics
* http://www.rc10.com/ae/tc4/tc4_home.htm
-5k slightly neg
Rayspeed Discharger/Balancer/Conditioner
-with box
-single fan
-800
HPI Rally Tires
-soft compound
-almost new
-800
For pics of items:
http://kebskaploosh.multiply.com/pho...tuff_for_Sale#
LOOKING FOR:
Parts for my Yokomo BD:
-Shock Bushings (8pcs)
-Rear Body Posts
-Yokomo Progressive Springs (Blue Dot)
-Main Chassis Plate
-99t 64pitch spur
-Orion 3800 LiPo
Text or pm me
09279752136
thanks
kevin
* Newly Rebuilt
* With Motor
* no electronics
-5k slightly neg
-with box
-single fan
-800
HPI Rally Tires
-soft compound
-almost new
-800
For pics of items:
LOOKING FOR:
-Rear Body Posts
-Main Chassis Plate
-99t 64pitch spur
-Orion 3800 LiPo
Text or pm me
09279752136
thanks
kevin
for sale or trade in
yokomo 15 turns- 600 (brush almost new)
yokomo 19 turns- 600
kunin mu 2 motors bigay ko 1k with free 16 turns (hindi ko lam brand)
lahat yan gud condition
09062221764
09062221764
Pamaskong Handog sa Batang Pinoy
M03 Aluminum Front Knuckle Arms - 1200
- Only Used for Fitting sa TA03.
http://i370.photobucket.com/albums/o...Knucklearm.jpg
TLP Expro II Fuzzy Logic Charger/Dishcharger- 2000
- For Nimh and NiCd. AC/DC input.
- Acquired last September. Home use lang. Complete with box and Manual.
http://i370.photobucket.com/albums/o...drift/TLP2.jpg
http://i370.photobucket.com/albums/o...drift/TLP1.jpg
Or get all for Php 3000 only. Thanks RCTech.
LF: TA03 Aluminum Knuckle Arms, TA03 Universal Dogbones.
Call or Text for faster transaction and to arrange meet ups.
09158501319 - Dior
Merry Christmas!!!
09158501319 - Dior
Merry Christmas!!!
Holiday update
FOR SALE
bnew Novak 27mhz synthesized reciever 2k reserved
eagel racing zapper 4k
eagle racing dynometer 4k reserved
txt 09218031010
txt 09218031010
