View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
looking for:
Hyper st pro bodyshell(used or brandew basta ok pa)
High torque servo perfect for truggy(steering)
For sale:
Duratraxx intellipeak pulse charger(110volts)-1.2k
1 set panther komodo dragonII buggy wheels and tires(99% thread)-1.3k fixed
used futaba s9402 servo-1.5k fixed
hobao center universals-1.2k fixed
for inquiries pls text me @09215209614-vince
For sale:
brand new novak smart stop 4s lipo cut-off....P1,3k reserved
2pcs east power 4200 batt good numbers... P850 (1pc left) reserved
almost new tower pro mg995 metal servo... P700 (sold)
very good condition emaxx2 kit use only for bashing...
..... includes the ff hop ups
................proline powerstroke with bypass shocks with xtra springs and piston
................rpm f/r bumpers
................rpm f/r shocktowers and body post
................rpm front A-arms
................rpm rear tru track arms
................rpm knuckles
................rpm f/c/r skid plates
................rpm f/r bulkhead braces
................t6 alum integy heavy duty typeII f/r bulkhead
ill include new stock emaxx f/r shocktowers and body post, t6 alum f/r bulkhead braces,set of traxxas hinge pins, pillow balls, bottle of shock oil, 2bottls of diff oil, box with manual,traxxas hardware tools and all emaxx parts that i can find...P18k
..........for inquiries txt or call 09158774050
LAST POSTED ON PAGE 197
FOR SALE! BRAND NEW!
3Racing assorted Aluminum hop-up parts for Axial AX10 and Tamiya CR01.
CR01- Knuckle Arm, Alum. threaded shocks.
AXIAL AX10- Y-Shape linkage connector(RESERVED), Steering link set,angled linkage set.
Genuine B/new AXIAL PARTS!
AX10 Chassis set- 800 pesos- a pair of brand new Anodized black aluminum chassis.
AX10 Slipper clutch set- 1.2K W/ Spur gear! Brand new taken from a B/new kit.
LIPO PACK 3,500 each w/ dean plugs-7.4V 4800mah 25C. 120Amps nominal discharge. (last piece)
TOWER-PRO MG996R SERVO- 1.2K (3pcs. left) Upgraded version of the famous MG995. The MG996R has smoother operation due to a whole new PCB circuit, IC control so it CENTERS perfectly! Metal gears are further improved so it's more quiet. Perfect for 1/8 & 1/10 scale Cars,Buggy,Truggy, MT's. Safe for large scale plane application!
TOWER-PRO 9g Micro Servo – 350 pesos each - Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
HOBBY WING PROGRAM CARD - 850 pesos each
Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack (OUT OF STOCK)
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
Mtroniks Viper ECO20- 2,000 each, (9 Pcs. Available)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g http://www.mtroniks.net/details1.asp/ProductID/170/lockit/true/Viper-Eco20.htm
IP6 Sport (Competition ESC) - 5,500 each,
B/N, Waterproof, 10T limit,Rated 350A continuous, peak 1,500Amps, Fully programmable punch, Drive Frequency 1.5KHz to 11.0KHz, Drive curve & brakes, 4.8-8.4V,4A Hyper BEC. http://www.mtroniks.net/details1.asp/ProductID/176/sid//IP6-sport.htm
IP6 Competition ESC- 7,300 each,
B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies! http://www.mtroniks.net/details1.asp/ProductID/177/sid//IP6.htm
Mtroniks Genesis Brushless
Mtroniks Genesis Pro- 5,300 each,
B/N, Brushless 100A peak, 4-8cell NiMH, 2-4 Li-Po, Li-Po Safe w/ built-in 2,3,4S programmable voltage cut-off, intelligent start up, Adj. Punch, Timing, Rev. set-up and battery selection,(LAST UNIT)
http://www.mtroniks.net/details1.asp/ProductID/179/sid/4/Genesis-PRO.htm
Mtroniks Genesis Pro/ KEDA 5900Kv COMBO- 8,600 B/N 100A Peak ESC plus 36-50-06T brushless motor (540 Size) 5mm shaft.
Mtroniks Radio Equipment:
1. Mtroniks Micro Failsafe- 1,400 each(LAST UNIT),
B/N, this new micro sized WATERPROOF failsafe is small enough to fit easily into those tight radio boxes or even just hang outside the box! It's waterproof after all!!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=Failsafe.jpg
2. Mtroniks ZGM (Zero Glitch Module)- 1,400 each,
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=zgm.jpg
3. Mtroniks Signal Booster-1,400 each,
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=signalboost-WP.jpg
Click here for product pictures:
Posting for my Brother: Used items for sale!
Novak GTX- 3K neg. NO MOTOR LIMIT, Forward/Brake only, 1 heatsink fin was cut-off to fit water cooling tube for marine use. but the esc works perfectly.
Tamiya TLT Chrome wheels and tires- 1.3K neg. set of 4 ( Rare )
Tamiya CR01 Vise Crawler tires- 1.2K neg. Seldom used. set of 4
I accept payments thru Bank Transfer or
Text or Call Stephen 0919-8888865 Sorry No Trade! Pls. Include RCTech Username Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
spool adaptor
SPOOL ADAPTOR (4 red / 1 blue)
http://www.philippinercdrifters.org/...showtopic=1873
txt kagad for fast transaction
09109665398
09109665398
UP for grabs
FOR SALE OR TRADE
Hi Tec Lynx 75mhz AM tx & futaba rx
- in good working condition
- with xtals
- no glitch or what so ever
- 2k firm repirced to 1.5k
features
EPA
throttle and steering reverse option
throttle and steering trim
3 lead light system power indicator
RFS:xtra controlle
will trade this controller to any 4 channel stick type tx and rx
item is in cebu buyer handles the shipping
09298301713
FOR SALE OR TRADE
- with xtals
features
EPA
RFS:xtra controlle
09298301713
LF
got one na
lipo for sale
hi selling my bnew Rhino Lipo batt
3s 11.1v 20c 2350mah or 3 cell lipo at 11.1 volts with a discharge rate of 20c continuous and 30c burst and has a capacity of 2350mah.
dimensions: 134x16x43mm weight: 205g
selling for 2k
09192321255
selling for 2k
09192321255
FOR SALE:
1. YOKOMO MR4BX 4WD OFF ROAD BUGGY: 8,000 PESOS ONLY
Excellent condition! Seldom Used!
Nothing to Hop Up!
With set of Tires and Body!
With spares worth about 5000 pesos!
No electronics.
2. Team Associated RC12L3: 2,500 only
No Electronics
CALL/TEXT 0917-5279037 RON
Nothing to Hop Up!
No electronics.
No Electronics
For Sale Team Associated RC10T4 Race Spec RTR
4 months old, used for a few times at QC Circle Racetrack practice run only, never used in a race, and never used on-road bashing, tires are very fresh, and sariwa pa tong unit.
Blue Aluminum shock bodies
Associated Dogbone rear axles
Painted body
Associated racing tires
RPM bumper
RPM gear cover
Associated transmission
Associated S1903 MG Servo
LRP A1 Automatic speed control (13T limit)
Reedy Radon 17-turn motor
Associated XP2 radio
Associated receiver
Dean's plug connector
Full ball bearing
Box and manual included.
Price : 10K
Unit is at Cubao, QC near Araneta Center
0917 800 6073 look for GT
Painted body
RPM bumper
RPM gear cover
Associated receiver
Full ball bearing
Price : 10K
TAMIYA F-350 FOR SALE....RTR PRICE LOWERED TO 16K
TAMIYA F-350 HI LIFT WITH RADIO AND ELECTRONICS..PRICE LOWERED TO 16K RTR NA FREE SHIPPING...
(0920) 981-6868
(0920) 981-6868
