Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 01-24-2010, 10:50 PM
  #51931
team dogbone's Avatar
AVAILABLE @
DOGBONE HOBBY SHOP
722-6180
hyper 9 electric P21,000.00
hyper 10 SHORT COURSE P15,500.00
team dogbone is offline
Old 01-24-2010, 11:19 PM
  #51932
denish's Avatar
Default for sale-sanwa dash saber 2 ch stick type radio
sanwa 1301 servo-1pc
sanwa AM SRD-2122RS BEC receiver
1.5k
09228811623
denish is offline
Old 01-24-2010, 11:47 PM
  #51933
zilam's Avatar
Originally Posted by zilam
bka po meron kayo dyan di na ginagamit na igniter w/ charger bilin ko nlng po....
tnx
up
zilam is offline
Old 01-25-2010, 01:21 AM
  #51934
AVAILABLE @
DOGBONE HOBBY SHOP
722-6180
Old 01-25-2010, 02:28 AM
  #51935
oro27's Avatar
Trader Rating: 33 (100%+)
Attached Thumbnails The Big Locked Thread-pics-1473-.jpg   The Big Locked Thread-pics-1474-.jpg   The Big Locked Thread-pics-1475-.jpg   The Big Locked Thread-pics-1476-.jpg
oro27 is offline
Old 01-25-2010, 02:33 AM
  #51936
tagasagwan's Avatar
Trader Rating: 58 (100%+)
Default LAST POSTED ON PAGE 957
last posted on page 957(skipped more than the minimum 2 PAGES!!! )
3Racing
Alum. Knuckle Arm for Tamiya CR01 crawler B/new 1.2K set (2sets available) (Open For Swap)
TURNIGY BRUSHLESS MOTOR
2435 4,400KV - Bnew 1.5K only (Open For Swap)
Motor Size: 2435 (370S), Speed: 4400kv, ESC Required: 18A-30A, Voltage Range: 6~12v, No Load Curr: 1.2A, Max Load: 26A, Diameter: 24.2mm, Length: 37mm, Front Mounting Hole Distance: 16mm, Front Mount Thread Size: M3, Shaft Diameter:2mm, Shaft Length: 12mm, Weight: 72grams
KEDA BRUSHLESS (540size)MOTOR
5,900KV Bnew 3.5K only (Open For Swap)
Dimensions: 36~50mm
Front mount holes are 25mm apart.
Shaft size: 5mm
Weight: 220g
Turns: 6
Spec.
Kv: 5900rpm/V
Idle Current: 6.9A
Resistance: .0034
Max Amp: 108A
Mtroniks Viper ECO20- 2,000 each, (6 Pcs. Available)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g
IP6 Competition ESC- 7,300 (last piece)
B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies!
Mtroniks ZGM (Zero Glitch Module)- 1,400 each
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm
Mtroniks Signal Booster-1,400 each
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
HOBBY WING PROGRAM CARD
- 850 pesos each
Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors 3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
EC3 Connectors- 100 Pesos/Pair
Pack contains 2 female & 2 male 3.5mm bullet connectors, 1 male & 1 female plastic casings (blue)
PLEASE CLICK HERE TO SEE COMPLETE PRODUCT INFO & PICS!
I accept payments via Bank Transfers ( BPI & Chinabank), SMART Money/Padala or Credit cards via
Text or Call Stephen 0919-8888865 or 0932-6783188 Pls. include your real name and RCTech username. Sorry No Trade unless specified! Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators
tagasagwan is offline
Old 01-25-2010, 03:05 AM
  #51937
Originally Posted by oro27
For Sale Or Trade with another rc stuff
Team Losi XXX ke buggy 2.3k only
Call or text me @ 09162100627 / 09228450727
i'll take it.
text sent.
-Jon
Ganjie is offline
Old 01-25-2010, 04:29 AM
  #51938
skavenjero's Avatar
Trader Rating: 34 (100%+)
Default SELL THIS ITEMS TO ME! ASAP.. hehe!
Ialok nyo na sakin ang mga items na ito :
M11 Tx bag (speedmind or etc)
Tamiya TB03 center one way.
PM or text or call me at 0906-3317633
Jero A.
skavenjero is offline
Old 01-25-2010, 05:27 AM
  #51939
Default sari-sari
1. Aluminum Suspension Block
for cyclone, pro d & pro4
-P200
-available in black (2pcs) & no color (1pc)
2. Aluminum Body Post
-P350 per pair
-available in black(3 pairs) & blue(2 pairs)
3. Aluminum Bumper Post (left)
-P250 per pair
-1 pair left (no color)
4. Aluminum Servo Holder L-type (middle)
for CF type Chassis (with screws & nuts)
-P250 per pair
-available in black (1 pair), blue (1 pair), red (1 pair) & no color (1 pair)
5. Aluminum Servo Holder (tall type)
for TA03 & M03 chassis
-P800 per pair (anodized in shiny type finish)
- 1 pair left
6. Aluminum Servo Holder (low profile type)
for CF type Chassis (no screws)
P350 per pair
-2 pairs available (in black & blue)
7. hpi wheels (with grip tires)
P350 set
-no color pero ready for paint
-6mm offset
8. Tamiya 23T Motor (BZ)
-P300
-in good condition & never use mula ng kunin ko kay Granmasteralok
-need new brush pero pede pang tumakbo
09109665398 (text kagad para mabilis)
meet me sa Robinson Ortigas after 6pm (Monday to Fri)
miltot is offline
Old 01-25-2010, 05:42 AM
  #51940
bentoy101's Avatar
Trader Rating: 74 (99%+)
Default For Sale!!
1) 2 pcs EP4200mah Nimh BATTERY 1,050php each HALF TAYO SA SHIPPING :-)
Very very fresh and good condition.extra batts lang..4200mahplus charging pa..good numbers pa :-)
1) 2 set TAMIYA SLICK TIRES 350 php only each set
1 time used only switch to drift tires..
2) BNEW TT01 kit W/ COMPLETE ELECTRONICS!!4,500 only NEG 4,0000 php nalang!! on hold
see the pics..you get what you see..FREE touring wheels and rims!!!BNEW TALAGA!!!BODY AT TX NALANG KULANG Ready to RUN na!!!display kit lang..
3) LRP PULSAR COMPETITION CHARGER AWARDEE CHARGER!!1,500php only!1000 nalang!!500 nalang!!!
charger,discharger matching motor break in upto 8amps!!1-8cell nicd nimh
ONLY NEEDS IC REGULATOR part number P40NFO to go :-)
4) Waterproof Traxxas Xl-5 esc and Titan 12 TURN motor!!!! 3,500 php only!!NEG! 3,200 until Jan 27 only!!
VERY FAST Combo!!ALMOST NEW!!twice used only!!extra po..not in use na!!
XL-5™ Waterproof FWD/REV ESC
• Innovative watersealed design
• 12-turn motor limit for 550 size motors
• 15-turn motor limit for 540 size motors
• Input Voltage: 4.8 to 9.6 volts can be 2s lipo
• Three drive profiles 100% forward and backward,50% power for begginers, reverse lock out for racing!!
• Forward / Reverse / Brake
• EZ-Set® push-button setup
• Thermal shutdown protection
* The Titan 12T is a 12-turn 550 size fan-cooled modified motor.
5) Non Waterproof Traxxas Xl-5 esc and Titan 12 TURN motor!! 3,200 only!!!NEG!3,000 nalang!!!!
VERY FAST again!!! ALMOST NEW.!! TWICE usedextra lang not in use na..
XL-5™ FWD/REV ESC
RFS Too many Kits already. . . :-)
Text/call me 09235753444 david :-) or pm me..thanks rctech!! :-)
I can ship if needed...:-) Thank you and Godbless:-)
Attached Thumbnails The Big Locked Thread-blue-xl5.jpg   The Big Locked Thread-ep-batt.jpg   The Big Locked Thread-titan.jpg   The Big Locked Thread-yellow-xl5.jpg
bentoy101 is offline
Old 01-25-2010, 06:14 AM
  #51941
jay061788's Avatar
-P300
meet me sa Robinson Ortigas after 6pm (Monday to Fri)[/QUOTE]
sir intrested ako sa bz nyo pero panu yung brush nya?san ako kukuha nun??
jay061788 is offline
Old 01-25-2010, 06:21 AM
  #51942
Default looking for
need 2.4 ghz m11x receiver and servos for the throttle and steering of my nitro 1/10 kit...anyone selling?
anyone needs esc? selling nosram pearl esc previously posted with pics.
call/text 09209180395
jonp is offline
Old 01-25-2010, 06:37 AM
  #51943
mikelouie8's Avatar
Trader Rating: 38 (100%+)
-P300
sir intrested ako sa bz nyo pero panu yung brush nya?san ako kukuha nun??[/QUOTE]
sir ang brushes meron po sa lils and the price range po ata from 200 to 300 lng per pair. dapat po dala nyo sample para di mag kamali, kc dalawa po ang type nung brushes isang nakahiga at isang nakatayo.
HTH
mikelouie8 is offline
Old 01-25-2010, 07:32 AM
  #51944
jay061788's Avatar
HTH[/QUOTE]
cge po sir ill keep in touch
hahanap muna ako brushes
Old 01-25-2010, 08:50 AM
  #51945
balikrc's Avatar
Revo Starter Box w/ 2 packs Nimh battery- must buy with the revo non pull
P3K ----------------------------------- sold!!
CRT 0.5
extended chassis
rolling Chassis
P7k
RC10GT with aluminum chassis,
RB engine and aluminum tuned pipe.
Stock servos, no Tx and Rx.
Reciever 5 cell battery
complete with box and manual.
Serpent starter box with 2 Nimh battery
P7K
Futaba Mini Servo S3002, 2Pcs
Futaba 9402, 2pcs
KO PROPO 2144 Digital Servo 1 pc
SMS only +639178927243 or +639228154402
balikrc is offline
