View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Backslash: txt or call me i have the items you're looking for 09178251298 - Jon
Sir Miles: last i asked out of stock daw, hopefully meron na ulit.tanx
FOR SALE:
1. LST Tires for sale - P1,300.00
2. XRAY FK 05 Rolling chassis, 95% ti screws, no scratches on chasis, alu shock body, optional bat holder, roll bars, extra ball bearings, with box, manual. - P5,000.00
3. MIP 2 in 1 clutch kit, with flywheel and spare clutch shoes. - P800.00
4. buggy tires with rims - P1,000.00
5. hpi savage .28 engine mount - P300.00
txt or call 09178251298
FOR SALE:
For Sale:
HPI Pro4 super fresh with loads of hop ups. Super well maintained
Ko Propo VFS-1 Hara Twister 2.0 - almost new. Very fresh.
Pro4 included Hop-Ups are:
HPI Carbon Fiber Main Shaft drive,
HPI Aluminum Servo mounts with Transponder Holder (2005),
HPI Aluminum Heatsink Motor Mount (2005),
HPI Aluminum Bevel Gears (2005),
HPI Aluminum One-way Gear Brace (2005),
HPI Carbon Fiber Body Post holder (front & rear),
HPI Carbon Fiber Camber Plates (2005),
HPI Delrin Outdrives (2005),
HPI Aluminum Spring holders,
Jet Racing Aluminum C-Hubs 4 degrees,
Jet Racing Carbon Fiber Bumper Plate,
Speedmind Motor plate Spacer, Servo
PLUS...
-Dozens of spare parts
-Free batts
-Tools
-23T motors - Flat Out (1 cut only), Tectro (1 cut only)
-4 set of tires (1 set new)
-Bodies
-plus lots more...
also included:
Custom made power strip with voltage read-out
Must be sold as package. All must go.
Package only for 10K
Interested parties, text or call me thru 0917-9479747
-Angelo
PLUS...
-Free batts
-Tools
-Bodies
-plus lots more...
also included:
-Angelo
Well Maintained Savage 25
For Sale, Well Maintained Savage 25 - 18K neg
HPI savage 25 without electronics
Hop-ups:
Alloy Differential Case
silicon filled differentials
4 bevel gear upgrade
cam type servo saver
modified throttle and brake linkages
nylon roll cage
hot bodies tuned pipe
high flow air filter
hardened dog bones
18tooth clutch bell
aluminum clutch
adjustable upper arms
orange and purple springs
primerless fuel tank
Includes:
extra arms
extra upper arms
extra fuel tank
extra body (used for display only)
txt me 0917 856 1314
Hop-ups:
nylon roll cage
hardened dog bones
18tooth clutch bell
aluminum clutch
Includes:
extra arms
extra upper arms
extra fuel tank
pitbull
for sale
pitbull charger...
needs 12v power supply....
good condition
with manual
with power supply(from a personal computer)
3,500php(fix)
pm me for pictures
09287038636
luk for bryan
pitbull charger...
good condition
with manual
3,500php(fix)
pm me for pictures
09287038636
luk for bryan
Sirio .27 Big Block Race Engine
-Comes W/ HPI rotostart 2 & Back Plate included almost new fresh
- new Connecting rod
- new Crankshaft
- Very Strong Compression
- Good For Off Road
7.5K w Roto 2 / Engine Only 5.5k
Novarossi Tuned Pipe for .12
-for 5 Port
-for Rear Exhaust
-W/ Manifold
1.6k
Sanwa RF Module
-TM-201CW
-Brand New
-40 MHz.
1.5K
Looking For;
Sanwa 40 Mhz. Crystal RX & TX Any Value
SANWA 40.65 X-Tal for RX only
Txt or Call
0906 3608404 Globe
0922 4609160 Sun
0921 6345368 Smart
- new Crankshaft
- Good For Off Road
-for 5 Port
-for Rear Exhaust
-W/ Manifold
1.6k
Sanwa RF Module
-TM-201CW
-Brand New
-40 MHz.
1.5K
Looking For;
Txt or Call
0906 3608404 Globe
0922 4609160 Sun
0921 6345368 Smart
For Sale:
Brand New RC Stuffs:
TA04 Front Aluminum Body Mount (53616) - 500.00
- brand new in plastic
Team Atlas (#OP8-184) Battery Cooler VER2 - 2,500.00
- purple
- brand new
TRF415MSX Carbon Front Damper Stay - 600.00
TRF415MSX Carbon Rear Damper Stay - 600.00
TRF415MSX MRE Front One-Way Housing - 1,200.00
Futaba PK-FSM RF Module for 3PKS -3,000.00
-40MHz
Futaba MJ 2-Channel Radio Control System - 2,500.00 SOLD!
- 27.175MHz
- FP-R122JE Receiver
- 2x S3003 Servo
Used RC Stuffs:
Hudy Comm Lathe - 6,500.00
- very good condition
- with case
- with Diamond Bit
-case included
MUCHMORE Battery Heatsink, Black - PhP 2,000.00
- used and good condition
Futaba S9550 Digital Servo - 3,000.00
- specifications:
Volts/Torque/Speed
4.8V/66.6 oz-in./0.14 sec/60°
6.0V/83.3 oz-in./0.11 sec/60°
CE Turbo 35 BL - 5,500.00
- comes with box
- charges up to 10A
- discharges up to 35A
- power-up your motor lathes/tire warmers
- break-in motors
Tamiya TEU-101BK FET Speed Controller - 1000.00
- complete w/ original wires and connectors
- excellent condition
Tamiya TL01 (Rally Setup) - 4,000.00
- TL01 Chassis w/ Long Suspension Arms
- Front Bevel Gear and Rear TA03 Ball Diff Gear
- Front Universal Shaft
- Full Ball Bearings
- Hollow Carbon Shaft
- Speed Tuned Gear Set
- Quick Release Battery Holder
- Mabuchi 540 Motor
- S3003 Steering Servo
- Tamiya Lancia HF Integrale Body
- Tamiya Rally Block Tires
- Tamiya CVA II Oil Filled Shocks w/ Tuned Springs
SMS: 0917-8330305
- purple
- brand new
-40MHz
- 27.175MHz
- 2x S3003 Servo
Used RC Stuffs:
- with case
- with Diamond Bit
-case included
- specifications:
Volts/Torque/Speed
- comes with box
- charges up to 10A
- break-in motors
- Mabuchi 540 Motor
SMS: 0917-8330305
yokomo toyota altezza body painted and cut -800
team corally 9t motor mint condition - 400
BNEW mabuchi motor taken from tamiya df03 - 500
traxxas tq TX/Rx excelent condition - 900
yokomo drift tires on yokomo rims (advan based rims) - 400
yokomo zero-v drift tires(yung nilalagyan ng rings) w/ extra set rings -800
hitec lynx am reciever with xtals tx/rx 40mhz- 450
pm or txt 09226261531 - choyie
LOOKING FOR:
MANIFOLD NA KASYA SA BIG BLOCK ENGINES, UNG PWEDE KABITAN NG TUNED PIPE USING SPRINGS AND NOT THE SILICONE COUPLER, BAKA MERON KAYO SPARE JAN. TANX
CALL OR TXT 09178251298
for sale trade
Tamiya mo4 with alpha romeo guilla body 4k
PTI 1/18 ferrari f1 unpainted body with window mask 1k
ofna pirate 10 with .21 pull start engine 8k
hpi micro rs4 1.5k repriced
kyosho 1/8 bike 4.5k
teu esc 1k
sport tuned motor 650 SOLD
1b 3600 stick pack 850
gp3300 650 side by side SOLD
tamiya wid dagger 3.5k
airtronics 94102 900 SOLD
futaba s3003 500
futaba r112je 27 am rx 500 SOLD
MINITRIX train RTR Almost new 8k neg
n9mm made in germany with atlas custom power 1700
model railroad power pack (110v)
with 4 caboose
teu esc 1k
futaba s3003 500
with 4 caboose
FOR SALE
FOR SALE
QUICK EP8 ELECTRIC HELI INCLUDES:
mega brushless motor
hi model 45amps esc
hs 81 servo
410t tail lock gyro
3e model 4s2p lipoly
PRICE : 23K NEG.
CEL# 09154037400 WILLIAM
www.willysrc.com
hi model 45amps esc
hs 81 servo
410t tail lock gyro
PRICE : 23K NEG.
www.willysrc.com
backlash, sent u d pics na. tanx
