View Poll Results: JPRaceway : On-road or Off-road?
On-Road
![](https://www.rctech.net/forum/images/polls/bar2-l.gif)
![](https://www.rctech.net/forum/images/polls/bar2.gif)
![](https://www.rctech.net/forum/images/polls/bar2-r.gif)
![](https://www.rctech.net/forum/clear.gif)
60
69.77%
Off-Road
![](https://www.rctech.net/forum/images/polls/bar3-l.gif)
![](https://www.rctech.net/forum/images/polls/bar3.gif)
![](https://www.rctech.net/forum/images/polls/bar3-r.gif)
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Yo Jinx, Achtung,
I'll be dropping by the battery center maybe this afternoon. Will just bring the battery on Saturday. Be sure that you'll fly on Saturday Achtung.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
![Wildflyer is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
For Sale:
Slightly used Lynx FM 3D 75mhz with rx (i soldered the antenna because it was cut) with battpack P4,000 (neg)
• FM Modulation
• 10 Model Memory
• Model Select with Copy and Reset
• Servo Reverse
• Digital Trims
• Idle Up
• Standard Dual Rate Steering - Adjustable on the Fly
• Auto Dual Rate Steeling - Adjustable on the Fly
• Anti Lock Brakes (ABS)
• End Point Adjustments
Exponential's
ATL Braking Adjust
Adjustable Brake Lever Depth
Timer Up / Down
3rd Channel
DSC
Steering Tension Adjust
Right / Left Handed Convertible
Removable Module
Display Only Switch
Used TA04r with box (with HPI tires installed) has a small chip on the chassis near the motor P3,000 (neg)
Used LRP v7.1 esc (i lost the heat sink but ill provide another one) P3,000 (neg)
or get all for only P9,000! (negotiable pa din!)
RC Magazines 31 pcs. - All are in good to very good condition P60 each or get all for P1,500
1. Hi-Torque RC Car - July 2000
2. Hi-Torque RC Car - April 2001
3. Hi-Torque RC Car - May 2001
4. Hi-Torque RC Car - June 2001
5. Hi-Torque RC Car - July 2001
6. Hi-Torque RC Car - Aug 2001
7. Hi-Torque RC Car - Sept 2001
8. Hi-Torque RC Car - Oct 2001
9. Hi-Torque RC Car - Nov 2001
10. Hi-Torque RC Car - Jan 2002
11. Hi-Torque RC Car - March 2002
12. Hi-Torque RC Car - May 2002 (small tear at the bottom of cover)
13. RC Car Action - Buyers Guide 2002
14. RC Car Action - April 2001
15. RC Car Action - August 2001
16. RC Car Action - Sept 2001
17. RC Car Action - Dec 2001
18. RC Car Action - Jan 2002
19. RC Car Action - Feb 2002
20. RC Car Action - March 2002
21. RC Car Action - April 2002 (scotchtape at the side)
23. Xtreme RC Cars - May 2001
24. Xtreme RC Cars - June 2001
25. Xtreme RC Cars - July 2002
26. RC Nitro - April 2002
27. RC Nitro - August 2002
28. RC Nitro - Oct 2002
29. RC Touring Cars - Fall 2001
30. Backyard Flyer - Summer 2002
31. RC Modeler - Dec 2001
• FM Modulation
• 10 Model Memory
• Servo Reverse
• Digital Trims
• Idle Up
Exponential's
ATL Braking Adjust
Timer Up / Down
3rd Channel
DSC
Removable Module
Display Only Switch
![takobets is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![Smile](https://www.rctech.net/forum/images/icons/icon7.gif)
Selling my stock AE TC4 for only 5K
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
excellent running condition
rolling chassis with slick tires
mazda body used for bashing
side by side config batt used fro bashing
some spare pinion gears
Interested buyer send me a PM...
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
![FT TC4 racer is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Originally Posted by Wildflyer
Yo Jinx, Achtung,
I'll be dropping by the battery center maybe this afternoon. Will just bring the battery on Saturday. Be sure that you'll fly on Saturday Achtung.![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
![Achtung, Stuka! is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Bravokilo
Thanks a lot for your advise.. incidentally I was much tempted to make the purchase of the RC100 electronic switch over the net.
Achtung Stuka
I promised mang Bert that I would sign up for membership in my next trip back to manila, still in HKG at the moment but will surely drop by someday, wala pa lang schedule.
Toti D
I've been to the new field at Niog, I think you'd be at a risk taking off and landing (your giant scale aerobatic gas planes) due to the position of the runway. The length may seem enough but at the end is I think a creek with very tall trees and on the approach for landing your crossing the street which is perpendicular to the runway and elevated about 10 feet, meaning you can't make a gentle low approach from a distance. But better yet, check it out to see for yourself.
Thanks for the advise on the Kill swith. I finally decided to get the RC100 electronic switch sold on the net by RCATS. If I'm not mistaken I recall you had an instance with your giant Cap 232 wherein throttle was stuck and you could not land it until fuel ran out. It's in situations like this where this electronic switch is usefull since you can cut off the ignition through your Tx, the device is attached to a spare chanel on your Rx. You might want to check it out and have one installed in your giant gas planes. It's installed in series with a mechanical switch for added safety.
http://www.rcatsystems.com/electronics/rc100.php
Achtung Stuka
Toti D
![louie_b is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Originally Posted by louie_b
Achtung Stuka
Toti D
Toti D
TotiD.. Louie's description of the field is quite right.. actually, it depends all with you. I suggest that you visit the field first and see if you want to try it out. Actually, the 'trees' at the end are bamboo and are about 20-30 feet in height.
The field's orientation is East to West with the bamboo at the east side of the field. Prevailing winds generally come from the Eastern section of the field (from East to South East).. after 9am.
Takeoff is usually towards the East and with a left turn executed almost immediately after take-off to avoid the bamboo.
Approach is made from the west crossing an elevated concrete road (approximately 5ft high) and some degree of turbulence is experienced during windy days... and the degree of turbulence is proportional to the wind at ground level.
I would consider this a 'carrier type' landing for big aircraft since your final approach would be slightly above idling as you come in.. and chopping completely when you cross the road .. ala 'Manila Domestic Airport' or 'Mactan International'...
Looking for...
Sanwa M8 charger (for stock NiCd battery)
Sanwa M8 dry battery tray
Sanwa M8 battery port cover
0920.9245081
0920.9245081
![VooDooPH is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
LOOKING FOR THE FOLLOWING ITEMS
- Sanwa M11 (Used/Bnew)
- Proline MOAB 40 series tires
- 1/10 hex adapter for AE RC18T
- Proline Crowd Pleazer body for AE RC18T
*Futaba T3PDF Transmitter w/ Rx SOLD Thanks
*Engine for HPI R40 FOUND Thanks
09228076343
Kevin
09228076343
Kevin
![Armstrong is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
I'M LOOKING FOR A USED TAMIYA SPORT TUNED MOTOR..
Pls PM your offers......
![macgyver1432000 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Part 3...
1. Team Trinity Battery Case - P1,000
2. DC Motorsports IB4200s Matched - P3,000 each (raced once - peak charge 4800 mAh)
3. Fushion V2 GP 3700s Matched - P2,500each (peak charge 4200 mAh)
4. Fukuyama GP 3300s Matche - P1,000 each (peak charge 3700 mAh)
5. Purple Standard Starter Box - P1,000 (scratches on surface but still good)
![jihernandez is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Part 4...
1. Used Bodies 190mm (1xDodge 3.1 / 1xMazda 6) - for practice only P250 each (free if you buy the Pro4)
2. Pro 4 with hop-ups (no tires & electronics included) - P4,000
BTW, in Part 4 on the Pro 4 this includes parts (spool, diff, one-way, HPI spring set, etc.) pic below.
Part 5...
1. Team Orion V2 8x1 - P1,500
2. Team Orion V2 10x2 - P1,500 (with free new brushes)
3. RD Logics II pipe (no manifold) - P500 only
Part 5...
Tamiya TA03 Ball Diff
opened and assembled but never installed/used (to be used for my m03 sana), i still have the packaging and all the little stuff included in it.
P700
Venom Temp Monitor
used. battery needs to be replaced. with packaging/manual.
P400
Ofna 6-ring pipe w/ side exhaust manifold and the rubber fittings.
b/new. can be used for ntc3 or the rc10gt that has a side exhaust engine.
P300
all prices are fixed. pm me.
P700
Venom Temp Monitor
P400
P300
![sup is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
HPI R40
purple aluminum rear bulk head
purple aluminum wheel hexes
Titanium Screws
HPI Orange Soft Springs
Rear Diff has 4 bevel gears already
Diff and One-way
RD Logics II Turbo in-line pipe
Sirio S.12 TUP 5 ports turbo (with extra new S7 cold glow plug)
2 x S9402 servos
1 glow plug igniter
1 standard starter box
1 AAA receiver batt 900mAh
1 Body
ALL YOU NEED IS YOUR RADIO AND RECEIVER AND FUEL AND OFF YOU GO!
ALL THESE FOR ONLY P10,000!
Titanium Screws
Diff and One-way
2 x S9402 servos
1 glow plug igniter
1 Body
