View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
only tt01 chassis is allowed. we have to wait for final advise from tac organizers if the tt01r will now be allowed.
as a guidance, they have informed each countries to initially use last year rules & regulations
1. Only TT-01 chassis is permitted to be used in this class.
2. Only CPR01 included in XB2 and TEU-101BK (#45029) are permitted to be used in this class.
3. Three batteries shall be handed out to all drivers by the race organizer. Each driver can purchase two additional approved batteries at the shop beside the circuit if necessary. No modifications to the battery cables or connectors are allowed.
4. Two standard 540 Motors will be handed out to all drivers by the race organizer. Drivers must use the motors as provided including wires. Any attempt to modify or to influence the ability of the motor is prohibited.
5. Cars do not have to be equipped with cockpit detail and/or a driver figure.
6. Minimum permissible weight of car when ready to run is 1,450g without a transponder.
7. Only the following three kinds of tire can be used:
#50419 Celica Racing Radial Tire, #50454 Racing Slick Tires, #50810 Racing Semi-Slick Tires
8. No tire performance enhancing materials are allowed.
9. Clearance under main chassis parts must exceed 5mm before the race.
LF: inner wheels for m18
baka meron kayo dyan inner wheels for m18 onroad swap ko sa stock chasis na m18 or meron din ako HP deskjet 3420 printer or laptop cooler.
yung aluminum na inner wheels sana pero kung plastic lang ok na rin cguro basta walang sira.
thanks.
pm na lang
thanks.
pm na lang
next year balita ko may malaking Asphalt Open parking lot na itatayo malapit sa Flat ko. Great way to stretch my Kit.... kaya lang matatagalan pa yun.
Miss ko na Circuit Racing!
Next summer ulit! may big event o wala... Lalaro ako on my next vacation. Hehehehe
bwahhahahah!
cobra: mg practice kna syang nmn kung nd k makakasali s race para nmn makita nmn ang konting yabang mo lakas mo kse s makina eh! bwahahahaha!
sana iniwan mo nlng ung revo mo ng tiis k nlng s savage sbagay mganda nmn ang revo mo fully modified nd up grade! awwuwwuwuwwwwww!ung png bagahe mo kinain n nmn ni lhancelot! bwahahahah! pre gudluck nlng s mga race mo ingatan mo mga parts mo at makina wala ng mg sponsor syo ng ganyan! bwahahahahah! tkecre!
crt.5 pro
for sale:
CRT .5 PRO
ran 4 tanks only after break in
- BNEW Nova .12 engine, unbroken in, with flywheel
- broken in condition STS .12 engine
- lightened flywheel
- 1400mah hump pack
- 2 s3002 micro servo futaba, metal geared
- not in picture is starter box for crt.5, included in deal, with 3300mah nimh batt
- no scratches
- box and manual and all extra parts in it
- body painted and reamed, mounted a few times, but never ran with body
Ran STS to break in only, Nova never tasted fuel....
repriced... text me for a SURPRISE!!!!
0197 8166115
open to TERMS with PDC
Free delivery in Metro Manila
reason: HOBAO HYPER ST PRO!!!!
CRT .5 PRO
- 1400mah hump pack
- no scratches
0197 8166115
super savage SS
FO SALE:
- SUPER SAVAGE SS
- super chassis, thick and lightweight (will include uopened bnew savage 25 chassis)
- 3 speed!!!
- lightweight racing flywheel
- aluminum C-hubs
- adjustable upper arms
- HD aluminum heat sink engine mount
- rpm under chassis guard
- dual disk brake
- .28 HPI very good comp (Have a lot of Kits so I seldom get to use this), roto
- roto 2 included
- hpi ribbed pipe
- aluminum integy rear shock tower
- aluminum HB shocks
- super raced tuned shocks (oil factor secret), green rear, purple front springs
- front and rear sway bars
- tank guard aluminum
- 23mm dish on Crime Fighter 40series
- radio box changed to X box
- hump pack batt
- will include VENOM Temp FS, box and Manual
- 2 bodies GT1 blue and red, red reamed only for WING mounts
- BAJA HPI wing mounted
- electronics: JR 10.4kg digital HT steering, throttle also
- reverse mod
- LUNSFORD titanium turnbuckles
- CVD all around (front, rear, center)
- baddest savage around!!!
call for pricing.... GUARANTEED LOW!!!
0917 8166115
TERMS available with PDC
- BIG discount for cash buyers.....
Reason for selling: HOBAO HYPER ST PRO!!!!
and on road Savage XSS OS30VG with Road Rage.... hehehehe....
- SUPER SAVAGE SS
- 3 speed!!!
- aluminum C-hubs
- dual disk brake
- roto 2 included
- hpi ribbed pipe
- hump pack batt
- reverse mod
0917 8166115
FOR SALE
1. YOKOMO WIDE FRONT BUMPER - BRAND NEW
- unused, in original packaging
- includes wide foam bumper and wide kydex bumper
- fits yokomo bd, bdm, sd cgm, sd ssg, sd lcg, sd drift
- only P 500.00
2. FULLY AUTOMATIC COMM LATHE... edit: sold ...
CALL/TEXT 0917-823-0894
LOOKING FOR
brand new aluminum or composite 3-shoe clutch for 1/8 buggy you may have a spare set that you wont be using anymore
- only P 500.00
LOOKING FOR
SJM 400 ELECTRIC HELI READY TO FLY ... edit: traded
futaba 2pcka w rx 2t
jr racing xs3 synthesized tx w rx 3t
0917-714-4494
0917-714-4494
Boss rnold,
what if meron nang NSO Birth Certificate? does the Taiwan Consulate really want the original copy of the document or will a photocopy suffice?
YOKOMO DRIFT PACKAGE
Hi, I'm selling my 6 month old YOKOMO DRIFT PACKAGE complete with box and manual. This kit is in perfect running condish and it's well taken care. This is the kit specially made by Yokomo for drifting.This kit has all the essential keys for drifting for that crazy angle and distance. I bought the kit for 13K, kit only and no electronics.Now i'm selling the whole package with electronics and remote, Ready To Run just add batteries. This kit is not only perfect for beginners but also for serious drifters looking for an upgrade.
For more info check out: www.yokomousa.com ; www.teamyokomo.com
MR4TC-SD CM CHASIS:
-Shaft Driven Full Time 4WD System
-High strength molded composite chasis
-Fully Adjustable Double Wish Bone Suspension/ Adjustable Allignment via Tie Rod Turnbuckles
-LSD Ball Differentials (front and rear)
-Front Universal Drive Shaft / Rear Dog Bones
-Aluminum Knuckle Arm
-Composite Shock Absorber, Adjustable Damping
-Aluminum Motor Mount
-Ball Bearings
-Realistic Disc Brakes
-Nissan Skyline GTR R34 Body Shell
-Yokomo Super Drift Tires with Rays Volk Racing rims for bashing (single wide ring version)
-Hpi Drift Tires w/ volk racing rims
ELECTRONICS INCLUDED:
-YOKOMO SPEED CONTROL SCR 6712 ( motor limit up to 12 TURNS) (with Bullet Connectors)
-NOVAK POWER CAPACITOR
-RC SPORT "4" CHANNEL MICRO RECIEVER (1 pair crystals included)
-FUTABA MEGATECH 2PL REMOTE (with box and manual) (New Condition)
--FUTABA STANDARD SERVO
-19 TURN D1-Sp Super Drift Motor and another 27 TURN HPI Saturn Motor
PRICE:
-9,000 for the whole package
Cars stand and Failsafe shown are not included in the deal
- cell: 0917 855 3317
-SOLD! SOLD! SOLD!
MR4TC-SD CM CHASIS:
-Ball Bearings
PRICE:
-SOLD! SOLD! SOLD!
Selling my two month old Hobao Hyper ST Truggy! (This is the RTR version but selling without the radio & electronics. Comes with the original MAC 0.28 engine)
Upgraded with:
- Aluminum CNC Steering Knuckle (worth almost 2T)
Already Set up with: (You save money here. This kit uses a lot of oil, specially the big bore shocks)
- 10T Front Diff. oil
- 25T Center Diff. oil
- 1T Rear Diff. oil
- 60wt. Shock oil all around.
Reason for selling: Upgrading to a Pro Kit Version!
Price: P18,000.00
Serious Buyers only pls.
PM if interested or text me at 09173202020
Upgraded with:
- 1T Rear Diff. oil
Price: P18,000.00
Team Truckista
Foxtrot: Yes bro, tuloy na tuloy yung race natin sa July 29, tomorrow. Speedzone will be open to all participants at 11am. Race will start 1pm.
Goodluck to all!!!
Makikita na tomorrow who is the King of Monster Trucks!
Goodluck to all!!!
