View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
edited
FOR SALE!!
Kyosho v-one rrr with manifold, pipe and RB 5Port Engine(Good Compression)
Hop-up as follows:
3R aluminum 1 piece engine mount
3R aluminum rear shaft gear spacer
3R aluminum rear upper deck post
3R aluminum mid post bearing stay
3R aluminum hex
3R aluminum upper servo lever
3R ventilated clutch bell housing
SSG Carbon Fiber upper deck
Carbon fiber front body shell stay
just add electronics and you're ready to race...
P16k negotiable
you can reach me thru 0920 922 9259
pics upon request
Hop-up as follows:
3R aluminum hex
P16k negotiable
pics upon request
Originally Posted by MFLORES
migvea: may 'banda' si Nicadraus!!!
boys looks like the weather has cooperated! see you later!!!!!!!
Rayspeed 3mm main chassis plate/lower deck
for MR4TC SD
para sa mga ngaka CGM/SSD na gusto mag-upgrade.
1K fixed
0920.9245081
for MR4TC SD
1K fixed
0920.9245081
Is that you Jayson?
I didnt know you are into RC too
For Sale: MIP STINGER 360 tuned exhaust for RC10GT
Sold!!!
Electronics not included.
I am the third owner... I do not have spares for the car.
Slightly used 2speed gearset. (Will Include old single speed gears)
Pull-start 0.15FE Engine, good compression.
fiber disk brakes,
orig HPI Tires... nag aalikabok lang sa kabinet.... Might as well sell it
add ko na rin a set of sponge tires.... as bonus!
all for 6K Neg.
or swap for nitro truck i'll add cash
Add 1.5K and I'll inlcude the TX and RX AM 24Mhz
call/Text/Pm me:
0917-856-1314
Looking for hightorque/speed servo... atleast 100oz-in
pictures here:
http://www.rctech.net/forum/showpos...0&postcount=836
fiber disk brakes,
all for 6K Neg.
call/Text/Pm me:
0917-856-1314
pictures here:
FOR SALE!!!
For Sale, Firm Prices
Cash & Pick Up Only
Sorry, Can't Ship/Deliver
Prices Effective Until 15 Nov.
1) B/N 3E Smart Plus 2-5 Cell Li-Polymer,
Li-Ion DC BALANCE/CHARGER, DC 12V 8A
Input Voltage, 1.3A/Cell Charging Current,
Reverse Polarity Protected, 140 X 80 X
31MM, 400g. Last One.--------- P3,380.
2) B/N E Sky 2-3 Cell Li-Ion Polymer 10-15V
DC Charger,.8A Charging Current.-P1,180.
3) B/N Electrifly 1-3 Cell Li-Polymer Poly-
Charge 11-15V DC Charger, 250mA/
500mA/1000mA Charge Settings.- P1,720.
4) B/N 7.4V 2Cell 2000Mah Lipo Batt. W/14
Gauge Wire, Deans Ultra Discharge Plug,
3Pin Charge And Balance Plug. 16 Amps
Continuous/24 Amps Burst. 34 X 17 X
84MM. Fits RC18 & MiniQuake.-- P1,680.
5) B/N GP 6Cell 7.2V 2/3A 1100Mah Double
Stick Battery Pack W/Micro RS4
Connector. Fits RC18 & MiniQuake- P820.
6) B/N IB 7Cell 8.4V 2/3 1200Mah Double
Stick-One Across Battery Pack W/Micro
RS4 Connector. Fits RC18--------- P980.
7) B/N CBP(Cheap Battery Packs) 7Cell
8.4V 2/3 1150Mah Double Stick-One
Across Battery Pack W/Micro RS4
Connector. Fits RC18------------- P920.
8) GoodCondition Tekin 411G, NO
Motor Limit, 300 Amps Max, .0015V
VoltageDrop. CheckTeamtekin.com
For Specs.& Manual.------------ P1,780
9) B/N Pair GPM Mini-LST Assembled Gear
Diffs W/Matching Pinions.------P1,520.
10) B/N 3Racing Motor HeatSink W/
Cooling Fan For 280/300 Series Motors
Anodized Blue or Red.----------- P430.
11) B/N In Box Silverlit Picoo-Z Micro-
Helicopter. Never Operated. ---- P1,680.
12) B/N RTR TeamLosi Mini-T, Complete
RTR Kit, W/TL Bearings & GPM Blue
Alloy Shocks Already Installed, SilverGray
Body, 26.995Mhz(Brown Freq.).- P6,480.
13) B/N Kyosho AWD/4WD Mini-Z MA-010
Readyset, Complete Readyset Kit, White
Nissan Skyline Body 27.045Mhz. FREE
ExtraMotor. ------------------ P8,280.
14) B/N RTR 1/18 Duratrax Micro-StreetForce
On-Road 4WD Beltdrive. Complete RTR Kit
With Micro ESC, 7.2V 600Mah Ni-CD,
Charger, 75Mhz. Very Durable.--P5,680.
15) B/N HotBodies Aluminum TunedPipe
(Black)W/Mounting Hardware For HPI
Savage.-- P1,780
16) B/N HPI MT2 Dirt Bonz Tires W/
Foam Insert. 4 Pc. Set---------P1,500.
17) B/N RoadTech 38,000RPM 27T Motor
For RC18T, Mini-T. 370 Size ---- P700
a) Buy 2 For.----------------- P1,200
18) B/N HiTec HS-55 MicroServo.-- P780
a) Buy 2 For Only.--- P1,400
19) B/N Futaba S3003 Servo.---- P680
20) B/N Futaba R142JE RX W/27.045
X'tals--- P1,680
21) Unused HPI GT-1(Orig. Body SS25)
Savage BodyPainted Yellow/White
/Silver.-- P1,580
22) B/N Traxxas T/E-Max Parts--
a) Front Bulkhead #4930-- P380
b) 1 Pc. Lower Front Arm--- P220
c) CushDrive Elements #5273--- P110
d) BrakeDisc #4964-- P120
e) 20T ClutchBell #4120--- P580
f) QuickConnector #4579--- P220
g) 5MM Flanged Nuts #5147-- P150
h) Carb O-ring & Seal Set #5247--- P380
23) B/N Coleman COLDHEAT Cordless
Soldering Tool In Unopened Blister
Pack.Requires 4 AA Batts.-- P1,180
Prices Valid Until 15 November. Subject To
Change W/O Notice Thereafter. Please Text
Or Call +639154524488(Formerly +63915
4130823). Scheduled Weekday Office Hours
& Sat.A.M. Pick Ups ONLY. Edsa-Greenhills
Area. No PMs. Thanks For Browsing.
To Those Who Purchased During The 3-Day
Sale, Thank You.
Cash & Pick Up Only
Savage.-- P1,780
X'tals--- P1,680
/Silver.-- P1,580
Sale, Thank You.
rush sale..
Indy 30A reactor discharger - 1.5k fixed
-discharge nicd and nimh batts..
-discharge sidexside or stick packs
-very good condish
-no box(natapon na kasi eh..)
Pitbull charger - 3.6k fixed
-charges nicd and nimh batts(stick or sidexside batts)
-1-7 amp charge rate
-peak charging
pm na lang ung interesado.. no shipping pls whatsoever kasi di ako nag-gaganun..
almost online lagi..
-very good condish
-peak charging
FOR SALE SAVAGE K4.6., .28 ENGINE, ROTO START, DUAL DISC BRAKE, FULL BALL BEARINGS, SERVO SAVER, DIRT BNZ TIRES, FORD F350 BODY, HEAVY DUTY DOG BNE, AM TX N RX, 2 STANDARD SERVO, BOX N MANUAL. READY TO RUN....19K
FOR SALE ELECTRIC MONSTER TRUCK EZILLA KIT ONLY, NO ELECTRONICS..7K
FOR .18 OS CVR, SIDE EXHAUST, ALMOST NEW,VERY FRESH, CONSUMED 1/2 GALLON INCLUDING BREAK IN, BOX N MANUAL....5K
FOR SALE GS .21 ENGINE, IDEAL FOR ROTO N PULL START, VERY GUD CONDITION..3.5K
FOR SALE NOVAK FLATLINE, DISCHARGE TRAY, BNEW SEALED, ORIG PRICE 2.5K., SALE 2K ONLY
NO TRADE, NO PM
09063147021-KENET [/QUOTE]
NO TRADE, NO PM
FS : Attack Gold Stick Tye Controller
I am selling my attack gold stick type controller. Spare ko ang to.. Make a reasonable offer or trades. Need parts for v1s kit if you have one. Radio lang ito. Cash or trades are pwede. Kapag Cash make an offer. Thanks...
09062228311
09062228311
For sale items...
Originally Posted by putok
MTX4 kit- php 15k
- no broken parts
- Nova LL5 tuned engine & gpx4 tuned pipe
- gpx4 front CVD
- alum wheel hex
- front diff
- gray springs (front/rear)
- new jaco foam tires
- 60/20t spur gear
- upgraded brake wheel
- ti turnbuckle
- 1 used body / 1 new gtr mustang body / 1 new painted stratus body
- parts like front spool / one way , dogbones, front arms, stock springs,stock spur gears,screws,etc.
- box / manual
Assorted Motors S PRO 9t / speedgem 23t (2pcs.)- php800 each
POWER SKATEBOARD - PHP 3K
- remote controlled electric powered skate board
- standard size
- w/ lead acid 12v battery n 220v wall charger
- speed - max 8mph
- capacity - 170lbs
OS MAX 21VZ -B VSPEC engine - php7k
Looking for :
M8 radio steering wheel
damaged s3003 servo(need only the housing w/ intact ears)
27mhz AM receiver no glitch
Txt / call me 09198194150
- no broken parts
- gpx4 front CVD
- alum wheel hex
- front diff
- 60/20t spur gear
- ti turnbuckle
- box / manual
- standard size
- speed - max 8mph
- capacity - 170lbs
Looking for :
FOR SALE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HOBAO GPX4 PRO
ALL TITANIUM SCREWS!!!!!!!!
MILLED OUT CHASSIS BLACK
NOVAROSSI L5 INCLUDED!!!!!!!!!!!!!!!!!!!!!
INCLUDING ALL PARTS I HAVE FOR THE GPX4
ALUMINUM HOP UPS INCLUDED!!!
NO ELECTRONICS
15k
TEXT 09193793627
HOBAO GPX4 PRO
NO ELECTRONICS
15k
TEXT 09193793627
