View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Kenneth: coming from q ave, take roces ave then you will see a gate sa right side bago mag velodrome yun na yun. park ka nalang dun yung entrance is nasa may gitna ng velodrome mismo pag akyat mo dun Voila!
Amoranto race
Kenneth M. : Bro, this saturday ang practice na allowed ng amoranto management.. Thursdays kac meron practice yung philippine cycling team. Baka madulas sila ng nitro spillage sa track. Saturday 9am-1pm.
Amoranto race
To all RC enthusiasts :
Are you fast?
Are you really fast?
Do you have what it takes to win in a game of speed?
If your answer is yes, then join the first ever NASCAR-like rc race in the Philippines. The 1st Amoranto Velotrack RC Challenge. To be held on June 9, 2007 at Amoranto Stadium, Roces Ave., Q.C.
This Race is open to all kinds of RC racers. From Nitro touring cars, Monster trucks, Truggies, Stadium Trucks, and to Electric racers as well.
This event will be featured on ABS-CBN's Sports Unlimited, if negotiations pushes through.
Practice Dates : May 19, Saturday, 9am -1pm.
May 26, Saturday, 9am - 1pm
June 2, Saturday, 9am -1pm
And before the race on June 9, Saturday, 8am -1pm.
Entrance Fee, per person, : P300
Practice fees before the race day : P100
Possible Categories:
1. 1/10 On-road nitro touring cars (open engine)
2. 1/8 On-road nitro touring cars. (open engine)
3. Nitro Monster trucks ( .25 and open engine)
4. 1/8 Nitro Truggy (open engine)
5. 1/10 Stadium Trucks
6. Electric on-road touring cars
7. Electric Monster Trucks.
No. of Laps around the 800 meters (approx.) velotrack per race:
Endurance race-Nitro - 6 laps, Electric- 4 laps.
Drag race- 1 lap
There will also be a demo run by the Go ped group and a Heli group.
Join and Win and Be Recognized as the Philippines RC King of Speed.
To those who are interested to join, text or call :
Karl - 0917-800-2976
Donjie- 0917-850-9057
Are you fast?
Drag race- 1 lap
MTX-4 package SOLD
Originally Posted by motogpph
Used Nitro Touring Car Sale!
1) Team Magic G4s Package: Php 16k
Hop-ups installed on car:
kfactory carbon fiber upper front bumper
kfactory carbon fiber upper front plate
kfactory carbon fiber break brace
kfactory aluminum break lever
kfactory aluminum (blue) one-piece engine mount
kfactory aluminum middle belt mount
kfactory aluminum side pulleys
kfactory aluminum servo mounts
kfactory racing brakes
kfactory racing brake disks
Extra parts included:
6 pcs. – 1st gear spur (51t)
1 pc. – 2nd gear spur(45t)
2 pcs. - 2nd gear spur(46t)
4 pcs. – clutch gear (18t)
5 pcs. – clutch gear (24t)
1 pc. – front belt
1 pc. – side belt
1 pc. – 2 speed housing & nut (with bearing)
1 pc. – front lower bumper (blue aluminum)
1 pc. – clutch shoe (hard, red)
3 packs – shock bladder
1 pc. – aluminum side pulley (18t)
2 pairs – steel gear diff joint
3 pairs – rear hub carrier
6 pairs – front upper arm
2 pairs – hard composite rear arm set
2 pairs – front lower arm
1 pair – steering block
1 set – 2 speed shoe
1 set – rear body post set
1 set – push type clutch pinion gear removal tool
PLUS several loose extra parts
Other stuff included:
others:
2- KO propo PDS-2364 ICS servos (hi-torque w/heatsink)
1- Team Magic receiver battery
PLUS free Used Novarossi LL5 Tuned engine with pipe!!!!
2) Mugen Seiki MTX-4 Package Php 16k:
3racing main chasis (4mm)
3racing brake disk
3racing side stiffener (aluminum)
3racing lightweight flywheel
3racing brake bracket
3racing carbon fiber battery tray
kfactory engine mount
5 pcs. – spur gears (52, 53, 54, 55, 58t)
1 pc. – 1st pinion gear (16t)
1pc. – 2nd pinion gear 23t)
1 pair – rear joint cup
1 pc. – rear anti roll bar (2.5mm)
1 pair – front spring (white, 1.9mm)
1 pair – rear spring (white, 1.9mm)
1 pair – front spring (gray, 1.8mm)
1 pair – rear spring (purple, 1.6mm)
1 pc. – fuel tank
1 pc. – front belt
1 pc. – rear belt
2 pcs. – clutch spring (hard and super hard)
1 set – 2 speed gear box shoe
1 pack – shock diaphram
1 pc. – carbon fiber front shock tower
1 pc. – carbon fiber rear shock tower
1 pair – front lower arm
1 pair – rear lower arm
1 pair – front upper arm
1 set – front upper arm mount
1 pair – rear upright
1 set – front bumper
1 set – front bulkhead
2 – KO propo PDS-2363 ICS (high speed w/heatsink)
1- receiver battery
3) Novarossi 12-3CT PLUS (slightly used) Php 8k:
4) M.SPEED L5 (slightly used) Php 9k
5) Used Novarossi conical manifold (.12) 6 fins Php 1.5k
Big discount and free stuff awaits buyer for the whole lot!!
Call or text 0917-5305602 for faster transactions
1 pc. – front belt
1 pc. – side belt
others:
3racing brake disk
1 pc. – fuel tank
1 pc. – front belt
1 pc. – rear belt
1- receiver battery
Hanz: Malabo magkaroon ng Tracks pa dito... Since Trashing and Bashing lang dahilan kaya bumibili mga Lokal dito... One more thing nga pala if ever it works para sa Savage Setup... Since it Works sa Onroad... Naka Toe-in yung mga Gulong sa Likod for Better Stability at High speeds.
Regarding naman dun sa Choice of Electric Motor... it would be better to Use Single turn than Double... Cause Single Turns are for High Speed and Double are for High Torque... V2 endbells are Ok din... Otherwise go for a Speed Standup Brush Endbell Configuration, kasi yung Laydown may Drag brakes.
These are the usual Motor Types.
1.Speed Stand-up......SS
2.Torque Stand-up......TS
3.Speed Lay-down......SL
4.Torque Lay-down......TL
The V2 Endbell uses Round Brushes and angled at a 45deg.
Im not yet familiar sa Brushless.. though from what I know... kailangan din ng ESC for Brushless para dun... Gastos naman yata yun.
Anyway... These are all Trial and Error setups...but most likely, the Errors will come from the Driver. Hehehehehe
Karl: Ask ko lang kung Kasali din sa Category yung Direct-Drives na scale 1:18?
Happy Practice! Balita ko Wla masyado parts Savage ngayon. Hehehehehe. Ingats Ingats lang!
For Sale:
Slightly used Lynx FM 3D 75mhz with rx (i soldered the antenna because it was cut) with battpack P4,000 (neg)
• FM Modulation
• 10 Model Memory
• Model Select with Copy and Reset
• Servo Reverse
• Digital Trims
• Idle Up
• Standard Dual Rate Steering - Adjustable on the Fly
• Auto Dual Rate Steeling - Adjustable on the Fly
• Anti Lock Brakes (ABS)
• End Point Adjustments
Exponential's
ATL Braking Adjust
Adjustable Brake Lever Depth
Timer Up / Down
3rd Channel
DSC
Steering Tension Adjust
Right / Left Handed Convertible
Removable Module
Display Only Switch
Used TA04r with box (with HPI tires installed) has a small chip on the chassis near the motor P3,000 (neg)
Used LRP v7.1 esc (i lost the heat sink but ill provide another one) P3,000 (neg)
or get all for only P9,000! (negotiable pa din!)
• FM Modulation
• 10 Model Memory
• Servo Reverse
• Digital Trims
• Idle Up
Exponential's
ATL Braking Adjust
Timer Up / Down
3rd Channel
DSC
Removable Module
Display Only Switch
Front one way for xxxg+ losi 4wd buggy -php800
one way bearing for xxxg+ - php200
Double oring shock cartridge (xxxg+ shocks) - php100
Front alum hinge bracket 5/10F (free rear graphite hinge bracket) - php400
Front inner pin bulk HD brace & Idler gear set for xxt /xxbuggy - php100
Oil filled shocks (can be used for rally kits) 4pcs - php600
Slightly used Servos (intact ears)
AE 9103 from mgt truck - php1000
Analog plastic gear 9403 - php1500
B/new 200mm on road mazda body painted but uncut - php 1200
B/New Arrow Shark 52" Flying Dragon Unleaded Gas Boat - php39k
- Semi RTR Gas boat without electronics
- JZ260M 25.4cc pullstart unleaded gas engine
- Engine parts are interchangeable w/ Zenoah G260PUM
- Tuned pipe w/ silencer
- Length 52 inches including rudder
- Beam 12 inches
- 5mm 270 propeller
- Boat wooden stand
- still sealed in box w/ manual
Txt / call me 0919-8194150. Pls indicate sender callsign
- Beam 12 inches
- 5mm 270 propeller
- Boat wooden stand
for sale,
Associated Rc 18mt
1/10 scale wheel adaptor
aluminum shocks
3 racing cvd's
new steering servo
RTR just add battpack and tx batts and ready to play na.
Selling for 9k only
09174902074
Associated Rc 18mt
aluminum shocks
3 racing cvd's
new steering servo
Selling for 9k only
09174902074
for Sale FUTABA CR2000 PEAK CHARGER DIGITAL
for sale FUTABA CR2000 PEAK CHARGER DIGITAL w/ cable for tx and rx, box and manual slightly used very good condition.
charger for NICD, NIMH, and glow igniter
For PHP5,500 neg.
pm me
or text me 09287751101
For PHP5,500 neg.
pm me
Looking for:
Pickup Truck Body 190mm or 200mm
DF03 Based Buggy or
Tamiya TA02 Stadium Truck Ford F150 or Chevy S10 or
Tamiya XC or CC01
Please PM or txt 09178357392 Edward
DF03 Based Buggy or
Tamiya XC or CC01
Originally Posted by miltot
FS: IWAVER 02 CHASSIS KIT
- mint condition
- 2 sets of aluminum wheels (black & blue / 8 pcs)
- ball bearing motor case(auldey) in stock armature
- Full Ball Bearings from Iwaver
- customized BRASS spring limiter!
- with motor mount for midmotor set-up & STOCK Iwaver accessories!
- modified GTskyline body (NEWLY PAINTED)
- revised 1/24 decalsheet included!
- reason for selling : want to shift at 10th scale!
- CRYSTAL NOT INCLUDED!
all for 2K na lang!
(no swapping pls! / willing to meet sa makati from mon 2 wed / fri & sat from 4pm to 7pm)
pls txt me at 09207835797 or PM!
PIX: http://www.rctech.net/forum/showpost...postcount=1844
- mint condition
all for 2K na lang!
FOR SALE
SOLD Novarossi Plus 5ct(5port) .12=6,000
SOLD Nova tuned pipe=1,000
SOLD receiver battery intellect=300
SOLD TM Bag f8=5500k (inside boxes still for repair)
SOLD 9402 SERVO=2500
9402 servo=2500
3350 servo=2500
SOLD Eagle Charger for receiver pack=1k
SOLD MuchMore CTX Charger=4k
rd logic pipe=500
rc stands 2 kinds=700(bigger/rotating) and 300 smaller
starter box with batteries=2500
KYOSHO RRR Parts
rear arms set=300
rear hub=200
thrust bearing=400
shock diaphram=150
spur gear 61t=200
spur gear 59t=200
front spring silver=250
pinion gear 22t=150
others:
SOLD tires new 3 sets=35/38/42 shore=1000 for all
fuel bottle=200
engine head L5=300, Max=300, 1 old nova and RB=300 for 2
Set up wheels=500
Hyper 8 Almost Brand New=15,000
7Port Nova .21 Engine = 10,000
txt 09209180395 or pm
9402 servo=2500
3350 servo=2500
rd logic pipe=500
KYOSHO RRR Parts
rear arms set=300
rear hub=200
thrust bearing=400
shock diaphram=150
spur gear 61t=200
spur gear 59t=200
pinion gear 22t=150
others:
fuel bottle=200
Set up wheels=500
porsche boy: im using a 23t motor. yup, brushless motors are fast as I've seen on the net, and I heard one of the participants this coming June 9 will run in brushless, nice!
kennethM: hmm yup its fast but I couldn't feel its swiftness kasi hindi maingay walang weeeng weeeng may kulang p parang mbagal p eh
Originally Posted by juz911
Selling/Trade My Schumacher Mi2 Full Hop-Up With Komodo Trinity 17Turn and LRP F1 No Motor Limit ESC.No RX TX.I Wanted to trade this schumahcer mi2 to a nice Off Road RC(If you are gonna trade this with a Electric off road RC i would only give you the stock motor and esc which is TEU-101BK and Modified Mabuchi Motor).My Schumacher is in a Very Good Condition Light Scratches in the Chasis.I Will Include 2 Bodies 1 Ferrari FXX and 1 Mazda 6 Bashed Body(Light Bumps on the FXX)I Will Also Include so Many Spare Parts like Arms etc.
I wanted to trade this so if you want to buy it you give me a price
PM me or Text me or Call me at 09267172216
futaba 72Mhz fm module
For sale 3pcs futaba 72mhz fm module model: FP-TP-FM,
1.5 each
you can reach me at 0922-827-1100
1.5 each
