View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Miguel: Ikaw naman ang wala kanina. Sayang... nagpa-gutom pa naman ako.
Centerfire: Bilis ng freak motor mo ah!
Geetoo: Champ, Amazing Aloha, Big Mac, Chicken Joy, Chicken McDo, Spaghetti, etc. etc. Kahit ano
MTX-3 Prospec
For Sale:
MTX-3 Prospec
-Box and manual
-Extra parts
-Aluminum Hop-up parts
-Sirio TU-Pro .12 Engine (needs piston and sleeve)
-HEC Pipe and manifold
-Igniter with wall charger
-250ml fuel bottle
P7000.00 fixed
Pictures are a bit big. I can send it to you via email.
No PMs please. Text me at 09175362548.
MTX-3 Prospec
-Box and manual
-Extra parts
-250ml fuel bottle
P7000.00 fixed
Mi2 Schumacher BMI Modified
-Tons of Extra parts
-Aluminum C-Hub
-Aluminum Knuckle arms
-3 pairs of plastic Knuckle Arms
-pair of plastic C-Hub
-New Spurs
-New Belts
-New Bearings
-New One way Bearing
-One way gears 4 pcs.
-Extra used Spurs
-Extra Diff. Rear
-Diff. Rings
-Extra Brand New Arms
-Belt Pulleys (Bearings)
-Extra used BMI Chassis
-& Lots of New parts Still in Plastic
-ETC. (Lots More)
-Box & Manual
8.5k only Nego.
HPI Nitro RS4 3
-.15FE engine pull start (new pull start)
-New Glow plug
-2 pcs S3003 servos slightly new
-Titanium Turn Buckles
-Newly installed 2 speed tranny
-orig. tires & wheels
-transmitter Pack
-Good for Nitro Drifting
-Sponge Tires Set
-Body for Bashing
8.5k only
JP Fx 5 Novarossi Tuned .12 5 port Race Engine
-Use only for Reserve engine
-still needs brake-in
-Good Compression
-Good bearing
-w/ conformity declaration certificate
-box & manual
4.7k only
MC230CR Esc Futaba
-Good as new
-Opened But never used
-All wires are original
-Tamiya Connector (male)
-Case & Manual
1.3k only
TEU 101 BK Tamiya ESC
-Installed on Kit only for display
-With Tamiya Male Connector
-Good as New
-fresh no scratches
800 Php only
Pro Line Bow Tie T Pro-196
-Once used on off-road track
-Truggy Tires
-Mounted on HPI Rims
-Like new
-Still shiny
-2.2x2.0 Size
2.5k only
FS: Personal Transponder(PT) AMB
-Good as new
-used once
-very very fresh
-w/ orig casing
-manual
5k fix
FS: Integy Indi Reactor 30Amps Discharger
-w/ auto cut off
-first owner
-Good Condition
2k only FIX
Call or txt 0906 3608404
-Aluminum C-Hub
-New Spurs
-New Belts
-New Bearings
-Extra used Spurs
-Extra Diff. Rear
-Diff. Rings
-ETC. (Lots More)
-Box & Manual
8.5k only Nego.
HPI Nitro RS4 3
-New Glow plug
-transmitter Pack
-Sponge Tires Set
-Body for Bashing
8.5k only
-Good Compression
-Good bearing
-box & manual
4.7k only
MC230CR Esc Futaba
-Good as new
-Case & Manual
1.3k only
-Good as New
-fresh no scratches
800 Php only
-Truggy Tires
-Like new
-Still shiny
-2.2x2.0 Size
2.5k only
-Good as new
-used once
-very very fresh
-w/ orig casing
-manual
5k fix
-w/ auto cut off
-first owner
-Good Condition
2k only FIX
3PK
Futaba 3PK
-Box and Manual
-HRS receiver
-Speedmind Bag
-Extra crystals
P8000.00
No PMs Please. Txt me at 09175362548
-Box and Manual
-HRS receiver
-Speedmind Bag
-Extra crystals
P8000.00
For Sale:
Losi XXX NT with Polished pipe, O.S. max engine ...
just pm ur offers... i'm online daily... thnx
FOR SALE:
Tamiya Tao4 Pro....4kCarbon Fiber chasis
Carbon Fiber upper deck
Carbon Fiber front and rear shock tower
Carbon Fiber Spur gear press
Front and rear universal shaft
Turnbuckle tie rod
Front 1 way diff
Ball diff
Alloy center 1 way pulley
Alloy finned motor mount
Alloy Spur gear adapter
Alloy racing steering set
Hard rear upright
Hard front and rear suspension arms
Front and rear stabilizer set
Full bearings
tao4 spur gears (90t, 112t and 120t)
HPI RS4 Pro 3.....4K
Both kits are hop-uped and in good condition
willing to swap for a Team losi Buggy or stadium truck or xxx-s09208685384
Turnbuckle tie rod
Front 1 way diff
Ball diff
Hard rear upright
Full bearings
SALE SALE SALE
TEAM AE RC18MT RTR - 6.8K ONLY!
WITH:
ORIG. TX & RX
ESC & BATTS
HOTBODIES MINIZILLA KIT - 6.5K ONLY!
WITH:
EXTRA BNEW MOTOR
EXTRA BATTS
UNPAINTED TEAM LOSI HUMMER 2 BODY
EXTRA PINION GEARS
TEAM LOSI XXX4-G+ 4WD BUGGY KIT - 6K ONLY!
WITH LOTS OF EXTRA PARTS
EAGLE MOD FASHION COMMLATHE - 3.5K ONLY! (RESERVED)
WITH 2 CARBIDE BITS AND 3 STEEL BITS
TEAM LOSI BK2 - SOLD!
ALL ITEMS IN EXCELLENT CONDITION
SEND PM OR SMS @ (0917)803-5291
WITH:
ORIG. TX & RX
ESC & BATTS
WITH:
EXTRA BNEW MOTOR
EXTRA BATTS
EXTRA PINION GEARS
Originally Posted by olkuy
Modified Team Losi Mini-T (Ready-to-Run Complete Set)
17K (negotiable)
Serious buyers only. See photo.
0920-5238816
-Well maintained and minimal playtime
-Mamba 25 ESC
-6.8Kv Mamba motor
-Golden Horizons piggyback shocks
-2 pcs. Roadtech NiMH 7.2 battery packs & wall charger
-Tx - FM Futaba 3PJ pistol type controller - PCM 40Mhz & Rx
-Hi-tech hi-torque mini-servo
-GPM blue anodized gear cover
-Extra team losi shocks / stock shocks
-2 bodies - painted and clear (assembled)
-2 pairs rear foam tires (one pair new)
-Extra parts, etc.
-Guaranteed tough and tested
-Reason for selling: With new job, no time to play. I'll be traveling more than usual
-Mamba 25 ESC
-6.8Kv Mamba motor
-Extra parts, etc.
17K (negotiable)
0920-5238816
Walang straight?? Mukhang pure driving skills ang kailangan sa futaba cup ah
Wala pa naman ako nun
Originally Posted by flying G.E.O.
Those are the same batts I saw you testing before? Dalin mo sat lets test it baka cycle lang. You should really get a good tray before buying batts. Hiram tayo batts si oldskul madami and chinacharge ng 7amps kaya ang bilis
about the tray, pinagiisipan ko pa.. kasi baka nga stock touring lang ako.. eh okay naman ung 1300 ko, kayang magrace for 5 or more than 5 mins.. 3 batts na tamiya stick pack na 1300 ang gagamitin ko for stock touring.. pwd na yun diba?
Nakakahiya naman humiram kay sir oldskul ng batts.. eh diba pang TRRS nya ung batts nya?
rush sale.. no swap..
Indy 30A reactor discharger - 1.5k fixed
-discharge nicd and nimh batts..
-discharge sidexside or stick packs
-very good condish
-no box(natapon na kasi eh..)
Pitbull charger - 3.6k fixed reserve till nov. 25, friday
-charges nicd and nimh batts(stick or sidexside batts)
-1-7 amp charge rate
-peak charging
pm na lang ung interesado.. no shipping pls..
almost online lagi..
-very good condish
-peak charging
ALL ITEMS SOLD! THANKS R/C TECH!
SOLD ITEMS :
- HPI Pro4 Complete w/ Hop-ups
- LRP SR (ESC)
- K.O. Propo Hi-speed Digital Servo (PDS-2344)
- Speed Mind Heatsink (Blue)
- Hudy Set-up Tool
- Integy 30 Amp Discharger
- 2-Units NOVAK Smart Tray
SOLD ITEMS :
- LRP SR (ESC)
- Hudy Set-up Tool
BDC : Hindi naman siya Freak!
Geetoo : Ok talaga INGLE NOOK!!!
chicmagnet : Chill..........
