In the interest of maintaining class size, does anyone have a problem with running the open class with the 10.5 class?
This is with the assumption that the open class will be mostly nitro 4wd and a few others. Phil |
I forgot, Touring Car and NASCAR style bodies must be ran in their normal trim. That means on a NASCAR and TC bodies, you can't hang a sidedam and the additional rear spoiler on the body for side and down force.
If you want to run a NASCAR style or the T-HD body, the Buds Super Bi-Level wing will be allowed only in the OPEN CLASS. The latemodel bodies can be tunneled or "decked". Thanks Phil |
Rules - First Draft
LAWRENCE PAVED OVAL CLASSES
Race Schedule Track Preparation: Track preparation will begin as soon as Entire releases the parking lot on race night. Preparation to consist of removal of debris by blowing and / or sweeping the track surface then applying soda to the surface. The track will be closed during the preparation process and until released by a Race Director. This for the safety of the people preparing the track surface. Drivers Meeting: The drivers meeting shall take place between the practice period and the start of the first heat. A breif practice period will be available between the drivers meeting and the first heat, at the Race Directors discretion. Heats: All Heats shall be 4 minutes in length. Mains: All mains shall be 5 minutes in length. ENTRY FEES: We plan to charge a weekly entry fee to cover expenses and lap counting equipment, etc. That fee currently is planned for $5.00 per entrant (car). All monies above the nightly costs will be returned as either winnings or door prizes. This will be determined at the time by the race director. Winnings will be handed out as RC Bucks redeamable at George’s Hobbies. BATTERIES: NimH limited to 7 cells, Lipos to be limited to 2s BODIES: Touring Car and NASCAR style bodies must be ran in their normal trim. That means on a NASCAR and TC bodies, you can't hang a sidedam and the additional rear spoiler on the body for side and down force. The latemodel bodies can be tunneled or "decked". General Rules: 1. No bitching or nasty comments between any or at the corner marshalls. Both will be asked to leave. Second offense unfortunately will not be allowed to return. 2. Car will be randomly tech for compliance. Non compliance will be DG. 3. We are here for a good time and fellowship among racers and besides we are not racing NASCAR and these are toy cars among men. 4. Rough driving as determined by the race director will be a warning for the first offense. Second offense will be DQ for that race. Third offense will be for the night. 5. Race directors has the final word. 6. All racers are expected to corner marshall after their race. CLASSES: It takes three entrants to make a class for that night of racing. All Entrants planning to race on a specific night will be registered before the drivers meeting. Any exceptions must be cleared with the Race Director of the night. Box Stock Class This class will be the RTR class and ALL components must remain as they were when removed from the box. Radios can be upgraded to the Spectrum or other. No changes in motor, battery, speed control, etc allowed. Chassis to be 4wd. 4wd Stock NASCAR Motor: 13.5 BL or 19T Brushed allowed Battery: Any 6 cell NimH battery up to 5000 mah or 2s lipo battery per the above restrictions Body: any COT style molded NASCAR body. Must sport COT style rear spoiler. Last years NASCAR body with the HPI spoiler is acceptable. Tires: Any rubber slick tire on either 24 mm or 26mm rims. Chassis: any 4wd touring car chassis. 4wd 10.5 / Equivalent Brushed class Motor: 10.5 BL, or equivalent rating Battery: Any Nimh battery, Lipos will be 2s per the above restrictions Body: any molded latemodel styled body regardless of manufacturer, NASCAR and TC bodies are allowed per the restrictions in the Bodies section. Spoilers: The rear spoiler will be limited to 2" as measured from the deck. Side dams are optional and limited to 3-1/4" from the deck including any wickerbill at the top and must be supported in a minmum of two places with a solid strap. No floppers allowed. This side dam must be 3-1/2" behind the center of the front wheel and not extend more than 1=1/2" beyond the rear of the car and must be located only on the left hand side of the car. NO extension, supports, thingamobob, or whatumacallit, etc will be allowed on the the remaining parts of the car. All cars are considered to be left hand drive cars. Tires: Any rubber slick tire or foam tire on eirther 24 mm or 26mm rims. Chassis: any 4wd touring car chassis. 4wd Open class: Any 4wd chassis allowed. Body: No restriction on body type but it must cover all wheels and but firmly attached. Latemodel bodies must comply with the above restrictions. TC and NASCAR bodies must comply with the above restrictions . Powerpant: Nitro or Electric allowed. Chassis must be 1/10 scale. 2wd Gearbox class: Any chassis 2wd Only only allowed. Body: Limited to Buggy Type Open Wheel, Stadium Truck, Oval truck, or EDM style bodies only. Powerpant: Nitro or Electric allowed. Chassis must be 1/10 scale. Unlimited Monster Truck Class: This class is open to Truggies, Muggys, 1/8 Revos, and other large Monster trucks. Anything goes but you have to drive the oval. Cutting corners in this class will be grounds for DQ. 1/8 Scale Latemodel Any production based 1/8 offroad buggy/car chassis Can run either Ofna Tire Part number 86505 or Losi Tire Part number LOSA 17768B There will not be any grooving of the tires Does not have to be the pre-mounts, but must be that tire. Must run a OEM 6 gear diff or Torsen diff,in front and rear end of the car May run a working diff or a spool for the center diff There will not be any one way bearings in the driveline Can run up to a 3” Spoiler measured from the deck lid Added winglets can be up to 2.5" high ” x 4.5” in length, maximum of 3 across the rear spoiler. Winglets cannot be rectangular or square in shape. Cannot be any higher than the spoiler. There cannot be any sharp edges. Any Nitro Engine Single speed transmission only No restrictions on window openings Body must fully cover the wheels. |
guys i'm cool with all the rules, except the batterys are a issue. the casing. we are outside plus so many of us have maxamp batterys. which are not hardcase. all the other rules are cool with me but the soft case lipos really should be allowed. i have 4 softcase lipos, been racing everywhere with them for almost 3 years now.
Originally Posted by touringdriver
(Post 5393707)
. Rough driving as determined by the race director will be a warning for the first offense. Second offese will be DQ for that race. Third offense will be for the night.
I thought rubbin' was racin'. Sounds lame. I like to bump, Bump, Bump! That's the sound of the 15's while they're hittin in my trunk. |
Rubbin' IS racin', but punting is meant for football. Turning into somebody with intent to wreck them, AKA "hacking" and close racing is two different things. It would be like if you're inside someone and put them into the outside curb. It's still supposed to be fun.
Originally Posted by LeeLockhart
(Post 5394572)
I thought rubbin' was racin'. Sounds lame. I like to bump, Bump, Bump! That's the sound of the 15's while they're hittin in my trunk. It's way to early to be talking about hacking :cry::cry: |
Novak has a chart that rockstar found. You can see the link if you look on the next page of this thread.
Lee,
I'm not a Zapper Racer, only drive Rogers stuff and I appreciate the comments and they are noted. Later Phil |
I have a 10.5 (venom) that is 4200kv, so I would say it is a 10.5 :D
(Post 5395554)
"Motor: 10.5 BL, 4300 BL, or equivalent Brushed" ????????????
4300 is 13.5. 13.5 is a 19 turn. Haven't you all got the hang of this kv thing yet? Who makes a 4300 that doesn't already call it a 13.5 ,anyway? Castle's motors are 4600's which would be like a 12.5. Their 5700's are like a 9.5. This is the reason Castle motors can't be in spec classes.Now 10.5 is probably equivalent to an 11 or 12 turn. |
Roger. Did you get any Tamaya brand F103 bodies/wing kits in yet? If so take care of the people racing them 1st, but I would like to have one to set back with my F103 for future sell if you have any extras.
Thanks for you time sir & please LMK at your convenience. |
I saw Phils oval body yesterday, looks crazy with the air damn on it. Do guys paint those things?
Starting to look foward to trying one out. Thnking about running a 13x2 checkpoint in the 10.5 class. Would that be the brushed equivalent? Shades where's my Revo punk ;) |
(Post 5393707)
I only have 8000mAh lipos! Soft case NO PROBLEMS!!!!!!!! |
