Ninja Engine by GRP
Old 04-11-2007 | 11:47 PM
  #706
stefan's Avatar
Originally Posted by HarKonnenD
Also, Mike Swauger stated using any other brand of plug will void the warrenty on the Ninja.
Hmm, what's next? Only Mugen fuel? or maybe genuine Ninja mechanic gloves and a special screwdriver for carb adjustments?
Grade A American bullshit if you axe me..
stefan is offline
Old 04-12-2007 | 12:08 AM
  #707
Pooh2's Avatar
Now if he didn't say anything about only using ninja plugs and something had gone wrong guys would have been cryin and sayin how come somebody from mugen didn't post we could only use Ninja plugs? Rc guys r never happy.
Pooh2 is offline
Old 04-12-2007 | 05:47 AM
  #708
MugenDrew's Avatar
So you guys bolt Ford parts on your Honda's?
MugenDrew is offline
Old 04-12-2007 | 07:19 AM
  #709
choisan's Avatar
whatever it works but doesn't hurt, won't matter.
choisan is online now
Old 04-12-2007 | 09:09 AM
  #710
aturbotony's Avatar
For all you motor guru's, if you take the head button off the motor and put in a different plug. you'll see that the different plug does not seat perfect at the bottom of the button
aturbotony is offline
Old 04-12-2007 | 09:25 AM
  #711
I hope noone axes you.
randay is offline
Old 04-12-2007 | 10:23 AM
  #712
Dialed Pile's Avatar
I dont like paying 8-10 dollars for a plug, but I really do not like making sure I have enough plugs for three different engine brands. I am going to continue to buy the corresponding plugs for their engine, but voiding the warranty is a little overboard..? But the ninja plugs are a perfect fit.
Dialed Pile is offline
Old 04-12-2007 | 10:33 AM
  #713
Hmm!!!! sounds like your a little jealous of the grade a american Bs! if you ask me! We dont say nothin about were your from so why bring it up?
J-MAN is offline
Old 04-12-2007 | 11:33 AM
  #714
spenzalii's Avatar
I don't have my manual on me, but I thought I read these motors didn't come with a warranty anyway. I'll check when I get home.
Not that it means a NR or O'donnell plug will be any better or worse for the motor, mind you. All the same, if the factory guy says run 'em, that's what I'll run, regardless of how many NR plugs I already have. They sure aren't cheap, though...
spenzalii is offline
Old 04-12-2007 | 01:42 PM
  #715
Regarding the Ninja engine and Ninja plug issue. If you look at the following page and scroll down you will see where Mike Swauger has commented on the use of the plug.
http://www.rctech.net/forum/showthre...&page=14&pp=40
Mark
munrath is offline
Old 04-12-2007 | 01:53 PM
  #716
Pooh2's Avatar
I trust what Swauger says. Only time things have gone wrong with my car or emgine is when I didn't listen... He has no reason 2 lie. I've seen his engines run. What ever he has 2 say we need 2 just listen! His engines run GREAT!!!
Pooh2 is offline
Old 04-12-2007 | 02:11 PM
  #717
Anyone looking for a Ninja .21? I know NYC Hobbies 718-366-6262 has 2 in stock. Ask for Veets.
vito c. is offline
Old 04-12-2007 | 02:32 PM
  #718
Dynamite's Avatar
only spark plugs and things of this nature :P
Dynamite is offline
Old 04-12-2007 | 02:48 PM
  #719
You cant go wrong with anything Mr. Swauger has to say! i know he has helped me out alot with what i have done!
J-MAN is offline
Old 04-12-2007 | 02:55 PM
  #720
MugenDrew's Avatar
Perfect example Dynamite; If it threads into the hole it must be O.K.
