Tamiya M-07 Concept
#781
Parts slowly trickling in. I look forward to building this.
#782
More M07R pics on rc-mini FB page.
#783
Of course a R version comes out lol. At least I have lost of spares
#785
what Is the part number for the hard tub please
#790
Some one correct me if I am wrong... The stock kit tub chassis is the harder version of the two. The "High traction tub" option part is apparently made with more flex (good for asphalt). The kit chassis is nice and stiff once all assembled. I was impressed after I finished my build.
#791
Tamiya Japan website: "Different material gives optimal chassis flex for excellent road holding, and traction on low-grip surfaces."
Tamiya USA website: "This is a carbon fiber-reinforced plastic main chassis for the distinctive M-07. Compared to the standard fiberglass reinforced chassis, it will flex significantly less under load. This set up is ideal when racing your car on high-grip surfaces."
#792
That depends on who you ask.
#793
Have both
i have both chassis and I can say for certain that the ''high traction" chasis is the softer one. It's made with resin, not much fibres in it (I cut out the grill beneath the motor for cooling) at all. Also, you can clearly feel a difference when tightening screws. The plastic feels soft.
The stock chassis has a lot of fibres in it, and tightening screws makes you wonder if you should have tapped the holes first. Definitely harder and less flexi.
Did it make a difference? I drive/race on a mid traction asphalt track and I have to say the car developed a lot of wandering issues with the high traction chassis. It was a lot less with the stock.
With exactly the same setup, the car underserved more and became a little twitchy.
Hope this helps
Alexander
#794
Hope this helps
Alexander
Hope this helps
Alexander
i persisted with it for 6 race meets trying different things to overcome it but i could never match the times of the stock chassis , for me it was 1/2 to 3/4 sec per lap slower than stock on a 12 second lap and very inconsistent.
i was consistently top 3 then found myself battling to stay in the A main ,i switched back and boom i was back to running top 3
it might work for some tracks but definitley not my local
#795
I have part 54812, which is the tub that comes with the M07R.
Interestingly, the label says carbon reinforced, but the mold says GF-S instead of CF or GF.
........................... I'm not feeling good about this.
