The Drift Thread
#706
does anyone sell deep-dish rims?
#707
I've been racing for about 4 years now and its less and less fun. I'm gonna probably convert my car to drift. I run a TC3 with a Warpspeed demon chassis. What things should I get to go drifting (Tires, motors, etc.) Also could anyone give me a good setup for the TC3?
#708
anthony390 nice rims
Serandin do you have any close ups of the rims I ran at DTP?
Now that I've had a chance to test it, new (no asphalt runs) abs tires seem to work best on a ozite (ish) carpet track also being used for regular racing. Taped rubber tires are ok, but a bit on the sticky side. The guys who had rubber drift tires found the as to be better.
#709
hpi, yokomo, kawada, tamiya, practicly everyone...just some may be hard to find
#710
i belive paz runs the same warpspeed chassis or that might be for his carpet and he as another tub chassis for drifting...
get abs tires, gat any stock motor but if you can get a p2k2 or a monster... usually stock motors with higher tourqe is what you want for drifting.
as for a basic set-up to get you going, run both open diffs with the rear around .75 of a turn tighter than the front, the spring have the rear a set stiffer than the front but you want to stay on the softest set you can get for the drifting aplication..i would use green up front and silver in the back (green is the softer one right?)
and that should get you going
#711
oh yes i did run the blue warpspeed TC3 for one season and it was my worst season ever i just couldnt get it to work i had to shim the diff case up just to get the main shaft to line up with the spur outdrive thats y i got me a Evo 4MS looks like a warpspeed, its blue but, it works
wow i run my TC3 with hard springs yellow front and red on rear and 70wt all round but i am running a 7 single im running 0 degree of camber and toe in, full diffs, rubber tyres or yokomo drifts when im running the 19turn
#712
Originally Posted by anthony390
well update on my car
check out my rear diff case, rear arms, and my rear hubs as well
tell me what u notice
Pictures Removed To Save Room...
im thinking of going back and fine shaping it
Also, does that mod make the rear shock tower any less rigid on the diff casing? It looks like it would flex the whole rear diff housing, but you're the one who did the mod so you tell me. Either way it looks sick, keep it up if it works good for you! I might have to do it just because I can't be anal enough with my diff gears...... they STILL strip out!
#713
Manila drifters on youtube. No rehearsing and practicing for the camera. Just plain drifting.
http://www.youtube.com/watch?v=-tkKAbGNhpQ
#714
Originally Posted by Platinum_Racing
Just one quick question, was that so you could maintain the gears/keep an eye on wear, or was that to save weight? I think I know the answer, but I just wanted to find out for sure.
well the real answer is for looks, weight saves, wear look, meshing, and it doesnt change the rigidy of it
when you said they still strip out do they actually get striped?...are you meshing them correct
#715
can you drift with just rims and no tires>?
#716
#717
Not a good idea
1) Rims are a fairly soft thin plastic and will get destroyed quickly, once you've got a few cracks or chips in the edge your drift will suck (the gaps will catch on stuff and be a very inconsistent surface)
2) If you're running on carpet you'll probably slice lots of nice holes into it. Asphalt shouldn't be a problem other than issue 1).
ABS is cheap, provides long life, won't damage carpet (make sure the edges are rounded off both for carpet safety and for consistent drifts, a sharp edge will catch on asphalt or carper when cornering), and provides a nice flat and consistent surface area.
#719
Originally Posted by Aries326
Anthony,
Great job with the ABS! Looks good!
thanks..i actually tried something new on the rear tires but after 3 runs i didnt like it anymore
what i did was shave the sidewall untill its constantly angled and after a nick the thinest area od the side wall (closest to the rim) would crack off and then show part of the rim
well now i know the best way...dont go over board on rounding your sidewall..if you ever need to round them again after it wears down just take of the whole wheel and then put it on a lathe
#720
Hey guys
I just finished my first racing season on carpet. Need something to have fun with after the races indoors - or at lunch outdoors.
I got a RS4 Rally (Electric) and a old 19T that I can refresh. Its a rally car - so its sits a little high.
Any recommendations for setup to start with.
Stiff or soft springs? Caster (not sure if its adjustable on this car)? Camber? Droop?
Any tips would be appreciated.
