Serpent Project 4-X >
Serpent Project 4-X
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree273Likes
Serpent Project 4-X
Last edit by:
Print Wikipost
Old 04-10-2020 | 07:43 AM
  #961
Billy Kelly's Avatar
Originally Posted by Zbegz
Has anyone purchased the Arrowmax FWD conversion? Or at least seen pictures on the 4x platform?
I recently got an X20, so I'm looking at a conversion to extend the life of one of my 4x, but I cant find much information.
I hadn’t seen that.
Billy Kelly is offline
Old 04-10-2020 | 08:02 AM
  #962
I'm still waiting for some images of that conversion.
DavidNERODease is offline
Old 05-21-2020 | 07:31 AM
  #963
Default Pinion Grinding
I have a bit of a problem, I recently installed my motor on my serpent and the pinion/gear grinds when I roll the car. Also what is a good size pinion to start with?
ozzieramirez is offline
Old 05-21-2020 | 08:31 AM
  #964
Johnny Wishbone's Avatar
Are they new or used gears? Is the mesh set correctly? Gear selection has a lot to do with what motor you plan to run, so you'll have to tell us a little more info.
Johnny Wishbone is offline
Old 05-21-2020 | 08:54 AM
  #965
I have a 17.5 motor and the gears are used. I bought the car a few months ago. The pinion I have now was from a 1/10 associated buggy. The car rolls fine without the gear and pinion touching. Maybe I'm not using the right pinion.
QUOTE=Johnny Wishbone;15642033]Are they new or used gears? Is the mesh set correctly? Gear selection has a lot to do with what motor you plan to run, so you'll have to tell us a little more info.[/QUOTE]
Old 05-21-2020 | 11:32 AM
  #966
[/QUOTE]
OK, so a ballpark FDR for a 17.5 would be around 5.0, track and timing dependent. I'd start there and check motor temp after 3 minutes and go from there. Sometimes used gears just get loud especially if they are worn to any extent. I'm hoping your using the same pitch gears unless your using a Tamiya gear which has a slightly different pitch then the normal gears.
Old 05-21-2020 | 11:39 AM
  #967
What is FDR? What size spur gear and pinion should I be running? I know it varies track to track, but what is a good starting point?
OK, so a ballpark FDR for a 17.5 would be around 5.0, track and timing dependent. I'd start there and check motor temp after 3 minutes and go from there. Sometimes used gears just get loud especially if they are worn to any extent. I'm hoping your using the same pitch gears unless your using a Tamiya gear which has a slightly different pitch then the normal gears.[/QUOTE]
Old 05-21-2020 | 12:33 PM
  #968
[/QUOTE]
If you are running 64 pitch gears, it would be 40 pinion and 100 spur.
If you are running 48 pitch gears, it would be 32 pinion and 80 spur.
Old 05-22-2020 | 01:44 AM
  #969
purplerain's Avatar
[QUOTE=ozzieramirez;15642044]I have a 17.5 motor and the gears are used. I bought the car a few months ago. The pinion I have now was from a 1/10 associated buggy. The car rolls fine without the gear and pinion touching. Maybe I'm not using the right pinion.
Almost all buggy gears are 48 pitch, not the common 64 pitch in touring cars. No amount of messing with gear mesh will work it that pitch is wrong.
purplerain is offline
Old 05-22-2020 | 03:22 PM
  #970
Thanks for the help.
Old 05-28-2020 | 11:08 AM
  #971
morris's Avatar
Hey guy’s,
what would you value 2 used 4x cars at with a bag of parts?
one has a lightened carbon chassi.
morris is offline
Old 05-31-2020 | 10:42 PM
  #972
morris's Avatar
Lack of help in here in here??
does anyone come to this thread at all?
morris is offline
Old 06-01-2020 | 05:45 AM
  #973
Marcos.J's Avatar
Super Moderator
Originally Posted by morris
Hey guy’s,
a friend of mine finally sold his for about $175.00
Marcos.J is offline
Old 06-14-2020 | 03:41 PM
  #974
Jochim_18's Avatar
if anyone have 4x they what to sell hit me up.
Jochim_18 is offline
Old 06-16-2020 | 05:57 PM
  #975
Default Oily rear end
Bought a project 4 and drove it around on driveway and I noticed the rear end was oily. Before I tear it apart, what area should I focus on? I didn't put this one together so I am not familiar with it. Is this normal?
