Serpent Project 4-X >
Serpent Project 4-X
Like Tree272Likes
Serpent Project 4-X
    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Old 02-17-2018, 11:44 PM
  #496
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by RKeasler
Manual says 14 mm what do they need to be to get a median ride height of 5.5 mm or so with the linear suspension set installed ? Struggling with ride height from left to right since installing
THe right height is too low now huh? I forgot the number. But I had to shorten them quite a bit. Try 12mm each and go from there.
snuvet75 is offline
Old 03-06-2018, 01:04 PM
  #497
BardSmith's Avatar
Trader Rating: 64 (98%+)
In regards to the roll center inserts on the bottom of the bulk heads which of the three options will provide more traction. I know there are many many variables to all this but what affect does the MidLow, MidHigh, and High each have.
BardSmith is offline
Old 03-06-2018, 04:44 PM
  #498
snuvet75's Avatar
Technically speaking, as you know, high roll center makes the car roll quick and hard and stops the roll. low RC makes it roll longer and deeper. So high RC in low traction and low RC in high traction is a general idea.
Roll center is prob one that has the most conflicting opinions on and the effect of changing lower arm positions has been very different from car to car for me and I think it has something to do with each car's stock roll center position. Unfortunately RC crewchief doesn't have Project 4x info yet. It would let us understand expected result from changing roll center much better. Just by eyeballing it, stock position seems very low but the arms are much shorter than other brands so you should take that into consideration.
In my 17.5T, I have mid high lower arm inserts and car is very stable in low- mid grip asphalt. The effect was very noticeable when it was changed from mid low setting.
In my mod car, I have mid- low RC (only because I want to make both RC's work for a challenge and I was lazy so didn't want to change the lower arm position. you guys know how hard it is to change the lower arm position in Project 4x once assembled lol). I had to thicken the rear roll dampening/springs quite a bit to stabilize the rear out of exit which was quite puzzling at first but I think the rear might have rolled too much too quick hence lost grip. When I changed the roll springs to softer ones, it got worse. I haven't had enough time to test it further on my mod yet.
But as you see, most use stock mid low setting and they are all fine. So as you said, it depends on the rest of the set up and I'm sure you can make either work.
Please share your experience too.
DavidNERODease and Byronf1 like this.
snuvet75 is offline
Old 03-06-2018, 05:01 PM
  #499
BardSmith's Avatar
Thank you for the awesome response.
Old 03-15-2018, 07:43 AM
  #500
Red RC ? RC Car News » Serpent Project 4X Evo 1/10th touring car kit
Been waiting for this for like ever. Looks really good but I do wish the drivetrain layout was more centered (belts more centered like Mugen, Awesomatix, Yokomo, Gizmo, Schumacher). I'm still on the fence with which exotic TC (A800, 4x, GZ2) to go for and hence still fooling around with other standard TC's - it's so fun to build new stuff).
Billy Kelly likes this.
DavidNERODease is offline
Old 03-15-2018, 02:08 PM
  #501
snuvet75's Avatar
New heave shocks, new upper braces, new linear suspension links, new lower rocker links, new motor mount and new upper bumper brace. Did I miss anything? Can't tell if roll dampers have changed or not.
snuvet75 is offline
Old 03-15-2018, 05:30 PM
  #502
New lower chassis plate with large cut outs in the front and rear.
snuvet75 likes this.
Old 03-19-2018, 10:43 AM
  #503
So is the new heave shock a bladder shock?
Old 03-19-2018, 10:51 AM
  #504
I'm looking at the Evo manual and I'm not sure what's going on here?
Old 03-19-2018, 10:53 AM
  #505
Ahh, a foam bladder.
Old 03-20-2018, 01:03 AM
  #506
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Which is curious
Awesomatix just went from the foam bladder in the rotary shocks to a shaft and o ring seal (which I must install some day...)
nexxus is offline
Old 03-20-2018, 09:55 AM
  #507
snuvet75's Avatar
Well, however they did it, as far as it doesn't leak, it wouldn't really matter much to me. I hope they also made the cap for the shock a bit tighter as it tends to unwind sometimes.
snuvet75 is offline
Old 03-25-2018, 05:01 PM
  #508
Benzaah's Avatar
Trader Rating: 24 (96%+)
This shock design with the foam was used in the original 411 shocks and also in the 1/12th scale which is where these parts have come from. Still mildly Pia to build but at least it doesn’t leak.
Benzaah is offline
Old 03-25-2018, 06:47 PM
  #509
nexxus's Avatar
Ran the 4x in a bit of testing on the weekend (bought one that had the VTD and other upgrades fitted) noticed it had a tendancy to oversteer mid corner which was new... All other cars I have encountered off power oversteer (so I reduce droop) but mid corner....
*stumped*
nexxus is offline
Old 03-25-2018, 07:30 PM
  #510
*stumped*
Could have been a case of the chassis rolling over too much and bottoming out meaning the carbon was sliding through the corner instead of having the tires carrying the weight. Increase the rear roll spring rate by 1 step and see what happens
Have to take a new approach to setups on this car.
WagwanBumba is offline
