Serpent Project 4-X >
Serpent Project 4-X
Like Tree272Likes
Serpent Project 4-X
    Hide Wikipost
Old 11-21-2016, 06:09 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Serpent Project 4-X
Last edit by: WagwanBumba
Introduction
This is a wiki page for the new and very interesting concept 4-X from Serpent. This is wiki is meant to develop and grow as more is understood about the car.
Serpent's Product Page - http://www.serpent.com/product/400030
The 4-X Development Story - Here
Manual - Here
Spring Chart
SOFTEST
  • 401705 Spring white C4.4 4X (2)
  • 401706 Spring yellow C4.9 4X (2)
  • 401707 Spring orange C5.5 4X (2) = kit
  • 401708 Spring red C6.3 4X (2)
  • 401709 Spring pink C6.9 4X (2)
  • 401710 Spring blue C7.6 4X (2)
  • 401711 Spring purple C8.4 4X (2) = kit
  • 401712 Spring greenC9.5 4X (2)
  • 401713 Spring grey C10.9 4X (2)
  • 401714 Spring black C12 4X (2)
HARDEST
Build Tips
RCBuilds.net Build, tip guide and youtube video - http://www.rcbuilds.net/builds/onroa...nt-project-4x/
Heave + Roll Damper Build Tips
Pivot Ball Nut Tip
Setups
Setup Tips
Ride Height Adjustment
Adjusting tweak with roll damper
Usage of washer on lower arm
Tuning ARS
Option Parts List
Social Media
Facebook 4-X Group
Print Wikipost
Old 03-25-2018, 08:49 PM
  #511
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by nexxus
Ran the 4x in a bit of testing on the weekend (bought one that had the VTD and other upgrades fitted) noticed it had a tendancy to oversteer mid corner which was new... All other cars I have encountered off power oversteer (so I reduce droop) but mid corner....
*stumped*
I don't understand your statement. So you got a used car and that was your first run. And you noticed oversteer mid corner. And all other cars "you have encountered"- does that mean you have driven or you have seen?- ALSO oversteer mid corner. But yours is on power and the others are off power?
snuvet75 is offline
Old 03-25-2018, 09:09 PM
  #512
erchn's Avatar
*stumped*
We need a setup to base advice off of, that’d be very helpful.
EE
erchn is offline
Old 04-05-2018, 09:50 AM
  #513
So what is the "play" like on this car? I assume you can adjust the play(slop) on the pivot balls but what about the rest of the chassis?
DavidNERODease is offline
Old 04-05-2018, 10:51 AM
  #514
snuvet75's Avatar
You've been researching this car for months already my friend. Just get it and get over it lol.
Play is not really significant anywhere. Some slop on steering rack just like any other car. Since 4x uses pivot balls in uprights, if you don't tighten the nylon screws to fixate the balls well, there will be play there. Pillow balls and ball joints are pretty tight fit that you may have to pinch the joints or burn with lighter a bit in some of them.
DavidNERODease likes this.
snuvet75 is offline
Old 04-05-2018, 11:42 AM
  #515
Default Evo
I will be making an offer to my LHS this Friday because this image http://www.serpent.com/files/img/1234582935b.jpg
is stuck in my frontal lobe.
Old 04-05-2018, 11:55 AM
  #516
I also finally got to see one in the flesh at the Canadian Nationals. I apologize to the owner for any drool I may not have wiped off.
Old 04-15-2018, 12:13 PM
  #517
Airwave's Avatar
Is there a shop where the new "bigger" springs are available?
Having only the one present in the kit is bothering me...
Airwave is offline
Old 04-16-2018, 09:14 AM
  #518
Looks like my LHS (Action Hobbies Kingsville) will get signed up with the Serpent dealer so the 4x Evo will be added to my arsenal
Old 04-16-2018, 01:36 PM
  #519
And as soon you decide they make radical changes... Entire suspension assembly is raised up to match typical touring car role centre positions I assume. New hubs and both lower and upper arm are much higher now - only on the rear apparently.
http://ets.redrc.net/wp-content/uplo..._wilck-ch4.jpg
Old 04-16-2018, 02:51 PM
  #520
Airwave's Avatar
I think the arms remain identical, it is just the rear hub which is now different from the front one. And with this new part, you will have to mount the arm closer to the center if you want to use the same arms...
Airwave is offline
Old 04-18-2018, 12:10 PM
  #521
Well, I still want one I thought somebody would have one by now - anyone know if the Evo kits are actually shipping yet?
Old 04-18-2018, 12:27 PM
  #522
Sorry, looks like A main got them yesterday.
Old 04-18-2018, 05:51 PM
  #523
RC MARKET's Avatar
rcmarket.com.hk
instock
RC MARKET is offline
Old 04-18-2018, 06:39 PM
  #524
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Evo
Ok going to assume the shocks will fit the old 4X, also which length control rod is the correct one, to fit to the first gen car. Going to fit the new parts to mine, control rods being most important.
RKeasler is offline
Old 04-18-2018, 07:20 PM
  #525
nubs's Avatar
I don't think they will fit.
nubs is offline
