Tamiya TA07 pro
#844
A's are too narrow in the front. You will traction roll. Run C-C in the front
#850
You'll be way off pace then. Black carpet is a lot different than grey carpet. If you are going to King, just do yourself a favor and glue dem sum bitches. Not unless if you like being a second or so off pace. You'll be chasing setup all day long. Of course it depends who shows up as well. hehe Do just the fronts.
#852
Trader Rating: 89 (100%+)
front
C/C should be standard in the front........
#853
I'm looking to get one. If anyone has one for sale. If not, when I order a kit. What else is needed? I got the electronics covered Sways,spool or what spring to start in asphalt ? Not sure what diff came with the kit
#854
I had some serious traction roll issues, and adding 1.5mm shims to my outer camber links solved the problem.
#855
I haven't built mine yet but the advice I got was hard front parts, Spool, and I also picked up some of the aluminium bling(steering, pulleys, etc). I have yet to get the motor mount pieces.
