NEW XRAY T2
#797
All,
I have been given permission to answer any technical detail questions about the T2 that you all may have. Fire away...
#799
Originally Posted by teamgp
All,
#800
Will the T2 function properly when the Sun and moon are perpendicular in relation to the earth causing a period of twin paradox magnetism?
#801
Originally Posted by Rogier
Will there be parts of the FK05 re-usable in the T2??
* ball diff
* multi-diff
* diff hub bearings (10x15x4) - for rear only
* drive shaft plastic caps
* 5.0mm double bevel shoulder pivot balls (outer camber links and steering linkages)
* hex screws (only certain applications)
* servo saver plastic covers (chassis & top deck)
* both servo horns
* shock parts: rubber membranes, all o-rings, alum adjustable nut, e-clip (1.9 & 2.3), washer 3.2, all fixed & adjustable pistons
* alum servo mounts
* composite battery backstops
* antenna mount & tube
* All hudy wheels
#803
Originally Posted by Scho
Is the T2 able to run on water?
#804
#805
Originally Posted by L.Fairtrace
Is a oneway included? I really wanna be fast on carpet.
Sorry I had to do it.
Only in non-US kits.
#807
I should probably clarify that I'm able to answer questions regarding all of the parts included in the T2 kit. I don't have all of the information concerning the optional parts at this time.
#808
could you please list all the bearing size, particularly the ones in the wheel hubs, as I want to order some ceramics.
#809
Team GP also forgot to mention the front and rear belts will transfer over as well. (30-5431) front belt (30-5442) rear belt.
#810
Qty...Size...Use
2...5x8x2.5...Ball Diff (each)
1...F3-8 3x8x3.5...Ball Diff (each) - axial thrust bearing
12...2.4mm...Ball Diff (each) - pulley bearings
10...5x10x4...Layshaft (2), Frt/Rr wheel hubs (8)
4...10x15x4...Frt/Rr diff hubs in the bulkheads
2...4x7x2.5...Servo Saver
