NEW XRAY T2
#2761
new xray t2
Originally Posted by lbckevin
I bought mine from Jbenthobbies and had it shipped down to Socal and have had no problems with the car with tweak and hubs. I took my time and assembled it per the instructions.
Ask Brian Kinwald, Chris Tosolini,Todd Hodge,Jason Ertractor,Josh Numan,Mike Truhe, Billy Easton, Greg Hodapp and all of the other factory drivers that run at Socal, if they ever put their car on a tweak station, NONE DO.
They set ride height, droop, camber and caster. The main thing to do is to assemble the car right the first time, pay attention to the instructions. Make sure shock length is the same for all four shocks.
If they hit something, they loosen the screws and retighten them and put it back on the track. I watched Bk race for years, telling me the tweak stations are bogus, its how your car drives on the track, Dont waste your money.
I enjoy my T2 and if you have any legitimate problems, voice them to RC America....They have great customer service and will take care of you.
#2762
If you hit something, you broke it !!! Its not the cars' fault that you hit something. Take it like a man and get a new chassis, its all part of racing. I broke two chassis on my FK05, because I hit something. Its my fault, that I hit a pole.
corallys NEVER needs tweaking...the losi guys are all stuck in the mind set of Jr. the tweak stations that bolt all four corners are hurting ..the MIP is the real deal...9 times out of 10 the corally is the most consistant car that stays flat on the MIP station...if you guys are still setting your tweak with your droop start looking for some other type of work...Tweaking your car after heavie hits has got to suck..lol....
#2764
new xray t2
#2766
new xray t2
What setups are you looking for?
#2768
I run on rubber tires on asphalt, high grip , indoor at Socal Raceway,CA
I run the medium stiffness setup from the manual:
Sorex 36R tires with Zenon Blue inserts.
multi -diff in the one way setting
Rear diff is fairly tight.
-1 degree of camber all the way around
Stock rear toe with two shims in rear and one shim up front.
Shock postions, and roll centers are straight from the manual.
I run stock oil and springs
Ride height is set at 5mm
Droop is at 4 front and rear ( measured under arm) on standard droop guage, non Hudy.
Kevin
Kevin
#2769
Every car I have ever had tweaks from race to race. Thats why before each run I back every screw off, no matter what. If you look at any of the pro drivers they all do the same. Its about makeing the car as perfect as possible everytime you put it on the track. Than, just to double check i put the car on four scales, and only 3 times have I not had to adjust a car on the scales.
If you don't want to work on a car from race to race that is on you, but every car needs it.
#2770
Results speak for themselves: Track changed on 1/31/06.
01/31/06
Best Heat Lap/Time for SPORTSMAN STK SEDAN:
KEVIN SMITH with 29/5:09.35
-- SPORTSMAN STK SEDAN - A Main --
Pos Car Laps time name id avg.mph
1 8 29 5:05.72 KEVIN SMITH 4 12.94
2 9 27 5:02.51 MATT O'BRIEN 25 12.17
3 2 27 5:04.31 BILL LEWERENZ 17 12.10
4 7 25 5:11.03 SCOTT PETITCLERE 44 10.96
5 4 25 5:12.26 CRAIG NORDSTROM 29 10.92
6 5 14 2:46.74 RYAN B. 12 11.45
7 6 7 1:19.12 DON D. 11 12.06
01/24/06
KEVIN SMITH with 33/5:09.19
1 2 33 5:04.20 KEVIN SMITH 6 14.79
2 1 32 5:03.27 HIRO 5 14.39
3 5 32 5:05.71 CARL HYNDMAN-pro 30 14.27
4 6 32 5:09.35 ERIC KIM 27 14.11
5 3 31 5:06.46 TAKA 4 13.79
6 4 31 5:08.87 BOB HAYES 35 13.69
7 7 30 5:00.34 KYLE 22 13.62
01/17/06
TONY PHALEN with 33/5:04.65
1 5 33 5:00.56 TONY PHALEN-pro 16 14.97
2 1 33 5:06.95 KEVIN SMITH 14 14.66
3 7 32 5:00.22 HIRO 8 14.53
4 2 32 5:04.74 BOB HAYES 12 14.32
5 8 32 5:05.72 ERIC KIM 30 14.27
6 3 31 5:05.92 ALEX NAVARRETE 25 13.82
7 6 31 5:09.13 KYLE R. 24 13.67
8 9 30 5:02.14 ALVIN MA 23 13.54
9 4 29 4:45.42 EDAGR FIALLOS-pro 28 13.86
01/10/06
KEVIN SMITH with 28/5:02.85
1 6 29 5:07.42 KEVIN SMITH 5 12.86
2 3 28 5:04.83 HIRO 3 12.53
3 5 28 5:05.45 BOB HAYES 20 12.50
4 7 28 5:07.92 MIKE MOLINA 8 12.40
5 1 28 5:09.64 ERIC KIM 29 12.33
6 4 27 5:01.50 ALVIN MA 22 12.21
7 8 26 5:04.10 TAKA 2 11.66
8 2 26 5:05.15 EIJI SASAKI 4 11.62
Doesn't seem like the car has any problems.....
Kevin Smith
01/31/06
01/24/06
01/17/06
01/10/06
Kevin Smith
#2772
new xray t2
Not if you can run with Mr P
#2774
new xray t2
Tony Phalen driver exstordanire
#2775
WHo is Mr. P ?
