Tamiya TB-Evolution III
#211
As previously posted, the builder quoted about 1435grams =3.1pounds including electronics but no body.
#213
Re: EVO3 Drive train
Originally posted by madjack
Has anyone else found the need to break-in the drive train on the E3?
My car seemed to have a rough spot that would hang up when rotating the spur.
http://groups.yahoo.com/group/tamiyatrf/
#215
Ref weights
My standard built Evo III is 1460grams
When I fiited L/W shafts and titanium screws it was 1438grams about the same as my 414WCR
#219
The screws and shafts are both tamiya
53502 42mm REAR SWING SHAFTS (Alloy)
And just match the screw sizes. All theses I get from Rainbow Ten in Japan:cool
#220
I'm almost done with my EVO3. Any evo3 owner plz tell me what 48pitch spur should I use for stock racing? thanks
#224
Took the car for a spin today at an indoor track (concrete with ashphalt surface).
Used the stock settings with 60wt shock oil instead of Tamiya oil. Used rubber tires (Take Off 27).
Powered with a Team Orion Core stock motor, geared at 6.25. Very nice to drive and very punchy coming out of the corners. Did not notice any torque steer.
Did run into a problem after a heavy collision.
Stripped a tooth from the front diff gear and bent a blue alloy universal shaft ($$$$ ouch). Looks like I jarred the propellar shaft which resulted in the stripping. While I had the diff out I put some ceramic grease on the front which may help in the future. This seems to be common with shaft cars (like my Barracuda) so I can't really fault the Evo3 for this.
The diff gear was pretty easy to replace but next time, I'll run the stock steel universal shafts instead, at least on the front
Thank goodness Tamiya includes lots of diff gears as spares with the kit.
#225
Originally posted by KINGZJ
use the largest one you can fit. The new RD ones are very nice about 1/2 the thickness of a kimbrough.
