Tamiya TB-Evolution III
#1741
Originally posted by davioh
hehe...maybe...what does it do...the torque rod....and so whats with installing it? doesn't come with the e3?
#1742
oh okay...so it didnt' come with an evo 3?
#1743
the torque rods run from the top of the steering block back to the upper chassis... its purpose is to reinforce the steering block to prevent change in caster during hard cornering, plus it also somewhat prevents the block breaking in a crash. they came on the TA04R and the 414 series...
#1747
Updated Carpet Foam Setup
Hi,
I tried some new ideas for my foam setup. Mainly I reduced the rear toe in to 0.5 from 1.5 and played with the roll center, spring rates and shock mounting locations.. I also changed the front hing pin blocks around.
You can find it at
mPowered-racing.com EVO III FOAM Setup
The car has a very quick turn in and is well balanced mid corner. It rotates through the corners very very quickly.
You can find it at
#1748
ooo....i think i nkow what a torque rod is now ....is it the wishbone thingY?
#1749
davioh do u own a evo 3?
#1750
evoIII
Hi Martin
i had a blast watching you and your Tamiya friends Racing at the Ottawa Championship.
I also got in to the A main qualifie 6 in stock ruber and finish 6 first time out with this Baby.
#1751
#1752
hence the name tb evo driver on my sig....
but i think it should come with more options like this and also come with a front diff and one-way.
i'm still having trouble with the servo saver sticking, anyone else have this problem? just need to order a KIM201 saver.
also my servo is crap, what will a high performance servo do for my lap times? thanx guys.
#1753
here are a couple o pix of my wcr sway with caster rods... it could prolly use some lil collars between the mounts, but seems to work good so far... just go to this album marked "rc stuff"
webshots album
webshots album
#1754
damn! what did you do?! you did it! 414 style! hehehehe
#1755
tamiyadriver - what size turnbuckles did you use for those toque rods?
and whats the part No. for that swaybar kit?
