Tamiya TB-Evolution III >
Old 04-08-2003, 05:54 AM
  #1711
davioh's Avatar
to prevent the body from moving?
davioh is offline
Old 04-08-2003, 08:05 AM
  #1712
Evo 3 for sale first 200 bucks takes it am from S Cali
mugenracer is offline
Old 04-08-2003, 08:30 AM
  #1713
Trader Rating: 21 (100%+)
as was explained to me by some top drivers in the world at the Reedy Race of Champions last year, the extra body posts in places are to keep the bodies from deforming while driving at very high speeds.
lot of the time bodies will deofrom under wind resistance and develop pockekts, and places for the airflow to get trapped.
the most common i can think of is where the hood turns into the windshield, a lot of the time the body can flex at this crease in the mold.
(wish i was a good enough driver to be able to tell if my lap times were tenths slower because my body was deforming under high speeds!)
peter
peter_robinson is offline
Old 04-08-2003, 08:47 AM
  #1714
Aluma's Avatar
wow, i guess he dont care much about his servo... no servo saver! unless thats one SMAALLLL servo saver we dont know about....
Aluma is offline
Old 04-08-2003, 09:01 AM
  #1715
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Mugenracer check your pm
OVA is offline
Old 04-08-2003, 09:13 AM
  #1716
davioh's Avatar
whats a servo saver?
davioh is offline
Old 04-08-2003, 01:30 PM
  #1717
Alan you are correct on the center supports but through all the pics it looks as if Surikarn started the event with no center bracing and then addded them as the event progressed if you look at the ones on LRP's website they are there but not in a direct side shot. We are hoping to see some of these updates at Reedy.....
Davioh it prevents the servo from stripping on a direct load(hit) most of the pros do not use one as it does aloow slight to major slop depending on the MFG.
Difuser is offline
Old 04-08-2003, 01:58 PM
  #1718
racer's Avatar
would like some opinions from some of you, which would be better for performance.
the rubber sealed bearing kit that tamiya has or re-oiling the stock bearings?
Thanks in advance
racer is offline
Old 04-08-2003, 02:01 PM
  #1719
Registered User
go to http://www.xe.net/ucc/
Aku-Man is offline
Old 04-08-2003, 02:11 PM
  #1720
Holmenkollen's Avatar
Hi guys,
if you some good pictures of Suirkarns EVO 3 visit : www.tamiyaracing.net
Holmenkollen is offline
Old 04-08-2003, 02:39 PM
  #1721
GTMilenko's Avatar
thanx alan1467 , i thought it might just be bad luck.
GTMilenko is offline
Old 04-08-2003, 04:03 PM
  #1722
I am still running the factory bearings. Peter is running the rubber sealed both cars spin the same when clean but Pete's run longer between details. They also seem a touch smoother but not much
Difuser is offline
Old 04-08-2003, 08:28 PM
  #1723
davioh's Avatar
so are the rubber shielded ones recommended? or keep the original?
davioh is offline
Old 04-08-2003, 09:18 PM
  #1724
DNQ
DNQ's Avatar
Default Alternative Spur Gears?
Does anyone know if a third party is making spur gears for the TB Evo yet? I think the plastic Tamiya uses for the spurs is too soft. I have little rocks on the street outside my house that have already eaten up some of the teeth of my spur after only running a few packs on my Evo.
Yeah, I know Tamiya pinions are pretty soft too, but I know the alternatives for those. Just wondering who else might make alternative spurs from a harder plastic or plastic compound. And if anyone lives around the San Francisco area, what shop carries them nearby.
DNQ is offline
Old 04-08-2003, 09:41 PM
  #1725
dsrbltoys's Avatar
I've seen both the HPI's and the RW's on the EVO III
dsrbltoys is offline
