Team Associated TC7 & TC7.1 Touring Car
#2656
If you run way too thin on high bite, it will diff out: into the corners and in sweepers it will over-rotate instead of holding a line, and it will also diff out on power and you'll lose forward drive.
If you run way too thick on low bite, it will feel like a straight axle: into the corners and sweepers it will over-rotate, and it will spin out on power.
I find it's important to match the diff fluid with the amount of traction you have available, and then fine tune from there.
#2657
Looking for some feedback/advice. I'm still struggling to get my used 7.1 rebuilt. With the 4 screws snugged down in the front of my top plate, the back of the top plate does not line up with the bulkhead screw holes. If I try to move the rear over it twists the front bulkheads. If I flip the top deck over it's still bad enough to concern me. If I loosen the 4 screws in the front and try to center the rear over the holes in the bulkheads it still does not line up well. I bought this graphite chassis off of ebay on the recommendation of a fellow RCTech'er, but I'm wondering it that might be the problem or maybe the top deck is junk. Any thoughts or feedback would be appreciated.
******Sorry, I figured it out. Just loosening and then re-tightening the front bulkheads took care of the problem!******
#2658
Good question. If you're way off, the effect can be very similar if you're either too thin or too thick.
#2659
#2661
#2664
Still racing the TC7 on carpet , Tc6's Outside Not really by Choice
#2667
what's you guys rear end setup on black carpet? just had my first go at it w/ the 7.1 on black carpet (after running on grey for a few weeks) and i'm trying to get the car to rotate how i want it. my current rear end setup, generally is 7k rear gear diff, rear belt is kinda loose, 1.5* camber seemed to be where i had to stay for it to not overrotate. 1mm droop ORH and 2* rear toe
#2668
New model rumored in the fall.
#2669
