Slapmaster Tools MS2.3 >
Old 11-20-2005 | 01:12 AM
  #31
cementsurfer's Avatar
Hey Brian, I just bought one of your diff thrust kits, and it looks like it's gonna work awesome! Great product, keep it up!
cementsurfer is offline
Old 11-20-2005 | 01:43 AM
  #32
Originally Posted by Slapmaster6000
Here's Hyperdrive's website: www.hyperdriveracing.com
Their parts that I use are:
HK-0007 damper tubes
HK-0008 ball studs
HK-0009 2.56 nuts
HK-0003 upper plate
There are three major online hyperdrive suppliers,http://www.lefthander-rc.com/catalog/index.php, http://members.willinet.net/bmurdock/MURDOCKRC/, http://www.rc4less.com/
Hyper1 is offline
Old 11-20-2005 | 11:24 AM
  #33
Slapmaster6000's Avatar
Jesse, I think that you will be impressed too. You will be able to build your diff and forget about it. Unless one of your buddies "spur" you, will mostly never have to look at the back of the car this season! I continue to run a diff that was built the start of '04-05 racing season without any maintenance. And its just as smooth.
Thanks for your support.
Thanks for the Hyperdrive sources!
Brian
Slapmaster6000 is offline
Old 11-20-2005 | 10:26 PM
  #34
Number 11's Avatar
Any ideas where I can get HK-0008 ball studs I can't find them at the track or on any of the sites listed. I can't complete the car until I get ball studs.
Number 11 is offline
Old 11-20-2005 | 10:48 PM
  #35
litespeed-dom's Avatar
The 2/56 ball stud for your tubes???
Go find a hobby shop that carries a big Du-Bro selection, hobby shops that carries airplane stuff usually will have this. Du-Bro part# 181. It's description is "2-56 Threaded ball link", about $1.55 each. Each package includes a 2/56 ball stud that is perfect for out application, some other hardware, also a clear ball end that you can use for the CRC tubes as well!
Try to call around and find it, if not pm me before noon and I can go to the shop that I found these during lunch and check it out. I also have 3 new packages in my 1/12th box. And I know I still have 4 on my car if needed. I can send them up USPS priority mail, should get there in about 2 days.
Dom
litespeed-dom is offline
Old 11-20-2005 | 10:49 PM
  #36
Scottrik's Avatar
Did Weylin run the 5.5 or 6.5 motor? Are you finding you're having to do anything special to get the GTB/Velociti system to run in 4-cel fettle? Is a receiver pack necessary?
Many thanks,
Scottrik
Scottrik is offline
Old 11-21-2005 | 06:06 AM
  #37
Number 11's Avatar
Dom just checked Tower and they have them. I searched up and down that site last night and couldn't find anything. Once you gave me the part number bing up it came. Thanks again for the help.
Old 11-21-2005 | 07:29 AM
  #38
purpurite's Avatar
FWIW, the CEFX dampner tubes will also work, and they use 4-40 ball links on both ends of the tubes. If you're partial to using 4-40 ball studs and links like I am, you will appreciated the CEFX tubes.
They are short enough and fit perfectly (actually, the dampner widths on the CEFX are very close to the MS2.3). I'm going to see how well the CEFX pod will match up to the MS, but from my initial measurements, it looks like a perfect fit.
purpurite is offline
Old 11-21-2005 | 07:35 AM
  #39
Thraex's Avatar
The only problem is to find CEFX parts...
Thraex is offline
Old 11-21-2005 | 07:38 AM
  #40
purpurite's Avatar
I got my dampner tubes and other CEFX parts from www.stormerhobbies.com. www.kthobbies.com also carries CEFX parts, though everyone's stock appears to be low right now. Josh must be behind.
Old 11-21-2005 | 08:10 AM
  #41
I've tried to put the pods on my old CEFX into the MS last winter. CEFX pods are a bit longer, it'll lengthen your wheelbase. Unless the CEFX pods are different now...
Dom
Old 11-21-2005 | 08:47 AM
  #42
purpurite's Avatar
Ooooh, good point. Out of curiosity now, what is the wheelbase of a MS2.3 built with the suggested parts? I'll have to measure some of the dimensions of the CEFX to see how it compares.
Old 11-21-2005 | 09:02 AM
  #43
MS wheelbase is identical to an L3. CRC T-Force is a bit shorter and CEFX is the shortest of all the cars out there right now. I don't have the exact measurement of all 3 cars.
Dom
Old 11-21-2005 | 01:43 PM
  #44
stumper1's Avatar
Default 2-56 ball studs
Allen,
I have some extra 2-56 ball studs if you need them. I should be at the rain Friday.
Deric
stumper1 is offline
Old 11-21-2005 | 02:56 PM
  #45
Number 11's Avatar
Thanks Deric if none come in by Wed I will check with you Friday. I really like to try this car out soon.
