Tamiya FF04
#271
I agree. The tbevo6 black edition came with the black aluminum blocks. The ff04 evo should have been the same.
#272
Nice, I am also building mine. What size of 48p pinion and spur you are running? I plan to set my FDR at 4.5 but I have no experience with 48p gear. What I worry is the physical size of gears which I can fit them in. Coz I find that the motor slot does not have much room for back and forth adjustment. I find in rcMart a pair of Kawada 70T spur and 40T pinion, not sure if they can fit properly? Your advice is very much appreciated, thankyou!
#273
This is a gear chart I put together for myself, you might find it useful (link to OneDrive). https://1drv.ms/x/s!Aq0DyLRFrfad7hUx...qCmXY?e=z1IIxH
70/40 won't fit, you will need to find a smaller spur.
#274
There is also this gear chart you can use. https://www.tqrcracing.com/rc_tools/gearing.asp
#275
Thank you very much for you all valuable info!
#276
Q: I just went through the manual and saw that the ff04 is using the trf 418 suspensions arms (#54569), combined wit the ta05 ifs c hubs (#54031), why? would the trf 418 c hubs (#54580) work?
thanks
thanks
#277
#278
Thanks... So trf 420 suspension upgrade could be also a problem I dont thought of...
#279
Hey Tom! Can you share more pics of your FF-04? I like the 420 ball caps like the one your using. I also ordered for my FF-03.
#280
Last thing, I modified, where the rear uprights. These are now exchanged to the 2° aluminium ones from 419XR.
#281
Thank you!
Very nice!
Very nice!
#282
@tom which damperstay are you running with the ssbb? or front and rear stock ff04?
#283
These are not the SSBB. The shocks are the kit included normal Big Bores. I only exchanged the thread collars to the large diameter ones for use of large diameter springs. Also the spring perches are large diameter. The original small diameter springs were too soft for me, especially in front.
#284
aaahhh ok, sorry! and thanks for the information
#285
Is anyone still racing these? I just picked one up for our clubs open class where a few guys run FF with 21.5T motors for fun. Last thing I need is a body - what are people running? I'm mostly worried about getting one that will fit. I'm just running an old Speed Passion 21.5T until the end of the year, so next year will get a new motor and probably need a new body by then too (if not after the first race day)
