Tamiya TRF419
#2416
If this was a wonderful thing to do, the shocks would come that way from factory (holes drilled in the caps) Not claiming to be an expert, it just doesn't seem correct..???
Someone want to do a video on it or pictures?
I get air in my shocks quite often but I never race onroad 1/10 electric or nitro.
I race 1/8 buggy, 1/10 truck off road.
I am new to this scene... please be patient with me...
#2417
Hey ic-racer, did you get full rebound in the way you built your shocks or something else?
Well for me in building the Yokomo SLF II Short shocks for the 419 and my new BD7 2016 I am still getting full rebound, maybe a more slowly rebound and not as forcefully as before. I cannot build a low or zero rebound shock it seems.
I did not drill a hole in the plastic cap yet but compressed the shock shaft in all the way minus about 2mm then put on the bladder and capped it and held the shaft in that position until the cap was on tight. So not sure what is going on yet.
Watched Jilles Groskamp's video.
I then take the R and L shocks and press them into each other, shaft-to-shaft. This lets me see if they both have the same pressure in the bladder. If they both reach full compression at the same time, the bladder pressures are equal.
In #4 there is almost no pressure in the bladder, as if there were a hole in the top of the shock. Again with model cars maybe foamy can be faster if everything else is set up around doing it that way. I have an engineering background so I have to build my shocks like #1 above or else I lose sleep...
#2418
To behave like a full-size automobile shock the bladder has to have a lot of pressure. To maximize the pressure I use a foam pellet and put the lid on the shock with the piston all the way out. Like #1 in my animated GIF above. So, yes the shaft sticks all the way out when done. If it does not then I have a problem with the build and not enough pressure in the bladder.
Yeah interesting. The older Tamiya shocks used the Urethane Foam pellet on top of the bladder and under the shock cap, but now not called for but there must of been a change in the shock cap design to hold down the bladder.
I guess all automotive shocks that are not front strut with spring have full rebound and shocks mostly are like gas charged. I remember changing my shocks on my Silverado truck to the Rancho ones and they came compressed enough in a long strong twist tie setup where you install on the bottom mount and line up the top mount and undo the twist tie setup as it goes out and hard to push back in with any manual labor.
#2419
Guys for different one piece suspension mounts at the front of the fronts and rear of the rears is it the TB-03 mounts that are the ones?
#2420
You'll notice from team driver setups from any manufacturer that 100% is very rarely, if ever, used.
Have you tried running shocks with limited and zero rebound?
It might cause you some insomnia, but will improve your lap times as well
#2422
I build my trf shocks the exact same way as explained. The only time Ive ever really seemed to not get 0 rebound was when i didnt get all the air out prior to putting the bladders on the shock would end up with a bit of rebound. Then I would start over and spend a little extra time getting all the bubbles out and try again my shocks would always end up with 0 rebound. Ive never had to use the bleeder hole option. Sometimes loosening the cap a bit and compressing the the shaft and retightening will even work for me.
I also noticed with most shocks when the piston is at the top of its stroke it pushes against the bladder (don't know about modern Xray). This is with the bottom spring perch installed, and the shock compressed all the way. I think this is a shortcoming of the design, but in use the shock should never compress that much. That said, I would still like shock shafts a bit shorter (of course one can use some shims to limit travel upwards).
#2423
#2424
I think inconsistency is also introduced capping these shocks, you put the bladder on and squeeze oil out, try to use tissue paper to absorb up some oil, then rest the plastic top mount cap on the bladder and then screw on the outer ring like cap to tighten that down, but you fiddle with the threading and disturb the bladder, things like that.
I don't think it would be too costly to come up with a different design.
I actually almost would prefer to fill and bleed somehow the shock on the bottom side if there is a way. The small bottom cap would be easier to deal with.
#2425
Yes, if one is building a DeCarbon/Bilstein monotube gas shock, by design it needs to be pressurized to prevent foaming or air entry around the shaft. If you don't build it pressurized you don't get the anti-foaming benefit of the design. Also, If you don't build it pressurized, on full rebound the pressure in the bladder is actually negative with respect to atmospheric and it is functioning like a concentric two-chamber shock whereby the chambers are separated by the diaphragm rather than separated in the two concentric tubes. Full size non-gas pressurized shocks have been around like that for years but they have a tendency to foam so the DeCarbon/Bilstein gas shock style is favored in many full-size automobile or motorcycle racing settings.
For RC cars in racing settings maybe foamy is better. In fact the 'aeration shock' is based on that.
#2426
I didn't mention that the reason I started building my shocks with gas pressurization is that when 1/8 on-road racing a few years ago I built my shocks without pressurization and had to re-build them every race due to foaming and air entry around the shaft. When they are pressurized air is less likely to get in around the shaft and foaming is less likely. So, when I switched to 1/10 electric on road I still build my shocks pressurized. Thought I'd like to try the aeration shocks and see how they compare.
#2427
Look what I and a few others have been working on in the lab.
http://www.thercracer.com/2016/03/ta...nd-blocks.html
3D printing is pretty smart
#2428
Nice work. Is that a F style Separate Suspension mount for a parallel arms situation or something more narrow when putting the actual F block in the very front for a toe out type suspension which I find most have on their setups in general and a local T4 racer says offers more stability?
#2429
I went yesterday for the first time my 419 with the short shock and the short shock towers. Had no tracksion and my rear overtook me when relent.
Could change what I wanted but nothing helped.
The worst thing I ever had on Track.
Become put everything on top.
The worst Tamiya I ever drove
#2430
Trader Rating: 89 (100%+)
short shock set up?
When I drove that set up on my 417 Raceberry conversion I experienced the same handling characteristics, it required a really hard spring up front.
