Tamiya TRF419
#2266
The roll bars are a joke on these TRF cars but they still make a significant affect on track. 419 have to be the last chassis with this roll bar system from Tamiya.
#2267
A good article: http://www.thard.co.uk/anti-roll-bars-setup/
(well at least that's exactly how I do it :- )
#2268
Yeah, with the current system, there's a lot of suspension travel before any effect is felt at the other end. I think in the near future most cars will move to the system you see on Xray cars (and others). That and the fact that roll bars are not going to impact things that much. Maybe if you're fighting for the last hundredth of a second. Most people have more important problems though.
#2269
I'm sure there's other articles out there, but here's the first one I could find on how to install/setup swaybars on a TRF car. It's from a 417, but the approach isn't significantly different:
https://tchub.wordpress.com/2012/07/...-build-part-5/
Paying attention to the little details is important. For example, making sure the grub screws are not too tight, but not too loose. If you're still having trouble, find an experienced hand at your local club to check it out.
Phil.
Phil.
TYVM
#2270
went to track today and I broke 3 C hubs.
Being a bad driver is expensive... I am gonna focus on running clean from now on.
I also lost my front swing shaft during a crash... Luckily, I found it on the track. Otherwise, i would have to spend $50 to get a set.
Do you guy know if Tamiya make a set of plastic , soft version of the c hub?
Guys at the track told me I may want to run plastic c hub so it flexes upon impact.
#2271
New ones are natorious for breaking on slight impact.
But until now I broke one only tho!
#2272
Talking about holding onto older cars, after selling one of my 417's I dragged out the old 416 I had on the shelf for some mod running. Ran well with a set of aeration shocks. I then found a spare 417 Smokem motor mount, and went to town on my CNC machine. here is the final product on the left, raceberry 417 on the right. 80mm width, 2mm top and bottom. Short shocks also. So 416 front and rear suspension, steering, and 417 motor mount, and a chassis shaped like the RB. First race this Friday
#2273
Bad Main last night with marshall in the straightaway that I smashed into. This car is like uncontrollable on carpet in 17.5 class even. I am sure I have some faults like using used Sorex 28 tires, Dodge Stratus 3.0 bodies from 10 years ago, but I mostly have the setup close to the carpet setups some of you posted. I will post soon later today my setup or what I changed yesterday.
Here is a video of why I think I want rigid separate suspension mounts on front leading and rear trailing blocks. That 1F block has got to be bent now good.
+ https://www.youtube.com/watch?v=SSl2mYoti8M" title="View this video at YouTube in a new window or tab" target="_blank">YouTube Video | |
#2274
Yesterday I completed my Tamiya TRF419.
I'm not too happy with the short shocks 42273. The 25mm spring are simply too long and you can see it in the picture. Front I came up to 5mm (further down does not work) with the spring (Yokomo Pink Front and Rear Blue). But rear I still have a little room (with the blue spring).
I ordered the wrong shock towers that have just the wrong height, unfortunately too early happy.
Should have to wait for the even shorter shock towers. I`m a litte sad aboud that
I want to go next week to test times and especially the 2mm chassis with steering brace on carpet. I'm very curious how it work together
For me, 23mm Spring would be the best choice. But there is nothing ... people ... business idea
Pictures attached:
Pictures attached:
#2275
Simmi, you should of bought the Raceberry towers.
With them you could of use the T4 shocks
#2276
Simmi so Xray dampers did not come good on the track?
#2277
#2278
Your tires are definitely not the problem, Sorex 28R are excellent tires. My FF04 EVO goes like shit of the shovel with them on.
Those are also kit springs huh? Get some Yokomo springs for carpet.
#2279
Double post
#2280
Pictures attached:
Pictures attached:
It will take you 5 mins to swap them from your 419 shocks onto those.
I have a new set-up that I will put on the site today / tomorrow from a racer who used them at Grand Prix des 3 frontiers in Longwy.
If you want to use the X-Ray shocks then the others are available here.
http://www.fibre-lyte.co.uk/fl/cars/tamiya/trf419.html
There are quite a few guys who have both sets and use them depending on what tracks they run on. It seems most prefer the 25mm spring ones over the shorter 20mm ones but that is because their is a wider choice of springs.
