Tamiya TB Evo 6
#1397
Converting my 17.5 chassis to a USVTA car. Going to have to add a bunch of weight. There is tons of space under the center of the main drive shaft, but it would be great if there was a way of securing it other than tape or show goo.
What would be really nice (if they are not already in production) are some holes added to the centerline of the chassis, and a custom made brass or tungston Exotek weight system.
Hint hint.
Hint hint.
#1398
Hint hint.
Hint hint.
I wouldn't use contact adhesive, by the way (too difficult to remove).
Can't you drill the holes where you want them?
And on the topic, wouldn't it be more useful to add weight at the corners rather than the centreline (at least some of it)?
#1399
Nothing is wrong with tape, shoe goo comes off pretty easy, and no it is not better to add more than 150g at the corners.
But hey we used to double side tape to hold steering servos down, and that didn't need to change did it? Or why all these battery hold down systems, just use tape? Progress that's why.
No I can't drill the holes myself in the weights, I don't have a drill press, CNC machine, or anything other than a dremel tool to manufacture a custom weight system.
So how about tying to put up something positive instead of condescending.
#1400
There's nothing condescending in my suggestion.
Just didn't understand what you wanted. Now I know. You want progress, embodied by holes you can't drill because you can't be arsed to buy a drill (you don't need a drill press - a pathetic puny one will do). Got it.
By the way, double sided tape is progress. It replaced nuts and bolts that need holes you can't drill.
Here's something positive for you : rent a brain.
Good luck.
Good luck.
#1404
#1405
Looking forward in getting some track time with this beast this weekend. I will let you know the results. Last time out on carpet I had way to much steering and no rear bite. Going to thicken up the shock oil a bit and go with the 1k in the diff. If it starts to push then I will go up on the diff fluid.
#1406
Does the thicker fluid "slide" the rear tires around the corner to get more turn it? I had always thought that the thinner the fluid, the more free the rear would be to rotate at the cost of "diffing" out on power in sweepers.
#1407
Finally, built my Evo6 and run it for 2 nights. Much louder than belt driven, as expected. The car runs straight without much trimming all the time, unlike some other shaft driven cars. As most of the Evo6's parts are graphite and aluminum made, I thought this is a pro kit car category in Tamiya. However, one of the local hobby shop's owner and a guy, who runs XRay T4 2016, mentioned that Evo6 is a mid range car and not a pro kit car. I really wonder how does one define whether a car kit is of pro type and is there a standard to define pro kit car? Anyone can explain? Thank you.
#1408
#1409
The EVO 6 is every bit as capable and as tunable as an x-ray. X-rays are good, but then again, they better be for that "luxury" price. It's only with the t4-16 that they included ECS drive shafts. Somethin that is standard on many other kits now. The EVO also gives you aluminum goody bits all over that are options on an X-ray.
#1410
I'd be interested to hear other's experiences on diff fluid on carpet. I'm sure it varies set up to set up to some degree, but I have experienced that when I go too thick on rear diff fluid (5K) I loose steering. I was shocked to read that some folks run 7K.
