Tamiya TB Evo 6
#1174
Dave,
Like the silver parts you've stripped. What mag cleaner did you use? Think I'm going to do the same.
Have you got Eric Wippler's carbon drive shaft yet? The drive shaft, Exotek's or R1's lightened out drives in the rear really give this chassis a ton of forward bite out of the corner. Both of these items combined will save you 10-12 grams in the drive train. If your going to run 17.5T, try theTB03 aluminum ball diff (54056) too. It holds up great as far as rebuilding with a 17.5T. Another large weight savings in the drive train over the Tamiya gear diff. If you want to stay with a gear diff, try the Spec R (SPR009-TB) Sean @ TQ has both diffs in stock.
Tamiya gear diff - 25 grams
Spec-R gear diff - 19 grams
TB03 Ball Diff - 14 grams
Lee
Lee
#1175
I'm sticking with stock parts so far, but I think this is what Lee is talking about
http://www.exotekracing.com/7075-rea...etc410-1-pair/
#1176
Trader Rating: 27 (100%+)
Has anyone ran into a warped pair of drivetrain gears? The gear on the spur and gear it mates to are slightly warped causing a slight bind. I'm not too concerned as I'll be going exo soon but wondered if anyone has seen it and how it was remedied.
#1177
Isn't parts missing from the TB03 aluminum ball diff (54056)? If so, what do I need to complete it?
#1178
Trader Rating: 89 (100%+)
http://www.tamiyausa.com/items/radio...diff-set-54522
#1181
#1183
