Tamiya TRF418
#467
#468
Next Sunday first time I drive on carpet with my 418
I setup my car like Marc Rheinard Setup sheet on carpet:
petitrc.com/reglages/tamiya/setuptrf418/TRF418_MarcRheinard_Hrotovice2013110103
Hope it will work
Hope it will work
#470
#472
418 traction roll problem. Hi help please. my setup.
carpet.
tires, sweep 32
front springs tamiya yellow
rear springs tamiya black
35 weight associated oil
Any suggestion guys to eliminate this?
carpet.
tires, sweep 32
#474
Trader Rating: 89 (100%+)
SPRINGS
you need harder springs especially in the front try blue maybe but something harder than yellow
#476
Can i just use my std Tamiya springs? do I need to change the retainers? If I want to use the larger springs should I get the Ride TC springs or the Yokomo or Hpi springs?
(I am racing carpet mainly)
Regarding the centre pulley, mine has a little play / movement nothing excessive though
#477
#479
Today i had the first race with the 418 and man is this car fast.
The car was super quickly and easy to drive, i did use the 6° front C-hubs.
It was a small track and my fastest time (7,59s) was about 0.6 seconds faster the the second fastest guy.
But once again, the swing shaft pin protector is a very weak part, i had to replace one again.
But overall a very impressive car that drives really smooth.
Me happy
Me happy
#480
I have a set of 6 deg hubs to try as well.
Was the track carpet or asphalt? any set-up pointers?
