Like Tree2Likes
Tamiya TRF418
Old 01-08-2014, 05:53 PM
  #451
Moving Diff?
Has anyone else noticed their diff moving from side to side in the bulkhead? I'm running a front diff and it moves too. The movement is perhaps 1 to 2mm total from side to side, if this needs to be shimmed what size shims do you use on a diff?
c2tcardin is offline
Old 01-08-2014, 11:16 PM
  #452
sosidge's Avatar
Originally Posted by c2tcardin
Moving Diff?
There is some float, I doubt that if you measured it it would be as much as 1 or 2mm. You can use 10mm inside diameter shims to take the movement out, I don't actually think it is an issue myself, it keeps the drivetrain free running and I can't see that the outdrives end up fouling any other parts.
sosidge is offline
Old 01-09-2014, 07:15 AM
  #453
Trader Rating: 42 (100%+)
418 Springs? the extra springs that come with the kit - are they hard springs? Can anyone help me what springs to get when running carpet. thanks.
noworries is offline
Old 01-09-2014, 07:18 AM
  #454
sosidge's Avatar
Extra yellows are harder, about HPI silver/Tamiya Blue equivalent. Extra Reds are soft, about old Tamiya Red equivalent. Kit Blacks are medium, about old Tamiya Yellow equivalent.
You will probably need to run another manufacturers springs to get the fine differences between rates that most people are looking for. Seems the team drivers are mostly setting the car up with Yokomo or HPI springs. I've got ARC springs to hand.
sosidge is offline
Old 01-09-2014, 07:24 AM
  #455
Originally Posted by sosidge
Extra yellows are harder, about HPI silver/Tamiya Blue equivalent. Extra Reds are soft, about old Tamiya Red equivalent. Kit Blacks are medium, about old Tamiya Red equivalent.
Thank you very much for your help
Old 01-09-2014, 08:12 AM
  #456
maxepower's Avatar
Exclamation 418 kit?
Anymore 418 kits available thru online hobby stores?
maxepower is offline
Old 01-09-2014, 08:22 AM
  #457
Smokem Racing's Avatar
We have some listed in our online shop, along with other goodies like the Hiro Seiko Blue aluminum and titanium screw kits for the 418.
Smokem Racing is offline
Old 01-09-2014, 09:33 AM
  #458
maxepower's Avatar
Talking
Your got P.M.
  #459
Thanks, I was thinking the same thing regarding keeping things free running and it doesn't seem to disrupt anything. At least as far as I could tell.
Old 01-09-2014, 10:17 AM
  #460
How are the new 6 degree C- hubs
Working compared to the 4?
Atechbh is offline
Old 01-09-2014, 05:19 PM
  #461
is it work???
asuradahk001 is offline
Old 01-09-2014, 09:44 PM
  #462
Been testing the 418 yesterday and the car runs great, did some minor adjustments to the standard setup and the car is great to drive and caries a nice cornerspeed.
I did notice that the swing shaft protectors are very weak, i've lost one of them at the front and i didn't had any crash at all.
I think the material is to hard, i need some better ones.
Does anybody know what brand that has some better swing shaft protectors, along with a part nr
addicted2blue is offline
Old 01-09-2014, 09:57 PM
  #463
CraigM's Avatar
Trader Rating: 34 (100%+)
I'm still on my original set of blades (3 race meets) running 4.5t!
The Arc blades are stronger if you need an alternative - #R101030
CraigM is offline
Old 01-10-2014, 06:44 AM
  #464
418 on carpet. I just wanted to chime in to anyone who is looking to buy the 418. I have run several xray cars and found out the other day straight out of the box (I do need stiffer springs though) on carpet the car I think is amazing. I feel I am faster than my T4. I do know some people have said the 418 is not a carpet car but I find that far from the truth. I love it.
Old 01-10-2014, 08:46 AM
  #465
+1..... I think it's great on carpet!
