Like Tree2Likes
Tamiya TRF418
Old 11-12-2014, 06:58 PM
  #1951
JimmyMac's Avatar
Originally Posted by cplus
Xenon & panaracer = same thing! different packet.
The stock spur works fine with 64p pinions. It's not "identical" but it is so close it doesn't matter. Even TRF drivers run them (with non tamiya pinions)
Different material.
JimmyMac is offline
Old 11-13-2014, 12:37 AM
  #1952
niznai's Avatar
Originally Posted by sosidge
Stop being a dick niznai.
0.4mod and 64 pitch are virtually identical. You can run 64dp pinions with the Tamiya spur.
I won't bore you with the calculation that proves this as I am sure you are knowledgeable enough to do it yourself.
Wow. Close, but no cigar sir (so to speak).
I've mixed and matched metric with 48pitch in the past, it is not good enough.
Respectfully,
your dick.
niznai is offline
Old 11-13-2014, 01:53 AM
  #1953
Respectfully,
your dick.
he is talking about 0.4 mod and 64dp. These are totally interchangeable, I've been doing it for years with no issue. 48dp is totally different
Qatmix is offline
Old 11-13-2014, 02:25 AM
  #1954
thank you guys for all the advise..cheers
fuse01 is offline
Old 11-13-2014, 03:42 AM
  #1955
Originally Posted by JimmyMac
Different material.
Really? I have both and cannot tell the difference.
If they are different material, do you know what the actually difference is?
Respectfully,
your dick.
Who said anything about 48p? That is miles off.
Cheers
cplus is offline
Old 11-13-2014, 06:55 AM
  #1956
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Xenon
Panaracer
Similar, not same
2 of the best gears on the market
Unbelievable quality in material, design, and execution
RedBullFiXX is offline
Old 11-13-2014, 03:10 PM
  #1957
b20btec's Avatar
.4 tamiya
64 pitch = .3968
Pretty darn close.
b20btec is offline
Old 11-13-2014, 05:08 PM
  #1958
sohlman's Avatar
Trader Rating: 92 (100%+)
TCS GT1 carpet setup from this past weekend at Middle River Hobbies. 418 definitely works better in slower classes.
sohlman is offline
Old 11-13-2014, 05:20 PM
  #1959
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Used a Tamiya 96T (.4 Tamiya) spur (from my TRF101) on my TRF418. No issues with a regular 64 pitch pinion. Another local racer did the same and had no issues.
niznai just thinks everyone should not disagree with him.
Dan is offline
Old 11-13-2014, 08:15 PM
  #1960
niznai's Avatar
Or that I should be in agreement with no one.
Depends what you want. 64 pitch is silent like a shy ghost such is the mesh. I take it that is a sign of how efficient it can be. A metric/imperial mesh will never be as silent hence I conclude something is not quite as perfect as it should be. Either way, I don't sell pinions or gears.
niznai is offline
Old 11-14-2014, 12:32 AM
  #1961
Salkin's Avatar
A couple of questions to the setup up sheet:
What does the "Full" means on the tires?
You don't show you have added extra weight, but the setup sheet shows a total weight of 1442g. Mine with a 7000mah GensAce, Mazdaspeed6 body weighs 1330g. Need to add 20g ow weight to reach the 1350g minimum weight requirement. Everything else is box stock, no titanium screws etc. Is it your lipo that makes all that weight?
Do you run with or without the single screw in the top deck near the motor?
Salkin is offline
Old 11-14-2014, 06:06 AM
  #1962
sohlman's Avatar
"Full" is the amount of traction compound used. Covered the full surface of the tire.
I didn't add any weight. For TCS racing, you have to use Tamiya bodies and the Ferrari 458 is super heavy. Sure, I could have used one of their lightweight bodies, but I didn't have a chance to buy/paint one. Also the new ORCA 7500 pack is kinda heavy too. When I run regular club races, I add weight mostly in the center and/or electronics side.
Yes, top deck center screw was used.
sohlman is offline
Old 11-14-2014, 07:07 AM
  #1963
Salkin's Avatar
Thanks!
Salkin is offline
Old 11-25-2014, 12:52 AM
  #1964
Salkin's Avatar
The manual instructs to add grease on e.g. the shaft blades.
I have replaced the front shaft spool cups with a type so I don't need blades in the front.
I add a little AW grease there also, because it's metal against metal.
Do you all use grease in these places, or can I stop using it if I accept some extra wear, and replace more often.
Will I gain less friction in the drive train if I don't use the sticky AW grease?
Was talking to some Xray drivers (T4'15) and they did not use it.
Salkin is offline
Old 11-25-2014, 05:55 AM
  #1965
Trader Rating: 77 (100%+)
Does anyone know the part number for the front cups so i can stop running blades? Also does it take any modding or just fits perfect?
Thanks.
goin2drt is offline
