Like Tree11Likes
Tamiya TB04 Pro
Old 12-22-2013, 03:17 PM
  #376
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Probably the arms were not spaced right to begin with. Sometimes, flash on the pivot balls doesn't let the ball seat all the way, so even if you shim it perfect, it's wrong in a couple of runs.
Re shim the arms and have another go at it.
CraigMBA is offline
Old 12-22-2013, 09:15 PM
  #377
Originally Posted by alwin
This is my first post on this forum. Yesterday, I ran my TB-04pro for the first time: high grip carpet, Carson 16T and Tamiya A-type. This will be my car for Tamiya Cup TW class.
The steering is so sweet, the car impressed me. After 5 packs, I looked at the rear arms more into detail and found out that their was a lot of slop. The arm could be moved back and forward. I saw on the track another TB-04 with the same problem.
What happend? What parts are worn out? Arms, plastic spacers? Another problem maybe? My TA-05v2R has the the same rear suspension, but build in CF and the spacers are in aluminium; no wear here.
Thanks for your input, Alwin
If it's like mine and you are running the stock plastic suspension mounts, it's probably just the mounts shifting a little. If I push the rear mount forward while tightening the screws there will not be any play but after a run or 2 the play comes back. I just put an extra shim in to take care of it.
By the way, has anyone heard anything about a carbon tub coming out soon. My chassis has a twist that comes back every run .
cj72 is offline
Old 12-23-2013, 03:39 AM
  #378
Thanks for your input. I've rebuild the rear suspension and it looks ok now. Probably, I was a bit cautious not to over tighten the screws into the plastic.
I'll see how it looks like after a few runs.
alwin is offline
Old 12-23-2013, 11:54 PM
  #379
CW22's Avatar
Trader Rating: 110 (100%+)
Default TB04PRO
Merry Christmas....
CW22 is offline
Old 12-24-2013, 06:12 PM
  #380
Wow that looks awesome. How are these working on carpet tracks? Also how does it work with the 6 degree caster compared to 4?
Has anybody switched from a TA06 which is what I currently use on carpet?
Atechbh is offline
  #381
Atechbh is offline
Old 12-24-2013, 07:13 PM
  #382
CW22's Avatar
Default TB04PRO
Haven't try at carpet yet. Is another great product from Tamiya.
I can't tell the different between 4 degree to 6 degree, but the car handle good in the corner as is stock set up out the box.
Thanks.
CW22 is offline
Old 12-29-2013, 12:00 AM
  #383
mac853's Avatar
Could anybody tell me if possible to fit those 418's arms(plastic parts) on TB04?
mac853 is offline
Old 12-29-2013, 04:46 AM
  #384
Airflow's Avatar
Why is the drivetrain noisier than belt drives? Is this normal?
Airflow is offline
Old 12-29-2013, 04:57 AM
  #385
Yes it can
Juan Aveytia is offline
Old 12-30-2013, 09:21 AM
  #386
mac853's Avatar
Thanks!
If somebody did this could please report something abou how the car behaves with 418 parts.
Specially on small tracks!
mac853 is offline
Old 01-09-2014, 02:14 AM
  #387
NItrox416's Avatar
Hi guys,
I would like to know how long are your new short dampers?
Can they reach approx 54/55 mm
Thank you for the help
NItrox416 is offline
Old 01-09-2014, 06:47 AM
  #388
maxepower's Avatar
Talking Noisey but fast!
I have a TB-03 and it is noiser than my TA-05. Shaft cars have gears in the drive train that trasfer power to the tires, this gives a sound that the belt drives don't have. But, if not shimmed correctly it can be much louder a sound. I can't decide which car I like better but the torque coming out of the corner on a shaft car is awesome and the smooth acceleration of the belt drive is easy to manouver through the corners is so easy to drive.
The TB-04 has an extra set of gears to compensate for the motor at 90 degrees from the shaft so again if not shimmed properly it can make a lot of noise and bind the drivetrain.
I race at the Tamiya track here in Aliso Viejo and it's hard to compare the three chassis but based on the last Speedtech race, the TB-04 made podium the first time out, now that is impressive!
Just my 2$
maxepower is offline
Old 01-10-2014, 02:03 AM
  #389
NItrox416's Avatar
Originally Posted by NItrox416
Hi guys,
Please is important
Old 01-10-2014, 01:06 PM
  #390
How have the 6 deg C-hubs working out?
Atechbh is offline
