Tamiya TB04 Pro
#361
Anyway, are carbon reinforced ones break easily to be too much stiff?
Best regards
#363
Best regards
#364
the stock c-hub and uprights are too soft, on the other hand. they tend to feel inconsistent on the track. that's why i tend to use the stock arms but upgrade the c-hub and uprights to carbon reinforced.
but that's just me... and by no means am i an expert driver. just thought i'd share my $0.02.
#365
Oh, really ?
My bad from my experience with Xray
#366
BEFORE i use stock GF parts, running 13.5 turbo, car is bad...
after replace CF parts form 416, problem solve...........
#367
Could anyone tell me why many people looking for steel bevel gears for diff, please?
Do they really need?
Best regards
#368
#370
I have been running 13.5 and haven't broken a single part with the stock arms on my TB04 pro.
As mentioned above, the kit ones will give more grip than the CF strengthened ones.
#371
Anyway, maybe Tamiya and Xray plastics are totally different, this makes me so confused.
Thanks!
Thanks!
#372
will the 2007 nsx body fit the tb04, thanks
#373
what servo and esc for tb-04?
i am looking to start rc racing and wanted to buy a tb-04 to start out with
i have build a wr-02 (suzuky jimmy) before, but the shop sold a complete set with all needed components.
now for the tb-04 i am kind of lost and not sure which parts to order to complete the car so i have 3 questions:
1. what kind of servo or what kind of specifications for a servo i should be looking for?
2. and the same for a esc?
3. its just to start out with in a stock series, so it will be used with a tamiya 540 engine, but i might want to experiment with other engines outside the series what would be a good option?
thank you for any advice you can give me
#375
This is my first post on this forum. Yesterday, I ran my TB-04pro for the first time: high grip carpet, Carson 16T and Tamiya A-type. This will be my car for Tamiya Cup TW class.
The steering is so sweet, the car impressed me. After 5 packs, I looked at the rear arms more into detail and found out that their was a lot of slop. The arm could be moved back and forward. I saw on the track another TB-04 with the same problem.
What happend? What parts are worn out? Arms, plastic spacers? Another problem maybe? My TA-05v2R has the the same rear suspension, but build in CF and the spacers are in aluminium; no wear here.
Thanks for your input, Alwin
