Like Tree11Likes
Tamiya TB04 Pro
Old 10-16-2013, 10:49 AM
  #211
CraigMBA's Avatar
Trader Rating: 22 (100%+)
While I'm waiting for my kit to arrive, I mocked up a pinion and the brass sleeves. I can get a 51 in there no problem. That gets FDR to around 3.72 (51/76), no bueno for GT3, but real close for GT2. And looking at the optional motor mount, I think there's even more room:
If you can get a 52 in there, you're at 3.65 and that's close enough. Plus, you can probably fit a smaller spur in there without adjustment with the bigger pinion.
CraigMBA is offline
Old 10-16-2013, 11:02 AM
  #212
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Good to know Craig! Thanks!
RAL is offline
Old 10-18-2013, 09:07 AM
  #213
rtypec's Avatar
Motor mount with a 48tooth pinion and no room for movement
rtypec is offline
Old 10-18-2013, 10:15 AM
  #214
CraigMBA's Avatar
Where does it hit? On the corners?
CraigMBA is offline
Old 10-18-2013, 10:54 AM
  #215
rtypec's Avatar
It touches everywhere. I basically looked for the largest pinion that would drop in.
rtypec is offline
Old 10-18-2013, 11:21 AM
  #216
IndyRC_Racer's Avatar
A person I race with locally in VTA came up with a solution to get the gearing/FDR he wanted for his TB04. He has access to a machine shop, so he fabricated a part(s). Tonight is his debut of the TB04 in VTA. If I can get a good picture of his solution I will post it.
At our local track we typically run anywhere between 3.6-3.8 FDR. From talking to him, he could go much lower. He would never sell/manufacture anything, but at least it might inspire others to duplicate his solution.
IndyRC_Racer is offline
Old 10-18-2013, 03:19 PM
  #217
Rod, get the dremel out. I know you like keeping things pretty. But screw it. I see lots of metal that can be removed.
Juan Aveytia is offline
Old 10-18-2013, 04:04 PM
  #218
OSherman's Avatar
So long to GT2 racing with this car....
OSherman is offline
Old 10-18-2013, 06:55 PM
  #219
CraigMBA's Avatar
If the rules don't allow for grinding out the 1mm that needs clearance, I'll grind it out anyway and use this car for VTA.
Winner!
CraigMBA is offline
Old 10-18-2013, 07:30 PM
  #220
AllenCheung's Avatar
front row!
AllenCheung is offline
Old 10-18-2013, 09:37 PM
  #221
CraigMBA's Avatar
I've had the kit for about two hours, and I'm no longer sweating gear.
That's a 54 (as big as you can go before you hit the screws), it is a PRS pinion (wider than a CRC), it turns and doesn't hit. It looks sano, and took about two minutes using a dremel sanding drum. With a 72 tooth spur, FDR of 3.33. The instructions give a measurement for pinion location, it's 14mm, that's where mine is.
I put a pm into Fred and asked if this is okay per TCS rules. For the life of me I don't know why it wouldn't be. They allow tb-03 users to mill the chassis so a lipo fits flat, and this isn't part of the chassis.
CraigMBA is offline
Old 10-18-2013, 10:12 PM
  #222
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Sometimes I think Tamiya is still in this little world of theirs where only silver can motors and shotgun style batteries exist.
Dan is offline
Old 10-19-2013, 01:13 AM
  #223
That is not modifying the chassis in any way. That's just a spacer to attach the motor. I don't see any reason why it wouldn't be legal. Show it to Fred.
Old 10-19-2013, 04:30 AM
  #224
What's the internal ratio of this car?
addicted2blue is offline
Old 10-19-2013, 05:42 AM
  #225
izzyracer's Avatar
Trader Rating: 27 (100%+)
Anyone taking this car to TA today?
izzyracer is offline
