Like Tree34Likes
Schumacher Mi5
Old 10-01-2013, 05:47 PM
  #1456
Trader Rating: 38 (100%+)
I had one leaky diff out of 3. I measured everything with calipers and found the plastic was molded the same on all but the thickness of the o-rings on the leaker was slightly smaller. I have since replaced the o-rings with ones from a rebuild kit and no more leaks.
linkless is offline
Old 10-01-2013, 08:32 PM
  #1457
TryHard's Avatar
Originally Posted by poop
mine was like that too. ended up running an extra o-ring and it hasn't leaked since. just remember to check and change your shims accordingly.
hope this helps.
Also, liberally coat the o-rings on the drive cups with black greese. Helps a lot to seal them up better.
TryHard is offline
Old 10-03-2013, 12:54 PM
  #1458
What kind of servo saver are you guys running, and do you use the option servo plate intended for servosaver ?
If I put in an Xray servo saver, and move my servo all the way back on the servoplate, then the sterring rods from the servosaver to the steering rack bind. There simply is not enough space for the servo saver.
Is the option servosaver the solution ?
Shock Tower is offline
Old 10-03-2013, 01:13 PM
  #1459
Car Breaker's Avatar
Originally Posted by Shock Tower;126009?5
What kind of servo saver are you guys running, and do you use the option servo plate intended forlotrvosaverinput f I put in an Xray servo saperfectand move my servo all the way back on the servoplate, then the sterring rods from the servosaver to the steering rack bind. There simply is not enough space for the servo saver.
What servo are you using ? I used a Xray servo saver with KO RsONE 10, fit perfectly. Now I use the stock horn and like it a lot. Steer input is much faster and centers perfect thanany servo saver.
Car Breaker is offline
Old 10-03-2013, 01:18 PM
  #1460
SteveM's Avatar
Trader Rating: 165 (100%+)
I'm using a Savox SG1251MG with a Tamiya heavy duty servo saver and it all lines up perfectly.
SteveM is offline
Old 10-03-2013, 01:22 PM
  #1461
I'm running the Kimbrough 201 on asphalt but switched to the HB TCXX on for tight indoor carpet to get some more steering since the arm is the same length as the stock Schumacher servo arms.
cgroves is offline
Old 10-03-2013, 02:01 PM
  #1462
With IIC only days away, do we have a head count for Mi5's? I know I will be bringing 3, though one is currently unopened.
linkless is offline
Old 10-03-2013, 03:06 PM
  #1463
I've got two for 17.5 and amateur 17.5, super stoked after last weekends high traction testing on the carpet at Lou's. Motors and batteries sucked but the chassis was very nice.
cgroves is offline
Old 10-03-2013, 06:44 PM
  #1464
The Teacher's Avatar
Trader Rating: 62 (100%+)
I will be at the IIC with the MI5 in the 17.5 class.....
The Teacher is offline
Old 10-03-2013, 08:54 PM
  #1465
I will be racing my MI-5 in the Spec-GT class...
gdcopbdcop is offline
Old 10-03-2013, 09:32 PM
  #1466
good luck to all Mi5 racer, wish you a safe victories
Old 10-03-2013, 10:21 PM
  #1467
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default good luck
Good luck to all at the IIC
Wish I could have made it this year.
Teach go get em.....
olhipster1 is offline
Old 10-03-2013, 10:59 PM
  #1468
jdm19turn's Avatar
good luck to eveyone run mi5's and keep us updated as far as setup changes that are working and if mid or rear motor is working the best for high traction carpet
jdm19turn is offline
Old 10-04-2013, 07:56 AM
  #1469
Trader Rating: 72 (100%+)
I believe I have read that Schumacher makes a u-shaped carbon fiber brace for the front and rear control arm ball-studs. I'm speaking of a brace that would mount to the top of the ball-studs and serve to strengthen their attachment. Does Schumacher make such braces? If so, what are the PNs?
Bill S.
waswadener is offline
Old 10-04-2013, 08:01 AM
  #1470
Bill S.
http://www.redrc.net/2013/09/schumac...ls/#more-72007
cyclonetog is offline
