Like Tree34Likes
Schumacher Mi5
Old 08-01-2013, 11:58 PM
  #1141
dorkmissle's Avatar
Trader Rating: 29 (100%+)
Hi, ran my Mi5 for the first time tonight on med grip carpet. Car was pretty good out of the box. Lots of steering. A little skaty on power (could be my 4.5t and heavy trigger finger) Looking to get yok springs and go up on oil a bit. might need less rear toe. Only wish the diff height could be adjusted.
dorkmissle is offline
Old 08-02-2013, 12:48 AM
  #1142
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Sam is that you? I'd guess you are running at RSD. I would think taking away toe there wouldn't be the fastest way around. I'd talk to Ron Atomic if you can and see what he was running at Mike's a couple weeks ago. Glad to see you wheelin' again!
AWD
andrewdoherty is offline
Old 08-02-2013, 06:35 AM
  #1143
dorkmissle's Avatar
You bet Andrew! Yes on power out of the corner its loose. CT was running a gear diff up front. I didn't have one to try....anyway new car to learn!
Old 08-02-2013, 06:47 AM
  #1144
John.C's Avatar
Trader Rating: 37 (100%+)
What is the easiest / best method for removing the o-ring from the wheel hexes?
John.C is offline
Old 08-02-2013, 08:06 AM
  #1145
Cpt.America's Avatar
Trader Rating: 52 (100%+)
John, I have these little "dental picks" that I keep with all my tools, usually used for picking dirt out of my off-road cars, and I just use those. I can just squeeze it under the o-ring and lift, and it comes right off. You just need something small and pointy that doesn't have a sharp edge, and you can lift it right out.
Cpt.America is offline
Old 08-02-2013, 08:08 AM
  #1146
olhipster1's Avatar
Trader Rating: 102 (100%+)
+1
olhipster1 is offline
Old 08-02-2013, 05:08 PM
  #1147
Potoczak's Avatar
Trader Rating: 120 (100%+)
So... What's the trick to getting minimal rebound on the shocks. No matter what I do I keep getting almost full rebound. I push the piston up to about 2 to 3mm gap, set the bladder on slowly while oil pushes out. Then screw on the cap slowly.
Potoczak is offline
Old 08-02-2013, 05:50 PM
  #1148
nvm, misread your post.
-Mike
grippgoat is offline
Old 08-02-2013, 06:07 PM
  #1149
I start with the piston about 1-2 mm from the top basically as high as I can get it, knowing the piston won't hit the bladder when i start the bladder process.
When I settle the bladder on, I tap it many many many times to make sure there still isn't some pressure on the center of the bladder... I give the bladder a little wiggle.. a little tap tap tap... then I screw on the cap. I usually end up with about 4 mm rebound. Works well for me.
Old 08-02-2013, 07:03 PM
  #1150
chiefj48's Avatar
Hey All,
I'm in the process of building my kit, and now I am at the shock building stage. (did I say how well this kit is???)
Can someone explain how, and where do I cut 3mm out of the shock shaft??
Is it on the thread side, or the piston side, of the shaft?
What is the reason for doing this?
If I glue my piston to the shaft, do I still use both of the clips, or just one??
What is the best glue to use for this??
Do I need to shim the seal unit with the .3mm shim???
Where can I purchase these shims, or assortment of shims??
I know, I ask a lot of questions!!!!! lol
When it comes to building my race cars, I like to build it right the first time, and make sure it is done correct!!!!
I always say, "The Race doesn't start till the Car is built"
Thank you for any advice and guidance you can provide....
chiefj48 is offline
Old 08-02-2013, 07:31 PM
  #1151
Originally Posted by chiefj48
Hey All,
you cut the shaft on the threaded side. this makes it easier use a smaller length from the bottom of the ball cup to the bottom of the shock body. I used both clips, and any good tire glue works well.
gdcopbdcop is offline
Old 08-02-2013, 08:35 PM
  #1152
chiefj48's Avatar
thank you......
do I cut the ball cup shorter, or leave it stock length??
chiefj48 is offline
Old 08-02-2013, 09:03 PM
  #1153
thank you......
leave the ball cup alone. cutting the shaft is enough....
Old 08-03-2013, 12:58 AM
  #1154
The best way i found to build my shocks with no rebound is to drill a hole in the plastic shock cap. Just a 0.5 mm will do the job.
This is what i always did with my tamiya shocks and works great!
Tomorow i'm heading to the euro's in lisbon... Lets see what the factory guys are running!
miguelito75 is offline
Old 08-03-2013, 06:40 AM
  #1155
Potoczak's Avatar
Please post back if you see something new on their cars.
Potoczak is offline
