Like Tree34Likes
Schumacher Mi5
Old 03-03-2014, 05:00 AM
  #1921
TryHard's Avatar
Originally Posted by Gillblade
When u modify the shocks to be 10.5mm long, how do u do it? Cut the bottom of shaft and cut ballcup? Or do i need to use other springcups (schumacher alu?)
What are the benefits of running the shocks at 10.5mm?
You'll need to cut about 3mm off the end of the shock shaft, then just use the normal ball joint and spring cups.
Running the shorter shaft means it is easier to set low rebound levels, as with the shorter shaft the piston doesn't hit the bladder when you push the shaft all the way in.
HiH
Ed
TryHard is offline
Old 03-04-2014, 06:31 AM
  #1922
Are we talking the thread end of the shock? If yes then if you don't cut down the ball cup by 3mm the spring cups will not be 3mm shorter. Unless I am missing some thing.
big paul is offline
Old 03-04-2014, 06:40 AM
  #1923
Just cut the shock shaft in the bottom. The spring cup and ball cup is the same. It will only make the shock a little shorter, and the gap between the top of the shock and the spring cup smaller, but there is enough space for the spring. It will only be a little more dificault to rmove the spring cup afterwards, because there are 3 mm less lenght of the shock. Does that make sence, hope so
Shock Tower is offline
Old 03-04-2014, 02:45 PM
  #1924
TryHard's Avatar
It's the length of the threaded section of the shock shaft that limits how short you can make the shock, so by cutting that back, the ball cup can be wound on further, and shortening up the whole shock length.
Ed
TryHard is offline
Old 03-06-2014, 03:43 PM
  #1925
reg
Hi,
Would it be possible to do a detailed write up with pics with regards to doing the grub screw mod to take out the play in the front hub?
Maybe make it a sticky,
reg is offline
Old 03-06-2014, 04:24 PM
  #1926
TryHard's Avatar
Originally Posted by reg
Hi,
I can do a blog post on it tonight. Not overly difficult, can actually do it without power tools.
TryHard is offline
Old 03-07-2014, 03:51 AM
  #1927
reg
That would be brilliant
Thank you.
reg is offline
Old 03-07-2014, 04:01 AM
  #1928
TryHard's Avatar
Thank you.
As promised
http://www.thard.co.uk/mi5-hub-hinge-pin-mod/
Regards
Ed
TryHard is offline
Old 03-07-2014, 05:12 AM
  #1929
Robert_K's Avatar
Looks like I have something to do!
Regards Robert
Robert_K is offline
Old 03-07-2014, 05:43 AM
  #1930
TryHard's Avatar
Regards Robert
TryHard is offline
Old 03-07-2014, 09:28 PM
  #1931
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default Nice
just wanted to drop a word on the new hard bumper by Discount RC...
just AWESOME!
had to shim the top bumper up 2mil....worked perfect.
olhipster1 is offline
Old 03-07-2014, 10:26 PM
  #1932
reg
That's brilliant Ed thank you very much
reg is offline
Old 03-07-2014, 11:14 PM
  #1933
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by DiscountRCStore
We've heard some grumblings concerning an updated chassis though no one has confirmed for certain. We would speculate that they'd be working on some of the general flexiness; be it ideal for asphalt, not so ideal for carpet. Many of the brands are working and winning with aluminum chassis' right now.. who know's? It's all speculation at this point.. We'll post anything we hear confirmed when it's known.
FWIW.. I do know that Schumacher watches the forums closely.. It might be a good time to post some feedback on some of the things you guys would like to see - if another kit was in the works.. Just a thought ..
..p
I jumped on the Schumacher Bandwagon with the introduction of the Mi3 and have had every model up to but not including the last Mi4model and the Mi5. I loved them all. When I ordered my last Mi4 in prep for a Reedy race the car was hung up in customs for over a month, so I pretty much gave up on any new schumachers. but when the Mi5 came out, it took everything I had to not buy one. I've seen it perform on our local asphalt tracks and the car is amazing and its been hard to not purchase one. one thing that does bother about the car is all the mods people do for various reasons.
oh BTW, I had a Kawada SV10 when the first came out. (its on the shelf) I like that top deck design.
skypilot is offline
Old 03-08-2014, 07:53 AM
  #1934
reg
Originally Posted by skypilot
I jumped on the Schumacher Bandwagon with the introduction of the Mi3 and have had every model up to but not including the last Mi4model and the Mi5. I loved them all. When I ordered my last Mi4 in prep for a Reedy race the car was hung up in customs for over a month, so I pretty much gave up on any new schumachers. but when the Mi5 came out, it took everything I had to buy one. I've seen it perform on our local asphalt tracks and the car is amazing and its been hard to not purchase one. one thing that does bother about the car is all the mods people do for various reasons.
Iv been running a boxstock setup as per kit apart from one extra centre brace £4 I think,no mods and it's second had from the first batch,it's without doubt the best car iv ever driven,I had an ARC and for me it's night and day different,it just grips and goes were you want it to,the mods people are doing are personal not essential
reg is offline
Old 03-08-2014, 02:21 PM
  #1935
Gone Racin's Avatar
Hello Racer's, Just finished my new Mi5. Going to make my first test, and run next Sunday. Hope you like it. Ron H,
Attached Thumbnails Schumacher Mi5-mi5-1.jpg   Schumacher Mi5-mi5-2.jpg   Schumacher Mi5-mi5-3.jpg   Schumacher Mi5-mi5-4.jpg
Gone Racin is offline
