Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-31-2023 | 07:33 PM
  #3481
OCLightning's Avatar
Default TT-02 Party
R, RR, SR - All modified
OVA, Bonezero, angrymelon and 1 others like this.
OCLightning is offline
Old 01-31-2023 | 09:07 PM
  #3482
OVA's Avatar
OVA
question
is the Yeah Racing upgraded conversion kit
ygpm
OVA is offline
Old 01-31-2023 | 09:54 PM
  #3483
All the upgrades are Tamiya on all three but customized the way I liked between the three, I am just not a fan of the adjustable upper arm set for TT-02 (Tamiya #54874). Here are upgrades I currently have installed on TT-02SR:
OVA, angrymelon, kausar07 and 1 others like this.
Old 02-01-2023 | 03:52 AM
  #3484
DirkW's Avatar
Nice, but out of curiosity: why all three? A fully modified R is the same as a fully modified RR (while the Type S, SR and SRX have the different suspension)?
DirkW is offline
Old 02-01-2023 | 04:20 AM
  #3485
MikeTKD's Avatar
What a nice family
Mine is not as nice but I started putting together static chassis (just enough to hold a body) for all the TT02 and TT01e bodies I haven't used because I cannot fathom destroying 8-10 hours of paint and decal work lol.
MikeTKD is offline
Old 02-01-2023 | 07:24 AM
  #3486
Are these the right parts for upgrades to a TT-02? Our rules allow shocksm universales, metal motor mount, bearings an screws.
Is there a better shock to go with? I think someone mentioned a 3racing shock. I might end up with a S6/4 so maybe that would be a better way.
Obviously there are some duplicates. Are the yeah racing pieces better than Tamiya? They're cheaper for sure.
54753 Oil shocks
Yeah racing tt02-015 Universals
Yeah racing tt02-017 universal cups
53792 Tamiya universals
54477 Universal cup joint
54558 al motor mount
TT02-013BU Motor Mount
Silverbullet555 is offline
Old 02-01-2023 | 02:10 PM
  #3487
Raman's Avatar
You need to add an S and the new SRX to the list and you’ll be complete
OCLightning and YoShImUrA53 like this.
Raman is offline
Old 02-01-2023 | 08:17 PM
  #3488
Honestly I just like building but also a couple of co-workers got TT-02 kits and wanted a brushed option to run with them in similar power output, but the Tamiya RZ is so fast it was not fair
And SRX on pre-order
angrymelon likes this.
Old 02-01-2023 | 11:06 PM
  #3489
angrymelon's Avatar
All painted and decaled up to go racing this weekend. Still need to mount the mirror and trim the body posts.
TT02 with RSR body.
SteveM, Rick Vessell, OVA and 4 others like this.
angrymelon is offline
Old 02-02-2023 | 05:09 PM
  #3490
Raman's Avatar
TT02 with RSR body.
What class are you running it in?
Raman is offline
Old 02-02-2023 | 05:23 PM
  #3491
OVA's Avatar
OVA
my guess would be USGT.....
OVA is offline
Old 02-02-2023 | 05:43 PM
  #3492
Raman's Avatar
Wheels don't look like USGT.. maybe VTA?
Raman is offline
Old 02-02-2023 | 05:55 PM
  #3493
OVA's Avatar
OVA
maybe because it fit better under the fender better than usgt tires..just saying
i know this racer
Rick Vessell likes this.
OVA is offline
Old 02-02-2023 | 07:01 PM
  #3494
angrymelon's Avatar
Raman locally we run a class called Scale Spec. Indoor rules require ROAR 25.5 motors and you can use either VTA or USGT wheel/tires. Any scale body is currently accepted. I normally run a TA07, but the plan is to try out the TT02 just to see how far off pace it is. The heavy VTA wheel/tire combo, heavy Tamiya body, and possibly it being a TT02 chassis are all likely points against it being competitive. I built the TT02 chassis for GT Pro Spec, but I only have one TCS race I'm planning on attending, so I figured I'd get some use out of it for now Eventually it will go back to a 257mm wheelbase and likely have either a Ford GT or Mustang GT4 body adorning it.
OVA you're absolutely right. Scale appearance before all else! You think you'll find time to travel down to Yacolt to race with us one of these days?
Old 02-02-2023 | 08:32 PM
  #3495
OVA's Avatar
OVA
Raman locally we run a class called Scale Spec. Indoor rules require ROAR 25.5 motors and you can use either VTA or USGT wheel/tires. Any scale body is currently accepted. I normally run at TA07, but the plan is to try out this TT02 just to see how far off pace is it. The heavy VTA wheel/tire combo, heavy Tamiya body, and possibly it being a TT02 chassis are all likely points against it being competitive. I built the car the TT02 chassis for GT Pro Spec, but I only have one TCS race I'm planning on attending, so I figured I'd get some use out of it for now Eventually it will go back to a 257mm wheelbase and likely have either a Ford GT or Mustang GT4 body adorning it.
Hey Ryan
No Doubt I will coming down to have fun ..I came down last year and had great time
I am not sure if I am racing 2023..TCS .pro GT Spec is a fun class ..I blew my chances twice for the win / L placed second 2021/ TQ and second places 2022
( It was the hottest day and I blockout and clipped the pipe..) still had a good times
OVA is offline
