Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 09-14-2022 | 11:57 AM
  #3391
Raman's Avatar
Originally Posted by Xrayray
How do the cars compare when running the kit rear hubs vs hop up 3 degrees? Is it a big difference?
Given the specs motor low speed, there was not much of a difference. 2nd place car was running the plastic lot ones. This was on black carpet.
Xrayray likes this.
Raman is offline
Old 09-14-2022 | 12:02 PM
  #3392
OVA's Avatar
OVA
Originally Posted by simple
Really, not even ball bearings or oil dampers?
they do make the difference imo
it is depend on track layout and track grips set up
I Top TQ and finished 2 in TCS.. I must fell a sleep in the main...
OVA is offline
Old 09-14-2022 | 12:11 PM
  #3393
OVA's Avatar
OVA
I was running the TT02RR which is stock alum 3 deg rear hub and I went to the plastic hub and it was un drive able
but again pn Black Carpet may be different stories
Xrayray likes this.
OVA is offline
Old 09-14-2022 | 12:26 PM
  #3394
I have the R and it needs more steering, I'm maxed on steering travel but mid corner still pushes a bit wide than I like. This is on asphalt so if the zero degree plastic ones are too loose then I'll keep my 3 degree hubs. Not trying to spend another $40 for the 2.5 hubs.
Xrayray is offline
Old 09-14-2022 | 01:48 PM
  #3395
Dan's Avatar
Dan
What springs, shock oil and diff settings? Which tires?
Dan is offline
Old 09-14-2022 | 02:36 PM
  #3396
TT02-R kit build, kit oil shocks, 3 hole piston 32.5 oil. Greased rear diff, hop up spool front. Sweep 36 tires.
Xrayray is offline
Old 09-14-2022 | 02:50 PM
  #3397
OVA's Avatar
OVA
are you running front spool?
front soft spring
2.5Mil front gear diff
one step stiffer rear spring or one hole upright rear shock position
low RC front and high in the rear camber link setting
OVA is offline
Old 09-14-2022 | 03:32 PM
  #3398
Raman's Avatar
You were texting while driving again?
Raman is offline
Old 09-14-2022 | 03:34 PM
  #3399
front soft spring
Yes, the hop up option spool. Everything else kit.
I have the shocks mounted in on the front and out on the rear. Same shock package all around.
Xrayray is offline
Old 09-14-2022 | 03:44 PM
  #3400
OVA's Avatar
OVA
you knew it
OVA is offline
Old 09-14-2022 | 03:46 PM
  #3401
OVA's Avatar
OVA
gear diff is better for me
it allow more corner steering
Xrayray likes this.
OVA is offline
Old 09-14-2022 | 03:49 PM
  #3402
Raman's Avatar
you knew it
They’re looking to revive the Silverbowl here in Vegas. You can build a whole TT kit before ProSpec 21.5 motor propels the car down the back straight. 😉
Raman is offline
Old 09-14-2022 | 03:52 PM
  #3403
OVA's Avatar
OVA
nice
OVA is offline
Old 09-14-2022 | 04:50 PM
  #3404
I will do some testing, thanks for the advice.
Xrayray is offline
Old 09-16-2022 | 05:57 PM
  #3405
Fixed my problem with the Year racing hubs along with the yeah racing drive shafts.
BullFrog is offline
