Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-12-2022 | 11:36 AM
  #3226
[QUOTE=Pinkgold88;15894115]
Originally Posted by TurboThirdGen
Got my red wheel nuts and Traxxas drift wheels in today. Getting that much closer to completion. Need to get it on some P-tile and dial it in.
nice in black , i do love the 73 rsr
It looks black but its actually the PS Pearl, backed with translucent blue, backed with black. It looks black until the sun hits it just right, then its a deep blue with heavy pearl flake. I'll need to dig out the DSLR camera to get a real good pic of the color. But it came out like I wanted; Like the Tuxedo Black on some of the older Corvettes.
Pinkgold88 likes this.
TurboThirdGen is offline
Old 04-12-2022 | 11:39 AM
  #3227
Originally Posted by Infinitesd
Seriously best advice I every had, thank you so much! I always assumed I knew what I was doing and just skimmed the pages. Especially since I have so many hop ups, and end up using those instead of stock parts.
Now I just wished I bought a better alloy steering assembly. The Yeah Racing has loads of slop.
I did the same thing with my TT02R. Ordered the whole Yea Racing blue aluminum kit. Looks so good. The R is my speed run rig.
Old 04-12-2022 | 02:50 PM
  #3228
Smile
[QUOTE=TurboThirdGen;15894291]
its damned pretty ,whatever the colour is , will be steeling your bonnet clip tether idea , lovely touch.
TurboThirdGen likes this.
Pinkgold88 is offline
Old 04-12-2022 | 05:12 PM
  #3229
[QUOTE=Pinkgold88;15894349]
Thanks bud! Yeah I wanted to do magnetic mounts, then I figured I could just try to make the body posts look like hood pins. I think it worked pretty well!
Old 04-13-2022 | 03:46 PM
  #3230
Has anyone got 47333 lying around that they would part with. Its the blue A parts, looking for some to complete a project
jgil089 is offline
Old 04-13-2022 | 05:07 PM
  #3231
IndyRC_Racer's Avatar
I was going to suggest reaching out to Tamiya fans on Tamiyaclub.com, but it looks like someone has already helped you there.
There is also Tamiyabase.com as well as the Wanted to Buy forum here on RCTECH.NET...
https://www.rctech.net/forum/r-c-items-wanted-buy-17/
Good luck on your quest.
IndyRC_Racer is offline
Old 04-13-2022 | 05:38 PM
  #3232
haha yep, I offered to ask here since hes been looking for 2 years! Will post in the wanted, see what comes up
jgil089 is offline
Old 04-17-2022 | 03:03 PM
  #3233
Default Editable set-up sheet
I’ve made a Stock TT02 editable set-up sheet to download. Following this I also thought I would share my base set-up for asphalt tracks.
https://www.thercracer.com/2022/04/t...p-and.html?m=0
IndyRC_Racer likes this.
Qatmix is offline
Old 04-17-2022 | 06:29 PM
  #3234
In the memo sections for the dampers, what are the 0.4 and 0.2mm shims for?
For a parking lot with less traction, would you run softer springs?
chjosi is offline
Old 04-18-2022 | 06:19 AM
  #3235
Those shims are used to fine tune the ride height. They ate 3mm internal diameter. Slide them on the piston and then fit the ball cup. This adds a finer amount of tuning to the ride height when using plastic CVA shocks.
If you use the TRF threaded units then you don’t need to do it as they provide fine adjustments anyway.
For low bumpy tracks softer springs are fine, but I would still start with the above. It is a very versatile base set-up.
I would first however add shock rebound to ensure the tyres are always in contact with the more uneven surface. This provides more grip than you could imagine on car parks etc.
Also adding more ride height can give you more lateral grip in the corners, but you will suffer if there are any faster switchbacks etc.
chjosi likes this.
Qatmix is offline
Old 04-19-2022 | 07:23 AM
  #3236
Default 3D printed TT02 Aero parts.
Alright guys, got some PETG filament in so have been printing, tweaking and test fitting for a couple days. The Front Splitter is the 3rd version and the Rear Diffuser is on its 4th version already. I have a side skirt I've designed for the left side that I am tweaking that fits well, and I'll mirror it for the right side then add the additional cutouts. The skirts will attach to the sides of the bathtub chassis. I haven't decided between clips, screws, or double sided tape for mounting yet. First sets will most likely get the double sided tape for testing.
Let me know what you think along with any design suggestions you may have. The side skirts are simple, straight ones at this point.
Raman, angrymelon, Eotz and 1 others like this.
Old 04-21-2022 | 02:00 AM
  #3237
So you are running zero droop? because you are controlling the ride height with the shock lengte
Rick Vessell likes this.
arnold1000 is offline
Old 04-21-2022 | 07:42 AM
  #3238
Raman's Avatar
No. Normally you reduce droop in front, to maybe 1mm over ride height.. eg you push down on front shocks to settle suspension.Then you pull up on body posts and you want upwards movement around 1mm. Rear you do around 2-3 mm.
Raman is offline
Old 04-23-2022 | 05:42 AM
  #3239
Default Quick aero update
Finished up the aero kit. After work today I'll try to modify some of it to make it more "generic" to fit more kits. The diffuser will take quite a bit to make "universal" so I'm not sure about that one.
SteveM and kwkride like this.
Old 04-23-2022 | 06:27 AM
  #3240
Vertebreaker's Avatar
That looks pretty clean. Nice work.
Vertebreaker is offline
