Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 11-09-2021 | 10:10 AM
  #2926
Raman's Avatar
If you pick up a basic TT02 kit, in my opinion, don’t waste your money buying the CVA plastic oil filled dampers.
For the same money you can buy the Yea racing aluminium which are basically a copy of the TRF. The threaded shock collars allow you to adjust ride heigh much more accurately.
Unless your planning to race in Tamiya TCS, which only allows for Tamiya parts
Raman is offline
Old 11-09-2021 | 10:13 AM
  #2927
Originally Posted by Raman
TA05R is a much better chassis than TT02. That’s the chassis I run for my speed runs.
However if you plan on hitting some dirty / rallye, stick with TT02.
Thank you. How about parts for the TA? Would it be an issue?
lnc0321 is offline
Old 11-09-2021 | 10:14 AM
  #2928
Thank you
lnc0321 is offline
Old 11-09-2021 | 10:22 AM
  #2929
No no, don’t use motor oil. Just picked up some Team Associated Silicone shock oil, 50wt, 55wt, 60wt.
Definitely add camber to front and back. Zero toe in back is causing the instability. I’m running 2° In on my rear and 1° out on front
I do have non-detergent oil if that's the issue.
What's the most robust option for rear toe? I'm using the body posts on the rear bumper so need the rear bumper to be attached.
I could fabricate something. I'd 3d print something but no plans openly available and I haven't taken the plunge into designing yet.
TurboThirdGen is offline
Old 11-09-2021 | 11:44 AM
  #2930
The current state of the chassis.
Upon further looking at the yeah racing rear toe mount, It might work with the bumper; I just need a caliper measurement from the front to back of the adjustable mount where the screws go.
Gyosho likes this.
Old 11-09-2021 | 12:57 PM
  #2931
Raman's Avatar
Hard to find parts are:
1. Replacement chassis
2. Belts.. V1 in particular
all other bits are more or less interchangeable and upgradable with later cars.. eg you can use suspension arms from 418, 419, 420 with no issues.
Belt, you can switch to V2 belt if you change the pulleys, which is better anyways. V2 belts can still be found.
Hop Up.. there is still plenty of inventory out there
Raman is offline
Old 11-09-2021 | 01:25 PM
  #2932
Thank you
lnc0321 is offline
Old 11-09-2021 | 02:29 PM
  #2933
Raman's Avatar
what brand tyres are those?
Mykranili likes this.
Raman is offline
Old 11-09-2021 | 02:37 PM
  #2934
Not sure the brand but here's where I got them. They have really good grip and the price isn't bad either.
4PCS 28MM 1/10 On Road RC Car Tires With Foams (Can be used for 26mm wheels) | eBay
Mounted on generic aluminum wheels.
Old 11-09-2021 | 02:54 PM
  #2935
Raman's Avatar
This is my TA05 V1 60mph car.
garnt, Mykranili and Gyosho like this.
Raman is offline
Old 11-09-2021 | 03:06 PM
  #2936
I love the Porsche bodies. I'd love to get the Tamiya Toyota TS020 GT-ONE body but I'm not even sure it would fit on the TT02.
I feel like something is off on the chassis. I put the shorter lower eyes on the shocks and moved the front shocks in up top. I have 2mm droop in the front and no rear droop with the mini CVAs.
Still pulls to the left pretty hard. I also have the 30mm foams. I'll have to get the ride height but its about 6mm front and 7mm rear.
Old 11-10-2021 | 02:30 PM
  #2937
Hi guys. Do you guys recomend 2 oil diffs or just rear and in the front stock with thick grease or locker? I am looking at the YeahRacing one.
https://nitrohobbies.com/tatt-020/
Thank you
lnc0321 is offline
Old 11-11-2021 | 06:53 AM
  #2938
Raman's Avatar
I typically run front diff locked / spool and rear with Oil filled. The only car I run a front diff on is my XV01 which is used for Rallye on dirt, snow etc.. that has a gear diff, but with very thick fluid
SteveM and jgil089 like this.
Raman is offline
Old 11-11-2021 | 07:05 AM
  #2939
Thanks again.
lnc0321 is offline
Old 11-11-2021 | 08:11 AM
  #2940
Silly putty in the front diff will make it into a solid spool, and it can be easily removed without residue later should you want to get the diff action back. Also won't leak.....bonus.
lnc0321 and Raman like this.
SteveM is offline
